Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Nov 25, 2019 at 2:35 PM
    Sn4rlax
    Sn4rlax Well-Known Member
    2016 Red Taco 4x4 V6
    already scheduled with Adam, now to wait for my end of year bonus to buy the lift :spending:
    chiefcrunchy, HCJ, BTHawk and 2 others like this.
  2. Nov 25, 2019 at 2:49 PM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    https://www.tacomaworld.com/threads/drive-shaft-lube-points-2nd-gen-4wd.225161/
    @boogie3478 also did a video
    chiefcrunchy and boogie3478 like this.
  3. Nov 25, 2019 at 3:08 PM
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    I keep all of my aux lights covered. But I was wondering about after-market fog lights. They are not going to be routinely covered.
    chiefcrunchy likes this.
  4. Nov 25, 2019 at 3:19 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    I read the statute a few times and it seems they are okay. I'm not sure about the turning off when the high beams are on. Why can't laws be written in normal speech?
  5. Nov 25, 2019 at 3:21 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    If @Truggin plugs them into the stock wiring he should be fine anyways
  6. Nov 25, 2019 at 3:22 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Fo' sho'. Heck I have Baja Designs down there and no one has ever said a word.
    Greg.Brakes.Tacos likes this.
  7. Nov 25, 2019 at 3:50 PM
    Truggin
    Don
    I had moisture in one of my ditch lights, and after being covered for a couple of months, it was gone. So now I just leave 'em covered. They are pleather and zip on and off. I sort of like that I'm not tempted to use them when I shouldn't.
  8. Nov 25, 2019 at 3:51 PM
    Truggin
    Don
    Well, they would turn off when the high beams are on....
    ready6delta and 113tac[QUOTED] like this.
  9. Nov 25, 2019 at 3:53 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    You're probably fine. My Baja's aren't legal and they don't say anything. They typically just care that they go off when high beams are on.
  10. Nov 25, 2019 at 7:22 PM
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
  11. Nov 25, 2019 at 7:25 PM
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    I emailed them just because I don't trust everything I see online. Here is their response.
    "Thank you for contacting the Virginia State Police - Safety Division.
    Section 46.2-1020 of the Code of Virginia allows an L.E.D. light bar to be installed on your truck; however, it must be unlit when traveling on any highway within the Commonwealth of Virginia.
    Highway is defined as the entire width between the boundary lines of every way or place open to the use of the public for purposes of vehicular travel in the Commonwealth, including the streets and alleys, and, for law-enforcement purposes, (i) the entire width between the boundary lines of all private roads or private streets that have been specifically designated "highways" by an ordinance adopted by the governing body of the county, city, or town in which such private roads or streets are located and (ii) the entire width between the boundary lines of every way or place used for purposes of vehicular travel on any property owned, leased, or controlled by the United States government and located in the Commonwealth.
    In reference to the inspection requirements, Section 19VAC30-70-160 of the Administrative Code requires inspectors to inspect for and reject if it meets the criteria outlined below.
    1. The auxiliary lamp is being used for a purpose other than for which it is manufactured or previously approved by the superintendent.
    2. The auxiliary lamp does not have a clear lens.
    3. Any reflector in such auxiliary lamp device is not clear.
    EXCEPTIONS: An auxiliary lighting device that is both covered and unlit shall not be considered for inspection. An auxiliary lighting device that has a clear lens has clear reflectors, and is unlit shall not be considered for inspection. Fog and driving lamps mounted below the level of the regular headlamps must be checked for aim as outlined in subdivisions I 12 h and 13 f of this section if not covered.
    NOTE: The covers shall be a type that would be installed as original equipment and not tape, paper bags, aluminum foil, or similar materials.
    I have provided a link below to Section 46.2-1020 of the Code of Virginia and Section 19VAC30-70-160 of the Administrative Code for you to review.
    https://law.lis.virginia.gov/vacode/title46.2/chapter10/section46.2-1020/
    https://law.lis.virginia.gov/admincode/title19/agency30/chapter70/section160/
    I hope the information provided will be helpful."
    Sergeant Kevin W. G. Satterfield, II
    Department of State Police
    Safety Division - Headquarters
  12. Nov 25, 2019 at 9:00 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
  13. Nov 26, 2019 at 4:36 AM
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    The Light God strikes again. What are your thoughts on the Amber portion?
  14. Nov 26, 2019 at 4:48 AM
    ready6delta
    JACOB
    So now my amber lense covers which have been good are no longer allowed and it should be left clear and off? Who uses amber emergency lights? I thought Emergency is red and blue and amber is for marking and for big trucks to show width and certain points on the vehicle.
  15. Nov 26, 2019 at 4:52 AM
    ready6delta
    JACOB
    Morning ladies, been on the road since 0230. Happy early thanksgiving to all you dirty pirate hookers may your plates be filled and cups never dry!
    Father in law decided to move to a new house starting Nov 1 so this should be an interesting turkey day haha. I might Be moving and building stuff while drunk should be a good time lmao!
  16. Nov 26, 2019 at 5:04 AM
    Superman910
    Eric
    Northern Virginia
    so nothing really new?
  17. Nov 26, 2019 at 5:31 AM
    Rome604
    Dave
    Alexandria, VA
    The way I read it is "Non-SAE" Amber=Illegal (only for inspections).
  18. Nov 26, 2019 at 6:13 AM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    The attempt to decipher the code regarding lights and inspections is an exercise in futility. It's crazy to think you're going to achieve some type of clarity or understanding, especially when it's application is so wildly inconsistent.
  19. Nov 26, 2019 at 6:28 AM
    Truggin
    Don
    We're not looking for clarity or understanding. We prefer obfuscation and confusion.
    And we found it!
    :humble:
  20. Nov 26, 2019 at 6:32 AM
    LocoLocal
    Large American
    That you have!
    Happy Thanksgiving, Don! Plans to go anywhere?
    ready6delta likes this.
