Noobish "Jump Start" Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by theTupper, Nov 4, 2013.
  1. Nov 4, 2013 at 3:22 PM
    theTupper
    theTupper [OP] White and Nerdy
    Jacob
    Raeford, NC
    '10 DCSB Off Road PreRunner
    The times that I've had to give someone a jump, I've always been in a truck. I'm not sure why that matters, but I'm hoping someone will answer my question or tell me I'm full of it.
    I walked out of school this evening and found a couple of my colleagues trying to jump-start a car. Suzie had left her lights on all day and her car was dead ("wouldn't even pop the trunk" dead) and Jill had pulled her little-bitty PT Cruiser along side and opened her hood. Jane was there and said she knew how to jump a car and hooked up the cables (in the right places) and told Suzie to crank it over.
    No luck. They let it sit a few minutes, still hooked up. No luck.
    These were competent and intelligent people...but just to be sure I sneaked over and peeked to make sure everything was in order: it was.
    By now, 20 minutes have passed and the car still won't start. With no other ideas I decided to pull the Tacoma over and hook it up.
    You see, I thought maybe since the truck has the larger 130A tow-package alternator that maybe it would have a little more "oomph" to get Suzie's car started up.
    I pulled over, hooked it up, and it started...first try.
    So my question is this:
    When jump-starting a car, does the size of the alternator on the running vehicle actually matter? I mean...12v is 12v out of a battery so the only thing that could make the difference is the amperage of the alternator, right?
    OR
    Was it coincidence and the fact that they had "trickle charged" the battery for 20 minutes and I just HAPPENED to hook it up when I did what actually mattered?
    I've never had a reason to question it before as the times I've had to give someone a jump I've always been in a truck with a heavy duty alternator. I can't imagine the little PT cruiser had a big one though.
    Genuinely curious, and sorry for asking what I'm sure is a stupid question.
  2. Nov 4, 2013 at 4:21 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    that is quite interesting. I know that some vehicles may require more amperage to get a starter to turn at the correct speed but the pt I would think to be able to juice up another car.
    my guess is that though they may have had the polarity correct, there may have been a bad connection.
  3. Nov 4, 2013 at 4:26 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    92 was mostly there.
    Basically, amps matter too, not just volts. The PT Cruiser may have eventually gotten the other car charged enough to start, but the truck's alternator is much better designed for it.
  4. Nov 4, 2013 at 4:41 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    I would hedge a good bet that after 20 minutes of charging, with no change at all in trying to crank that it was a crap connection.
    I have jumped some large vehicles with little hondas, it does take longer but it is more than capable of doing the task.
  5. Nov 4, 2013 at 4:53 PM
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
    more importantly, pics of suzie and jill??? :)
  6. Nov 4, 2013 at 5:06 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Battery acid on the connection? Not a good connection on the jumper cables?
  7. Nov 4, 2013 at 5:07 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    :proposetoast:
  8. Nov 4, 2013 at 5:12 PM
    169.254.255.201 Well-Known Member
    Interwebs
    My friend went to jumpstart a pt using his celica, and it wouldn't. Had to use the tacoma..
    I think the pt would start to crank or something with the celica, but wouldn't start
  9. Nov 4, 2013 at 5:23 PM
    theTupper
    Jacob
    Raeford, NC
    I thought it might be the connection but it seemed to be okay. When the PT was hooked up to the Jetta, the Jetta's dome light would illuminate so the connection was good, no?
    I had a feeling this was part of the answer. Thanks!
    lol
    There's one (or a dozen) in every crowd. :)
  10. Nov 4, 2013 at 5:27 PM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    I had my truck die, I was too lazy to push start it, so I and had to have one of my colleagues, we will call her colleen, jump me in her focus. She had to rev her engine to get me jumped.
  11. Nov 5, 2013 at 4:41 AM
    mandzach
    mandzach Well-Known Member
    Our trucks, almost every truck/car alternator will not put out its maximum amps at idle. You really need to be into the skinny peddle to get the amps up.
    So if you were idling when you jumped her, it was more than likely a bad connection on the first vehicle.
