Not much down travel on OME setup
Discussion in 'Suspension' started by whitebread, Jul 10, 2010.
  1. Jul 10, 2010 at 3:30 PM
    whitebread
    whitebread [OP] Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    I have the OME 90000 dampers with 885 coils, the 3/4" top plate, and Light Racing UCA's. I noted how little down-travel this setup had when working on my truck a few weeks ago. This morning I was at 4WheelParts getting an alignment and they also stated that I had "almost no down-travel."
    What is wrong here? Do I need dampers with more travel? When manually manipulating the suspension it almost feels like the UCA's are the problem...but it isn't like these are stock. The guy at 4WheelParts said I needed a drop-bracket.
    Any help is appreciated.
  2. Jul 10, 2010 at 3:39 PM
    GEENYUSS
    GEENYUSS Well-Known Member
    Colfax, CA
    1998 TRD Off-Road 3.4V6
    Icons, SPC UCAs, Solo Motorsports LCA, Bilstein 5125’s, All-Pro Exp Leafs, 285/75/16 BFG KM3s
    im sure the spacers dont help, but not sure what else is your problem
  3. Jul 10, 2010 at 10:09 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    stock we only have like 3.5-4" downtravel. every inch of lift takes away at that downtravel. therefore you use 885 coils w/ and extra 0.75" spacers, and your at what 3-3+" up front...do the math and you have nearly no downtravel. make sense?
    if you want more travel w/ lift, you either do spindles (prerunner only), drop bracket like the guy said, or LT...thats all you can do.
  4. Jul 10, 2010 at 10:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Pull the spacer out.
  5. Jul 10, 2010 at 10:19 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Well said, x2
  6. Jul 10, 2010 at 10:23 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    you have about 1" of down travel, the 3/4" spacer is that the physical size or the lift it gives... if its 3/4" size then it gives about 1.5" of lift and therefore you are at about 4" of lift which would therefore mean you have no down travel left.
    I had 885's with 1/2" spacer (physical size) and had about 1" of down travel... thats why I upgraded to a drop bracket lift
  7. Jul 11, 2010 at 7:55 AM
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
    Thank you - that makes perfect sense now.
    It is the 3/8" physical size that ToyTec sells with the kit. Originally I thought it was an OME part being that it was sold with the OME kit, but it is made by ToyTec.
