Not sure what to do on lift.
Discussion in 'Suspension' started by Mxer256, Jul 4, 2012.
  1. Jul 4, 2012 at 11:26 AM
    Mxer256
    Mxer256 [OP] Well-Known Member
    Tyler
    Mississippi
    2012 Prerunner
    2012 Tacoma Trd sport, 10" bulletproof lift with traction bars and icon resi rear shocks, custom headlights and tail lights, 24x14 American force jades,37x13.50x24 Toyo mt, 1" borla wheel spacers, 30" lightbar, new build so more to come come
    Well i was planning on getting some bilsteins and spindles for my 02 prerunner to get about 5.5 inches of lift but i was thinking...Is there any way possible to get eibach coils and bilsteins and crank the shocks to 2.5 and have 5.5 inches of lift that way? Itd probably be too much weight on UCA though so i was wondering if i got some of those then itd be possible? not sure though.
  2. Jul 4, 2012 at 11:32 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    No, it doesn't work like that. When you put A 5100 and adjust it to 2.5" setting, that's how far it will go in height. Plus, if you want to achieve longer than 3" of lift you will either need A spindle (as you mentioned above) or A drop bracket, due to the LCA angles.
  3. Jul 4, 2012 at 11:36 AM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    That makes sense....Thanks for the help
    But is 3 the highest i could go without having to do spindles or DB? I emailed the only company that makes spindles for 1st gen and there 1450!!! Didnt expect quite that high but im still debating on it and just trying to find out some options
  4. Jul 4, 2012 at 2:37 PM
    krimson
    krimson Nothin
    TRD Off Road
    Yes 3" is the highest you can go without A DB or Spindles. Ever thought about just getting an OME lift for roughly 700$ and get 3" of lift? You will get a great ride... 285s with A 3" lift on our trucks look perfect...
