Noob question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AgingDisgracefully, Apr 26, 2018.
  1. Apr 26, 2018 at 8:54 AM
    AgingDisgracefully
    AgingDisgracefully [OP] Well-Known Member
    Peter
    2016 Tacoma SR5 V6 4X4
    Hi All,
    I am the proud new owner of a 2016 SR5 4X4 V6. This is my first truck, let alone Tacoma.
    I have what is probably a weird question and I am not even sure if I am getting the terms right.
    The one feature of the truck I don't like is that it has a running board/side step (some sites call it a "nerf bar") installed. I'm pretty tall (6'3") so I don't need this.
    Removing it seems as simple as just unbolting it.
    However, I have now watched a few videos of installing these things and all of them start with the removal of OEM plastic screws/bolts designed I guess to protect the nerf bar mounting bolt holes and keep moisture out.
    Does anyone know where or how one can buy plastic these plastic screws/bolts so that I can replace them when I remove the nerf bard? Or what they are called?
    Thanks so much in advance.
  2. Apr 26, 2018 at 8:59 AM
    chertzog
    chertzog Well-Known Member
    Lewisberry, PA
    2008 Red DCSB SR5 Sport
    You could always just re-thread the bolts back in.
  3. Apr 26, 2018 at 9:04 AM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Just hit the bolt holes/threads with a bit of rustoleum paint to discourage rust.
  4. Apr 26, 2018 at 9:28 AM
    strktly_bodysurf
    strktly_bodysurf Well-Known Member
    Here is some horrible advice (Be warned, its HORRIBLE ADVICE)
    Find plastic screws with the same thread type and length and plug them with some loctite
  5. Apr 26, 2018 at 9:34 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Don't put loctite on plastic screws lol. When you go to take it out youll break the head off the plastic screw and you'll be screwed
  6. Apr 26, 2018 at 9:36 AM
    strktly_bodysurf
    Sorry I should have clarified. I'm assuming this is a permanent type deal? So, as to not make another point to rust, I suggested plastic screws and a pretty permanent applicational adhesive :cheers:
  7. Apr 26, 2018 at 9:36 AM
    epluribusunom
    epluribusunom Well-Known Member
    Luke
    '16 White SR5 4x4
    This mate.
  8. Apr 26, 2018 at 9:40 AM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
  9. Apr 26, 2018 at 9:41 AM
    phsycle
    phsycle Well-Known Member
    CA
    This is horrible advice. Why would anyone want to permanently glue them shut? What are the advantages? I'd rather just leave them open rather than doing that.
    OP - you can also tape them shut as well. Probably some gorilla tape cut to size would do the trick. Or like others said, just reinstall the bolts (put some anti-seize on the threads)
  10. Apr 26, 2018 at 9:45 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    welcome to the forum and the world of owning Toyota trucks..to answer your question, you could also put a small dab of silicone caulk in the holes and if you ever needed them, you could use a small center punch or nail to push the caulk out..i have done this in the past and it works great.
  11. Apr 26, 2018 at 9:52 AM
    strktly_bodysurf
    :( Sorry for my horrible advice, OP.
  12. Apr 26, 2018 at 9:55 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Even though you might not need them to get in and out, they'll still prevent door dings. I also find it necessary when washing or waxing my truck and I'm tall also.
  13. Apr 26, 2018 at 9:56 AM
    chertzog
    Lewisberry, PA
    I have steps on mine. I dont need them, but wifey does.
  14. Apr 26, 2018 at 9:57 AM
    Taquitoma
    Taquitoma Well-Known Member
    2017 OR DCSB M/T
    You could try calling a local dealer and see how much they would charge, or if you sell the steps locally ask the person buying if they wouldn't mind you taking the plastic plugs off their hands.
  15. Apr 26, 2018 at 10:00 AM
    eon_blue
    Azusa, CA
  16. Apr 26, 2018 at 10:00 AM
    strktly_bodysurf
    I'm sorry for offending you.
    I don't feel bad though, should I?
    eon_blue[QUOTED] likes this.
  17. Apr 26, 2018 at 10:01 AM
    eon_blue
    Azusa, CA
    lol I was just making light of the fact that others here were taking it so seriously.
    tcjacado likes this.
  18. Apr 26, 2018 at 10:01 AM
    strktly_bodysurf
    We get it. You need attention
  19. Apr 26, 2018 at 11:12 AM
    AgingDisgracefully
    Peter
    This is a good point. I need to think about that. Thanks.
  20. Apr 26, 2018 at 11:13 AM
    AgingDisgracefully
    Peter
    No worries. :)
