"Normal" 3rd gen manual trans noise fix
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DeeKay20, Nov 7, 2020.
  1. Jul 25, 2024 at 12:49 PM
    #61
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The worst is when you hit a pothole or significant bump right as you go to shift. It will shockload the synchro and grind bad. Happens very rarely, but it does happen.
    abou824 and Toy_Runner[QUOTED] like this.
  2. Jul 25, 2024 at 1:08 PM
    #62
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Rarely? Lol, I'm near Pittsburgh. We have stretches where there's more pothole than intact road.
  3. Jul 25, 2024 at 1:08 PM
    #63
    BLtheP
    Plano, TX
    Rarely that it’s bad enough to cause grinding in a shift. At least for me. The clanking noise from bumps and potholes I hear/feel all the time.
    Toy_Runner[QUOTED] likes this.
  4. Jul 26, 2024 at 8:52 AM
    #64
    Rednecktacoma22
    Rednecktacoma22 Well-Known Member
    Logan, UT
    22 TRD OR 6MT
    Yeah, I actually wasn't active at all last week in the forums so it's my fault. It's not that big of a deal to get back under and do this mod on the shield. I need to remove it again anyway as I forgot the slave cylinder bleed nipple cap. Now I can take care of this and the cap in one go.
    tonered[QUOTED] likes this.
  5. Jul 26, 2024 at 9:06 AM
    #65
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have a nickname of three time tony. So, I can feel that. Haha!
  6. Jul 26, 2024 at 9:32 AM
    #66
    Rednecktacoma22
    Logan, UT
    22 TRD OR 6MT
    If you want it done right, do it yourself.... three times! hahaha
  7. Jul 26, 2024 at 9:38 AM
    #67
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I am cheap though, and know who to blame. Hahaha!
  8. Jul 27, 2024 at 7:57 PM
    #68
    DeeKay20
    DeeKay20 [OP] Well-Known Member
    Danny
    Columbia MO
    2020 Tacoma DCSB TRD OR 6MT
    Dobinsons 2" lift, 33s....other stuff
    Glad this thread is getting some traffic finally.
    abou824 likes this.
  9. Jul 28, 2024 at 5:35 AM
    #69
    BLtheP
    Plano, TX
    I haven’t received my washers yet, so no idea if they will make any difference (they may not since I have a dampened shield), however I did receive the TSB shield and installed it. Very expensive but it for sure works better than my stock shield with the Noico type stuff I added to it. My stock shield with the stuff I added was 12 oz, the TSB shield was almost a pound, right at 15.6 oz. It feels substantial. Installed it yesterday and went for a road trip. Due to the high drivetrain speeds from my regear, the transmission has always had the whine at about 70+. It’s still there but muffled a lot more than it was.
    We’ll see if the washers help muffle it more. This isn’t the same noise as the pothole in neutral noise (though I have that too, I pay attention to it less and try to stay in gear for bumps), but the shield carries all the noises all the same so any improvement in noise muffling should help with all transmission noises across the board.
    So I guess, all this to say I think the TSB shield is nice and a good idea, albeit very expensive. Less messy than the sticky butyl foil stuff I added which is nice.
    abou824 likes this.
  10. Jul 28, 2024 at 5:37 AM
    #70
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    LOL from PA too, this is the truth. The state flower is the orange traffic cone.
  11. Jul 29, 2024 at 6:06 AM
    #71
    BrianKindly
    BrianKindly Bozo
    NE Ohio
    2021 TRD
    MGM 6MT
    I'm going to have left over cushioning washers, as they come in a 50 pack. I imagine that I can get away with throwing 4-8 of them in an envelope and shipping them for the cost of a stamp. So I guess DM me if you'd like to try and throw some cushioning washers on your heatshield and I'll get some your way. We can get some more data on how well the cheaper fix works for different people.
    Do you guys think washers between the transmission and the heat shield will do the trick or will also having washers between the heat shield and bolt head make a difference?
    tonered likes this.
  12. Jul 29, 2024 at 8:08 AM
    #72
    DeeKay20
    Danny
    Columbia MO
    I would do both, want to eliminate as much metal to metal contact as possible.
    BrianKindly[QUOTED] likes this.
  13. Aug 10, 2024 at 11:21 AM
    #73
    BrianKindly
    BrianKindly Bozo
    NE Ohio
    2021 TRD
    MGM 6MT
    Well, I can say adding both made a night and day difference.
    DeeKay20[OP] likes this.
  14. Aug 10, 2024 at 3:07 PM
    #74
    Nordicbeast
    Nordicbeast I wanna be sedated...
    '23 TRD Pro 6MT
    I'm gonna have to do this mod....the rattle/clang is driving me up the wall....
  15. Aug 11, 2024 at 12:45 PM
    #75
    BrianKindly
    BrianKindly Bozo
    NE Ohio
    2021 TRD
    MGM 6MT
    You could start with the washers and see if that eliminates enough noise for you, if not, the sound deadening heat shield can be a back up.
  16. Aug 11, 2024 at 12:59 PM
    #76
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Switch to redline MT90. If you have stock fluid. It doesn’t compare to MT90. Way smoother shifts.
  17. Aug 11, 2024 at 1:03 PM
    #77
    BLtheP
    Plano, TX
    I’ve had about 6 different fluids. It’s not a fluid characteristic, it’s a transmission design characteristic that shows itself only at the exact right time if you happen to shift right as the tires hit a strong bump.
