Noob Question-Map Lamp Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 95SLE, Sep 11, 2009.
  1. Sep 11, 2009 at 5:32 PM
    95SLE
    95SLE [OP] Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Do you just have to take the map light lense off to replace the light bulb?
  2. Sep 12, 2009 at 4:23 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
  3. Sep 12, 2009 at 8:14 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The MAP lights are a 'button' - which might be designed differently than a standard lens/light. I honestly don't know for sure.
    Taking the overhead console down is SIMPLE. Why not take it down and poke around a bit before trying to poke & pry at the lenses?
  4. Sep 12, 2009 at 8:30 AM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    just use a small flat srew driver and they pot open
  5. Apr 30, 2010 at 7:59 PM
    AZM9
    AZM9 Well-Known Member
    Jay
    Chandler, AZ
    2009 Prerunner TRD Sport
    ARE tonneau cover, Redline hood struts, Leaf TSB, and Trans TSB, Satoshi grille.
    You do not have to take out the console to change these bulbs. The lenses pop off using a eyeglass screw driver.
