Not running! Varsity level issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by ecknavy, Nov 11, 2018.
  1. Dec 13, 2018 at 6:23 AM
    #61
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    It looks like the bottom of my BBQ
  2. Dec 13, 2018 at 9:01 AM
    #62
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Yeah, that sludge was BAD. Hopefully that gets taken care of too.
    The other thing is that I can't imagine that ECU's just fry all by themselves.
    If I were you, I'd leave your OBD scanner hooked up all the time. That way, if whatever caused the ECU to fry in the first place rears its ugly head again, you might have some bread crumbs.
    OneWheelPeel and ecknavy[OP] like this.
  3. Dec 13, 2018 at 11:09 AM
    #63
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    I've only heard of capacitors going bad which will happen eventually with electrolytic capacitors since the electrolyte dries up. It would be good if some owners with confirmed bad ECUs took the cover off and did some electrical testing.
    Boatbldr likes this.
  4. Dec 13, 2018 at 4:55 PM
    #64
    ecknavy
    ecknavy [OP] Member
    97 tacoma 3.4 V6 5vz FE 2wd auto
    No wires toasted anywhere that I could find and no evidence of anything wrong with the circuit board when I opened it up, but disclaimer that I'm not an electrician either.
  5. Dec 13, 2018 at 5:01 PM
    #65
    ecknavy
    ecknavy [OP] Member
    I have ordered two cans of the BG EPR(can't find the stuff here on the island) when the cans get here, planning on doing a "flush", twice. Then remove the valve cover and see what's up. It was all very soft and pliable stuff, figure it'll come out. Will update after for more finality. Perhaps I can/should make another post once I've got some conclusion on that one.
    Boatbldr and Nockturno[QUOTED] like this.
  6. Dec 14, 2018 at 5:35 AM
    #66
    Nockturno
    Nockturno Well-Known Member
    2017 MGM Tacoma TRD Sport, DCSB, 6MT
    A new thread would be solid. Thread called " Look who I found in my engine ". GL and keep us posted
    ecknavy[QUOTED][OP] likes this.
  7. Dec 14, 2018 at 7:59 AM
    #67
    tony2018
    tony2018 Well-Known Member
    pics of sludge?
  8. Dec 14, 2018 at 8:14 AM
    #68
    Boatbldr
    Boatbldr Well-Known Member
    Florida
    2002 prerunner
    None
    I was gonna do an ATF fluid run. A member post info on why not to. Ended up using Sea Foam both in gas and oil.
    OneWheelPeel likes this.
  9. Dec 14, 2018 at 8:27 AM
    #69
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    page 2 but you've been warned
  10. Dec 14, 2018 at 8:32 AM
    #70
    Clearwater Bill
    Billy
    Largo Florida
    You dont need magic elixers for soft sludge
    Change the oil/filter with 1qt ATF and the rest dino every 2k for 3 cycles.
    Last change go back to your normal oil of choice and OCIs
  11. Dec 14, 2018 at 9:16 AM
    #71
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Stop recommending ATF. Its an old wisetail like the 3,000mile oil change or Castro and Tupac are hanging out in cuba. ATF has no detergent value and hasn't for a long time. Plenty of products out there DO have detergents and are recommended for such purpose. Even Diesel and Kerosene have more detergent value than ATF.
    I'll make it easy:
    Sticky Lifters? - Dont use ATF
    Loud Valvetrain? - Dont use ATF
    Excess Sludge - Definately Dont use ATF (Especially with the amount the OP has)
    Worn Timing Chain - Dont use ATF
    Piston Slap - Dont use ATF
    Engine Nocking or Humm - Dont use ATF
    ATF is not designed to be used in an Internal combustion engine.
    Grab some Supertech synthetic fir $15 and do 5k oil changes with a $5 filter change. Add seafoam, marvels mystery oil, b12 or any of the other hundred products and add to the crankcase right before an oil change. Idle the car for 20 minutes and change the oil. Boom.
  12. Dec 14, 2018 at 9:24 AM
    #72
    Jon G
    Jon G Hoarding Tacomas one at a time,
    Jon
    St John's Newfoundland Canada
    02, 04 & 07 Tacoma
    Magnaflow 2.5 Catback Exhaust K&N filter
  13. Dec 14, 2018 at 4:55 PM
    #73
    mlcc
    Oregon
    ^^^^^ this
  14. Jun 30, 2020 at 6:35 PM
    #74
    YfwrCwrw1997TT
    YfwrCwrw1997TT Member
    Jon
    1997 Tacoma 4WD
    Here’s a shot in the dark regarding not getting any readings. A Toyota mechanic had problems with mine bc it is California spec(whatever that means; I’m in NC). Anyway, he eventually was able to get scanner data once he had figured that out.
  15. Jun 30, 2020 at 7:41 PM
    #75
    turkeyhunter21
    turkeyhunter21 Well-Known Member
    1998 Supercharged Tacoma 4x4 Limited
    33X12.50-15's and zip-ties.
    Man I had lots of similar things your taking about with my truck wouldn’t run. Smoked. Flooded. Get you some carb cleaner and turn the truck on and try to find a vacuum leak. I had to trace all my hoses and find it. Worth a shot carb cleaner is cheap!
