Noob question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BirdTRD, Oct 30, 2009.
  1. Oct 30, 2009 at 12:09 PM
    BirdTRD
    BirdTRD [OP] Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Noob here,
    I've been searching and can't find an answer. What is a TSB rear? I can tell it has something to do with the leaves but not sure exactly what. I see everyone talking about them but I can't find any explanation of what they are.
    OK, now flame away but please at least answer the question while you're at it.
  2. Oct 30, 2009 at 12:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its a new 4 leaf spring replaceing the 3 leaf OEM springs. :)
  3. Oct 30, 2009 at 12:14 PM
    thestrangebrew
    thestrangebrew AlphaPlanner
    Brian
    Dos Palos CA
    TRD 4x4 Rugged Trail Edition
    Black Badges, Black Center Console
    You should be able to find the actual TSB for it if you do a search up top. Alot of people here have been able to get it done at no cost. Good luck.
  4. Oct 30, 2009 at 12:14 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Thanks. What's the story with it? Is it factory/aftermarket? Stiffer? Lift? It sounds like it would be good for hauling/towing and bad for wheeling.
  5. Oct 30, 2009 at 12:16 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    The factory does it huh? What are the advantages? My truck is under warranty and the guys at the local dealer are awesome. Should I inquire with them?
  6. Oct 30, 2009 at 12:28 PM
    JTDTacoma
    JTDTacoma Well-Known Member
    08 4X4 Double Cab TRD Sport
    You'll find a ton of info about it by searching. But to sum it up, yes get it done if you are still under warranty.
  7. Oct 30, 2009 at 1:11 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I have a search writeup that I did that may help you generate better results. Click the link in my signature. I'd suggest a Titles-only search for TSB.
    Basically, the stock springs are weak and cause the truck to bottom out easily creating a rough ride. The TSB springs add a helper leaf which stiffens them up. The advantage is that your truck doesn't sag when the bed is loaded.
    On mine, they were so weak that the truck would hit the bump stops when going over a curb. It does stiffen the ride a bit but I don't think it's bad.
  8. Oct 30, 2009 at 1:17 PM
    thestrangebrew
    Brian
    Dos Palos CA
    It gave my truck about 1.5" of lift. I've got a serious rake now but I'm planning on getting some 5100s to take care of that. It'll ride a little stiffer once it settles but it makes a huge difference when driving with a load. I recommend getting it done if you're still under warranty.
  9. Oct 31, 2009 at 1:22 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
