"Normal" 3rd gen manual trans noise fix
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DeeKay20, Nov 7, 2020.
  1. Oct 6, 2022 at 2:19 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Not in the least. In neutral, there is zero torque going through the transmission.
    I put noise insulation on the inside face of the heat shield. It does a surprisingly great job of killing that noise. Garden hose washers are pretty large. You'd need an o-ring or something smaller like that. But if you are in there, slap some sound insulation on there.
    OZ TRD and doublethebass like this.
  2. Oct 6, 2022 at 2:21 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    I thought it was something to do with lubrication...
  3. Oct 6, 2022 at 2:31 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good point. I believe that @Jowett mentioned that there is a pump in there. My best guess is that it would be driven off the output shaft. I could be wrong, but pumping from the input shaft while idling doesn't seem necessary?
  4. Oct 6, 2022 at 3:40 PM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    I'm looking to add a pump for cooling and to increase durability under the higher power circumstances in which my truck will be operating. The design of the transmission, in very very neat way, already pushes lube to all the required places via channels, holes, etc.
    Coasting in neutral should be fine, but I would not flat tow for any great distance w/o the engine running.... even then.
    Having a transmission opened up, my best guess while looking and wiggling gears and shafts, is that the source of the noise is some lash between gears, shift sleeves, hubs, and sychronizers. The noise rings out through the cases, heat shields, etc.
  5. Jul 16, 2024 at 6:38 PM
    BrianKindly
    BrianKindly Bozo
    NE Ohio
    2021 TRD
    MGM 6MT
    If this actually fixes that absurd noise, I'll love you forever. I assumed it was normal, even though I bought the truck used, it only has 30k miles.
    Might throw this on it too to double tap the situation haha.
    Do you have any further info on this, or a link to the TSB?
  6. Jul 16, 2024 at 6:49 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I missed this thread. Although I hardly ever hear the noise and don’t find it annoying, I appreciate the troubleshooting.
    I was talking about this noise in a thread just the day. I got curious again and listened for it carefully while driving slowly with my windows open and radio off. I didn’t hear a thing. I have heard it many times in the past. There may have been too much background noise.
  7. Jul 16, 2024 at 6:55 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The noise/condition is normal, it is because the reduction gears are between the counter shaft and output shaft instead of the conventional transmission build where the input is geared direct to the countershaft instead. The reason for the noise is because the transmission internals are always spinning when the truck is rolling due to that reduction gear setup. With bumps and whatever else you can get slightly changes in speed in the wheels which can cause the transmission to switch between coast and drive just slightly enough to make clanking. Hard to explain it in a way that makes sense, but every counter-to-output geared transmission I’ve driven has been the same.
    What the OP did was muffle the noise some. You’ll still feel it in the shifter if you grab it while going over the bumps in neutral.
    The good news is, it won’t hurt anything but your feelings. It is annoying, but just a side effect of this design. The design is pretty good otherwise though, it results in less torque running through the drive gears, allowing for gears and shafts to be smaller and make for a more compact design while allowing the transmission to still handle enough torque for
    the application.
    All the TSB did was provide a heat shield coated in sound deadening that helps to cover the noise. It was not for the neutral clank, it was for a whistling noise that happens in the overdrive gears. T-SB-0186-17
  8. Jul 16, 2024 at 10:43 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry. I don't have it handy, but slapping on some sound insulation works like a champ.
  9. Jul 16, 2024 at 11:07 PM
    BrianKindly
    BrianKindly Bozo
    NE Ohio
    2021 TRD
    MGM 6MT
  10. Jul 16, 2024 at 11:16 PM
    BrianKindly
    BrianKindly Bozo
    NE Ohio
    2021 TRD
    MGM 6MT
    Do you know if they honor that TSB on the latest 3rd gen years or did it stop after 17? Mines pretty loud so I can imagine it has the updated shield.
  11. Jul 17, 2024 at 4:02 AM
    BLtheP
    Plano, TX
    I have a 2021 that did not have any updated shield. I think the TSB was only performed if a within warranty complaint was made. And I don’t know if they ever stretched it into 2018+.
  12. Jul 17, 2024 at 4:58 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  13. Jul 17, 2024 at 6:09 AM
    Sinister184
    Sinister184 Well-Known Member
    23 Tacoma TRD OR 4x4
  14. Jul 17, 2024 at 6:15 AM
    BLtheP
    Plano, TX
    This thread was created because of that noise in the video. OPs fix was to muffle it slightly by adding noise dampening material to the accumulator/slave heat shield. Similarly, Toyota issued a TSB to install a factory dampened heat shield on 2016-2017 trucks that had an audible high pitch whine noise in 5th and 6th gear. Two separate noises, but can similarly be muffled in the same manner. The clank will never truly go away, it is simply due to the design of the transmission. The post is just about trying to muffle it slightly.
  15. Jul 17, 2024 at 6:33 AM
    #35
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    Do any of you find that the noises are loudest when going over bumps at low speeds? Trying to track down a noise in my truck. Thought it was the steering rack but that video sounds pretty similar to what I'm hearing.
  16. Jul 17, 2024 at 6:41 AM
    #36
    BLtheP
    Plano, TX
    Loudest at low speeds due to no road noise to drown it out. Quietest but felt much more in the shifter at road speed due to the severity of the road speed, but don’t hear it as much because it’s under the truck and gets drowned out by the road.
    abou824[QUOTED] likes this.
  17. Jul 17, 2024 at 6:42 AM
    #37
    abou824
    Aidan
    Central PA
    Sweet, gonna try the gasket material then hoping for the best.
  18. Jul 17, 2024 at 9:46 AM
    #38
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Mine never did that and certainly doesn't do it after the clutch line mod 5 years ago
  19. Jul 17, 2024 at 10:18 AM
    #39
    BLtheP
    Plano, TX
    Yours probably does and it just hasn't been noticed. You have to be coasting in neutral. Every manual Tacoma I've been in does it.
  20. Jul 17, 2024 at 10:26 AM
    #40
    Nordicbeast
    Nordicbeast I wanna be sedated...
    '23 TRD Pro 6MT
    I've been wondering what this noise was! I had though perhaps my exhaust was loose and clanging when I went over low speed bumps....gonna try this mod!
