Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Dec 21, 2020 at 7:08 AM
    BSK
    BSK Keyboard not responding. Press any key to continue
    Trabant 501 Kombi
    Cigarette Lighter Delete
    Thats what I understood but need to get some more confirmation.
    Not going to argue here but major disagreement on the above statement. That would be a resume generating event if I see you touch equipment without a grounding strap in my shop. Consider yourself lucky that you have not had a static discharge. Some other engineers here are will most likely agree and tell you the same.
    Rockslide likes this.
  2. Dec 21, 2020 at 7:40 AM
    Rockslide
    Rockslide Well-Known Member
    2019 Cement Tacoma Off Road
    ^^^^ Agreed. It's your system so feel your free to assembly it however you wish, but a static strap is a good precaution and a minor inconvenience when you consider that today's components are more susceptible to static than in the past. I've built all of mine, and on the job, over the years and still use a mat and strap whenever I open a system up.
    BSK likes this.
  3. Dec 21, 2020 at 9:27 AM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    Let me know if anyone is looking for Predator step bars (in great shape). I am prepping for skids/sliders, so the step bars and trd skids are coming off. Family price!
    VABeachTacoTrail likes this.
  4. Dec 21, 2020 at 9:39 AM
    samer312
    samer312 Well-Known Member
    Sam
    Alexandria VA
    2020 Cement TRD OR
    So I'm trying to track down a thunk coming from the rear of my truck that I outlined in this post https://www.tacomaworld.com/threads/thunk-in-the-rear.699671/ As a result I'm trying to find a garage that can check my shocks and perhaps fill them with nitrogen. Anyone have a suggestion for a shop that could do something like this? I don't know any suspension rebuilding places around.
  5. Dec 21, 2020 at 10:02 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What kind of shocks do you have?
  6. Dec 21, 2020 at 10:07 AM
    samer312
    Sam
    Alexandria VA
    2020 Cement TRD OR
    ADS
  7. Dec 21, 2020 at 10:11 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Gotcha, just making sure you don't have oem shocks or something silly. I commented before I read your thread, and just went and read it. That's a very pronounced thud.
    Shock pressure is a fickle bitch because there is such a low volume of gas in there. Just by checking the pressure, a tiny bit bleeds off and can throw off the shocks. I would unbolt the lower shock mounts with the truck on it's own weight. Pry the shock out of the lower shock mount and see if the shock extends on its own. If it does (should take a few seconds to fully extend) then there is pressure in the shocks.
    That would help rule them out with a simple and free test.
    Hafaday and samer312[QUOTED] like this.
  8. Dec 21, 2020 at 10:22 AM
    samer312
    Sam
    Alexandria VA
    2020 Cement TRD OR
    I have the day off so I'll try this out right now. It also just occurred to me that if I disconnect the shock, jump on the truck and the sound goes away I will have found my culprit.
    EatSleepTacos[QUOTED] likes this.
  9. Dec 21, 2020 at 11:46 AM
    samer312
    Sam
    Alexandria VA
    2020 Cement TRD OR
    So it was definitely something related to my shocks because when I removed them the sound went away.
    Shocks were in good working order. I'm gonna chop it up to poor installation because it looked like the base of the shock was rubbing. Upon reinstall the sound is gone.
    Mojo Jojo, Hafaday and EatSleepTacos like this.
  10. Dec 21, 2020 at 12:53 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Boom. I love a simple (and free) solution.
  11. Dec 21, 2020 at 12:57 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  12. Dec 21, 2020 at 1:56 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
  13. Dec 21, 2020 at 4:26 PM
    Tiny's Taco
    Tiny's Taco The Wanderer
    Shenandoah Valley
    2018 Inferno TRD Sport
    That's a horrible idea. What time?
    Thanks for the input. I plan on going steel for cost savings. Unsure on finished or raw and going local for finishing.
  14. Dec 21, 2020 at 4:29 PM
    Tiny's Taco
    Shenandoah Valley
    chiefcrunchy likes this.
  15. Dec 21, 2020 at 4:32 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    IMunsolicitedO powder coat can be so hit or miss, depending on who does it. I would do some research on whoever you decide to have coat it. I’ve seen so many bumpers start peeling and rusting after only 2 years.
    PyritePirateBill likes this.
  16. Dec 21, 2020 at 4:39 PM
    BSK
    Trabant 501 Kombi
  17. Dec 21, 2020 at 5:29 PM
    Mojo Jojo
    Mojo Jojo Well-Known Member
    Mark
    Harpers Ferry, WV
    2020 Pro AG MT, 1997 Land Cruiser
    Tacoma: mid-travel on 33s LC: 3.5” lift on 35s
    Tiny's Taco[QUOTED] likes this.
  18. Dec 21, 2020 at 8:26 PM
    Tiny's Taco
    Shenandoah Valley
    Thanks for the info. There's a shop up here that I was referred to by the local Line-X dealer and Trick Trucks that is supposed to be pretty good. They do in house sandblasting, powder coat primer, and will color match the outer coat. Another friend here said their shop refers to them as well. I haven't talked to them yet, but they seem to have a good reputation. And I may just order if finished and save the hassle.
    Edit: http://www.powdercoatingfccva.com/
  19. Dec 21, 2020 at 8:28 PM
    Tiny's Taco
    Shenandoah Valley
    If that were an affordable option for me right now, I would pursue that instead of modding up the daily driver. But I would imagine that would be a $20k price tag, and I don't need it that badly.
    Mojo Jojo[QUOTED] likes this.
  20. Dec 22, 2020 at 4:50 AM
    virginiamarine
    Northern Virginia
    Toyota did this or a custom shop selling their setup? We all know how our trucks can be mod'd to fit any of our needs, but I don't see how this is different from anyone building an overland rig. I guess I'm not seeing connection between the very sparse article and the setup/title. Seems like click bait for more numbers. lol
