Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Oct 31, 2012 at 7:22 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    The Cougar is on fire tonight!!
  2. Oct 31, 2012 at 7:23 PM
    acdronin
    acdronin Well-Known Member
    :rofl:
  3. Oct 31, 2012 at 7:47 PM
    SACTOWN
    Greg
    It was more of a really.... Did you just say that?!?!?
  4. Oct 31, 2012 at 8:19 PM
    whiteboy
    whiteboy Well-Known Member
    Cody
    Glendale, AZ
    '06 TRD sport
    Kings, alcans, 33's blah blah read my build thread in sig
    Save the pillow talk for the meet ;)
  5. Oct 31, 2012 at 8:21 PM
    SpazzyB
    SpazzyB Master of the Prius...
    Ryen
    neuf un six
    '04.5 vw stance machine
  6. Oct 31, 2012 at 8:21 PM
    whiteboy
    Cody
    Glendale, AZ
    '06 TRD sport
    The back has minor ones. That doesn't bother me. I know it's the leaf springs and bushings. The front driver and passenger sides are what are bugging me. I'm thinking it could be my TC UCAs possibly? They only squeak at slower speeds and when I'm turned at least halfway on the steering wheel. The bushings got greased with super lube or whatever that recommended white grease is and tri flow lube as well.
  7. Oct 31, 2012 at 9:51 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    They make lube for that man. You gotta take care of your stuff. Use dry lube or the silicon lube on the ball joints after every wash. You ultimately should clean out all the old lube...but its a pain. Mine squeaked a little for the first couple months but it went away after awhile.
  8. Oct 31, 2012 at 10:03 PM
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    My truck has had super squeaky suspension since day 1. Since lifting it, even worse, and I have greased all fittings and also dry lubed the uniballs. Never heard such squeaky suspension, but I just turn up the beats and say f-it
  9. Oct 31, 2012 at 10:22 PM
    whiteboy
    Cody
    Glendale, AZ
    '06 TRD sport
    I have been using the dry lube on the ball joints and grease shoved in all the bushings. Here are two videos I just took on the way up my driveway that you can hear all the sounds on. Seeing as this only happens when I the steering wheel at least half lock and going slow, I think something is rubbing that doesn't have to do with my suspension or something. I may have accidentally pushed something into something else when I was lifting up the front of my truck. I took off the wheels the other day and jacked slowly from that fat screw at the bottom of the brakes. :confused: Maybe that mud guard or whatever got bent? I'll check tomorrow after work, have to sleep now.
    You can clearly hear it at about 8-11 second range.
  10. Oct 31, 2012 at 10:29 PM
    Shaggs
    NorCal
    sounds like a brake backing plate more than suspension
  11. Oct 31, 2012 at 10:33 PM
    whiteboy
    Cody
    Glendale, AZ
    '06 TRD sport
    Yeah, alright that's what I was thinking. I thought that if it was my UCA, it would be noisy no matter what. Not just from slow turns and such. I'll have to see where it rubs tomorrow.
  12. Nov 1, 2012 at 3:20 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    I know you won't show. You never join us.:(
  13. Nov 1, 2012 at 8:46 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
  14. Nov 1, 2012 at 8:51 AM
    acdronin
    X2
  15. Nov 1, 2012 at 8:53 AM
    acdronin
  16. Nov 1, 2012 at 9:08 AM
    SACTOWN
    Greg
    Are you sure your not mixing him up for me?!?!?!
  17. Nov 1, 2012 at 9:08 AM
    SACTOWN
    Greg
  18. Nov 1, 2012 at 9:14 AM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
  19. Nov 1, 2012 at 9:16 AM
    acdronin
    bummer, maybe you should call in sick that day:)
    If you know any of the other peeps up there hit them up, it's their big chance to meet a lot of members without a brutal drive.
  20. Nov 1, 2012 at 9:26 AM
    coppert
    coppert Mall Krawler
    Travis
    916
    I would have been all over this a few weeks back! I had to pick up a 2nd job that has tripled the mileage I'm putting on, so I have to stick with my A/T's for now. :(
