Not Sure What Happened
Discussion in '2nd Gen. Tacomas (2005-2015)' started by this_is_nascar, Jan 31, 2015.
  1. Feb 3, 2015 at 11:32 AM
    #41
    this_is_nascar
    this_is_nascar [OP] Well-Known Member
    Gloucester City, NJ
    2007 TRD Off-Road
    OK, thanks.
  2. Feb 3, 2015 at 1:15 PM
    #42
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    Could it be wheel bearings?
  3. Feb 3, 2015 at 1:21 PM
    #43
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    They probably knocked a balancing weight off, or they never clamped them down tight when they balanced the tires and they fell off.
  4. Feb 3, 2015 at 4:45 PM
    #44
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Did you actually do any of the suggestions that were mentioned??
    Because your Toyota dealer is probably going to do the same things.
    When you let your tires go that long before rotating them - things seat in, bed in, weather and wear patterns occur. Once you disturb all that - things aren't going to be the same and its not necessarily going to be a ONE time, one thing that fixes it. It could be anything or a combination of things. That's the whole purpose of troubleshooting & testing. To narrow down the problem.
  5. Feb 3, 2015 at 5:07 PM
    #45
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Pretty much everything suggested was already done. While I'm extremely appreciative of all the suggestions, I can't tell you how many times I've explained that the tires were were put back the way they were before the issue occurred. They were only used for maybe 50-100 miles after being rotated. At least twice, I said they were rotated front to back, so the direction in which they rotate has been constant. As stated a few times, I've used Rugged Trails since buying this truck. I'm on my 3rd set, so I think I understand how they work on my truck, as it relates to various tire pressures, performance, etc. Some of the recent suggestions like checking mounts, fluids, bushings, etc will be done on Thursday.
    Again, I can't express enough, my appreciation of everyone's feedback and suggestions. I just hope it's nothing too costly.
  6. Feb 3, 2015 at 5:15 PM
    #46
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    :thumbsup::thumbsup:
  7. Feb 3, 2015 at 6:53 PM
    #47
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I know you said you marked your tires, but are you absolutely positive the tires are in the original position they were prior to your noise? Did you mark the tires the 1st time you had them rotated, and then checked them again on the 2nd rotation?
  8. Feb 4, 2015 at 4:39 AM
    #48
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Yes, they are marked. Actually, it's the rims that are marked, so the only way they were not put back on correctly is if the tires were unmounted and remounted to different rims. I don't expect that to be the case.
    I started this practice several years ago, as one time, I didn't think they actually rotated the tires like they said they did. Ever since, they're marked and documented in a book I have, so I don't forget the most recent positions.
  9. Feb 4, 2015 at 5:39 AM
    #49
    Canufixit
    New England
    When you have the problem, did you out it in neutral and let the engine go to idle to see if it's still there??
  10. Feb 4, 2015 at 8:06 AM
    #50
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Yes, problem was still there. Went from D to 4 and the noise was still there. Then went to N and still there. At a lower speed, went into 4WD-H in D, 4 and N and still there.
    Get suggestion though. I too was trying to determine whether it is a drive train issue or the fact of the tires touching/spinning on the road surface. What I am still looking for is a nice stretch of bridge that has one of the steal grated/see through road surfaces. I figure if I could drive on that and the noise remains, than it's not a "tire to road" issue, if you know what I mean.
  11. Feb 4, 2015 at 8:44 AM
    #51
    moondeath
    Pa, Gardners
    Changing from driving on concrete and black top should change the tune if it's tires.
    How long were the tires rotated before you put them back to their original position?
    Any way you could get some video with the sound. Tire sound and mechanical sound tend to be quite different.
  12. Feb 4, 2015 at 11:25 AM
    #52
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    No more than 50 miles, 100 at the very most, but I'm thinking 50.
  13. Feb 5, 2015 at 4:10 AM
    #53
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Well, I'm checked in at the dealership. They start in 20-minutes. My 1st hope is that they can easily and quickly identify the problems(s). My 2nd desire is that it's not costly. I know, I want allot :).
  14. Feb 5, 2015 at 4:43 AM
    #54
    Canufixit
    New England
    Did the tech take the test drive with you and hear/feel the problem?
  15. Feb 5, 2015 at 5:04 AM
    #55
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    They have not test drive it as of yet. Tech is saying he can see it's the front driver's side wheel/hub/bearing assembly. About 3-hours to replace and almost $800. WTF........
  16. Feb 5, 2015 at 6:01 AM
    #56
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Driver's side is done. Tech reports passenger side is suspect. What a morning.
  17. Feb 5, 2015 at 6:13 AM
    #57
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
  18. Feb 5, 2015 at 8:58 AM
    #58
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Well, I home and the issue seems to be resolved. Had a big vocal disagreement with the Service Writer about the way they charge for labor. In slightly less than 3-hours, they replaced both front wheel/hub/bearing assemblies. Since the book calls for 3-hours for each, they charge labor accordingly @ $180 per hour, I think he said. Through some complaining, I was able to get a few hundred off the bill. Bottom line is slightly less than $1500 total. I can tell it's even better than normal, but haven't taken on the highway yet. That won't happen until this afternoon.
    My next trip in, I'm going to get all those other items serviced (lube U-Joints, check differential fluid, etc), as I didn't have the patience or coin to get them done today.
  19. Feb 5, 2015 at 9:06 AM
    #59
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    $1500 to replace the wheel bearings ?
  20. Feb 5, 2015 at 9:10 AM
    #60
    moondeath
    Pa, Gardners
    x2. Op, are you saying your Toyota dealer charges $180/hr? :eek: That's like Porsche dealer labor rates.
