Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Dec 23, 2018 at 8:14 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Tacomaworld; not Mazdaworld... :D
    Interesting advice. I'll have to try it.
    nDub[QUOTED] likes this.
  2. Dec 23, 2018 at 8:18 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yeah that's on my "want" list. When I've got the free cash I'm adding UCON, possibly 7th injector, probably 2.7" pulley, headers (still on the shelf, i know I know, but have been debating URD equal length instead), and probably a new exhaust. Have also been slowly researching a spare 4.0 to get bored out, add a stroker kit, and upgraded internals, like Torspd did. That's a whole nother rabbit hole I'm not sure I want to go down though. I need to pick Jasons brain someday about dropping a 5.7 into it if its CA legal and all that. If the ECU mates up just fine and all that, whats the fitment like, blah blah blah, that's far down the road though.
    Yeah I've looking into Steigmeyer (sp?) before, its about $600-800 or so with shipping and their porting service, unsure if its worth it for 10% more hp, so...maybe 10hp. Have looked into their Snakebite system as well which IIRC is the full port and polish plus regearing the rotors for twice the speed and boost. Something like 14 lbs of boost with the stock pulley. Reliability comes to mind on that one though.
    Right now I'm just fixing broke stuff. Had a stripped cam bolt that's seized in place, having to cut it out tomorrow. Was replacing Lower uniballs and adding new brakes as well before my Pismo trip on Friday. Ordered a Sawzall to cut out the cam bolt (the front one that's a shaft the bolt goes through) with extra blades....sawzall showed up Saturday....blades say "out for delivery" and then "delivery delay" today. Was hoping to have that thing cut out and everything put back together tonight, so hopefully they show up tomorrow or wednesday. Have everything prepped to put back together, shouldn't take all that long.
  3. Dec 23, 2018 at 8:27 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Welcome!
    FirstTimeFirstGen likes this.
  4. Dec 23, 2018 at 8:39 PM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Welcome!
  5. Dec 23, 2018 at 11:14 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Darn if I was closer or not so busy i would have brought over a sawzall and a little torch. I've got a spare set of OEM LCA if anything goes wrong during cutting ( but at least one has a stuck bolt too) I was gonna keep them as spares and put in new bushings but I have no spare time and they are big and heavy. Most likely gonna end up as scrap at this rate.
    I looked at Snakebite and I'll probably do some porting of lower and S/C when time comes for rebuild. Full snakebite at least for mustangs add new cooler and I am sure the smog guys will hate that but they won't see just the porting. There are at least two other places that do S/C rebuilds I have bookmarked somewhere.
    Good luck with all the fixes! Looking forward to hearing about go fast stuff.
  6. Dec 24, 2018 at 12:29 AM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    I never used to have issues other than maybe holding a pen for too long. Or as I said, chopsticks. Can’t use chopsticks for more than 5 minutes otherwise I’d be in pain. Sitting at a keyboard or whatever for hours at a time, no issues. Driving never used to irritate my hand up until maybe a month ago. I had to drive lefty earlier because the thumb part of my hand became unusable. No amount of shaking helped.
    That is where I’ve been resting my hands since the day I started driving. Either that or right dead center at the very bottom. It’s just...less effort. Any higher up and it’s wasted energy in an attempt to keep my arms elevated.
  7. Dec 24, 2018 at 4:30 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Let’s eat!
    tacomgee, rob1208, HAVING FUN and 4 others like this.
  8. Dec 24, 2018 at 6:36 AM
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
    Yes, let's!
    :hungry:
  9. Dec 24, 2018 at 8:11 AM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    I notice when I wrench after awhile my hands go numb also. Getting older sucks..
  10. Dec 24, 2018 at 8:12 AM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Weather in bethpage Tennessee, 28 degrees and foggy.
  11. Dec 24, 2018 at 8:50 AM
    Tee Arghhhhhh Dee
    Tee Arghhhhhh Dee is typing...
    Jay
    Bay Area
    2011 SW DCSB 4x4 4.0L V6 Manual
    Stuff
  12. Dec 24, 2018 at 8:50 AM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Kommiefornia
    08 Taco
    91 Octane
    HB JAY!
  13. Dec 24, 2018 at 9:08 AM
    Moogle
    Moogle Dyslexic Stanist
    Glen
    Alameda, CA
    07 Silver TRD Sport DCSB 4x4 6-speed
    Blood of virgins
    I got these for when I had to cut out both my LCAs. Made quick work of it.
    https://www.acehardware.com/departm...Q0SRNlzn9xTIsFvJocbqIAGLW2TOArJsaAkQjEALw_wcB
  14. Dec 24, 2018 at 10:48 AM
    nDub
    Lead Free Gasoline
    Oh shit I missed it. Happy birthday!
  15. Dec 24, 2018 at 11:21 AM
    VolcomTacoma
    Jeff
    NorCal
  16. Dec 24, 2018 at 11:53 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Merry Christmas, ya filthy animals.
  17. Dec 24, 2018 at 11:54 AM
    Moogle
    Glen
    Alameda, CA
    Blood of virgins
    You're a day early, heathen.
    Anderson and Fernando like this.
  18. Dec 24, 2018 at 12:36 PM
    T4RFTMFW
    I don’t plan on being here tomorrow. So..
    I’ll just delete it then. :bananadead:
  19. Dec 24, 2018 at 2:12 PM
    T4RFTMFW
    Alcohol would’ve killed those germs.
    You failed yourself, friend. :drunk:
  20. Dec 24, 2018 at 2:17 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Cheers ya'll. Merry X-Mas Eve
