Not happy with my soft rear end..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by akwagon, Oct 5, 2009.
  1. Oct 5, 2009 at 9:18 PM
    akwagon
    akwagon [OP] Alaska Dude
    chris
    alaska
    08 Access 5spd 4x4
    5100, kazktin leather, truxedo
    09 Taco. Access cab 4 banger 4x4. Had rear tsb done. Put Eibach 2" front leveling springs on. Front feels firm, back end now sits exactly level with front (I have a leer 180r canopy on, it weighs prob. 175lbs) When I hit a bump, the front end is firm and the backend cadilac soft. If I put a couple hundred pounds in the bed, I then have a sagging rear, which I just dont like. What is a good option to lift my rear a little and/or firm it up. Shocks? AAL (dont want to gain much height in the rear..) rear 1" blocks... Suggestions..
  2. Oct 5, 2009 at 9:20 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Then get in the gym.
  3. Oct 5, 2009 at 9:24 PM
    akwagon
    chris
    alaska
    08 Access 5spd 4x4
    I know half of these replys will be smartass ones, so I figured I would end those here... :)
  4. Oct 5, 2009 at 9:26 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Aside from Gold's Gym... hit your dealer up for the TSB. Show them your 3 pack part numbers match the TSB for 05-08. Some will do it, if not it's documented, try another dealer, and work with corporate if all else fails.
  5. Oct 5, 2009 at 9:29 PM
    akwagon
    chris
    alaska
    08 Access 5spd 4x4
    I do have the rear TSB, the 4 leaf pack. and yellow/blue bilsteins. Had it done the first week I got the truck..
  6. Oct 5, 2009 at 9:30 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Damn, and you still think it's soft? AAL would be your cheapest route that would also do the job.
  7. Oct 5, 2009 at 9:37 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    Took wilson precisely 2 minutes (120 seconds) to get the obvious smart-ass response in. I just read the thread to make sure somebody did. DAMN you guys are fast. :rolleyes:
    You got your easy answer (not like this topic ain't talked to death on every taco board). AAL or if you want REAL springs go with Dakars.
  8. Oct 5, 2009 at 9:40 PM
    akwagon
    chris
    alaska
    08 Access 5spd 4x4
    If I go with the toytech AAL, will I need longer shocks? I will have 5 total then in the pack.. 4+1=5 (Higher education kicking in) :rolleyes:
    I dont want to have them top out going over bumps....
  9. Oct 5, 2009 at 11:21 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Dude, just reading the thread title had me LOLing...
  10. Oct 5, 2009 at 11:31 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    That's what I was going to suggest.
  11. Nov 21, 2009 at 9:51 PM
    gcwaterski
    gcwaterski Well-Known Member
    I want more lift in the back, and have the rear tsb too. Wondering if I can just throw another leaf in there, or if I have to get a new set alltogether like the Dakars or something. Fatbobsgarage.com has aal's for our truck for CHEAP.
  12. Nov 22, 2009 at 12:06 AM
    akwagon
    chris
    alaska
    08 Access 5spd 4x4
    Supposedly if you have the rear TSB you have to get the addaleaf from toytec as the std one from say fat bobs wont fit
  13. Nov 22, 2009 at 6:49 AM
    gcwaterski
    ah, okay- thanks. Did you go with the toytec aal? Damn it would be so easy, quick and cheap just to throw a spacer back there- I just really don't want to, considering it does NOTHING for load capacity..... I REALLY would like one of those adjustable air helper spring? kits. One that you can control from in the cab. That would be perfect! Expensive, but perfect.....
  14. Nov 22, 2009 at 9:19 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    1 Wilson doe Pilates, he knows ass, you should listen! lol
    2 for offroad a flexible suspension is desired, that really does mean when you add a canopy and say 300 lb, it will feel soft. You could get Deaver springs or equal, they survey you for what is on it and how you use it. "I want to tow... then rock crawl on the week end" they really don't make a spring for that.... detachable sway bars or air bags could be the answer.
    (edit) hey, a photo of you truck plz, I'd like to see it with the 180r on it. I'm Canopy shopping this year.
  15. Nov 22, 2009 at 10:01 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    I was just checking out Hellwig helper leaves on their site.Pretty cheap bolt on.
  16. Nov 26, 2009 at 11:35 AM
    rickabev
    rickabev Member
    Ann Arbor, MI
    06 Taco Sport
    3" Toytec lift Leer Shell Alpine CD w/ Sirius Satellite Polk Audio momo speakers Kenwood 8" powered sub Airlift Airbags at rear with on board compressor with remote control K&N Replacement Filter BFG All-Terrain Tires
    If you want total control of the stiffness, add on airbags. I added them for towing and they are phenomenal. I also have a 3" AAL from toytec, which helped a ton but the airbags with compressor (controlled from inside the cab) means I can control the exact stiffness regardless of the load I have.
  17. Dec 21, 2009 at 6:59 PM
    gcwaterski
    ^^^what kinda air bag/compressor setup ya got? about how much it run ya?
  18. Dec 21, 2009 at 8:03 PM
    Monarch
    Monarch Threadkiller
    Kitchener, Ontario
    09 AC 4X4 2.7L 5 speed SR5 barcelona red
    Readylift, Roadmaster, Bushwacker, Pop & Lock, Redline, Weathertech, Crappy Tire
