NST Overdrive Pulley set compared to URD 2.8" S/C pulley
Discussion in 'Performance and Tuning' started by bcroach78, May 13, 2011.
  1. May 13, 2011 at 6:01 AM
    bcroach78 [OP] Well-Known Member
    Feb 5, 2011
    2010 Crew cab TRD L/B S/C
    NST claims (dyno sheet to prove it) that their overdrive pulley set for the 2005+ supercharged tacoma's and xrunners will net 1.5psi increase in boost and a total of 341WHP. URD has the 2.8" S/C pulley that they claim will add 1.5 to 2psi of boost. My questions:
    1. Since the urd pulley claims the same amount of boost will it increase your HP the same?
    2. What would be the benifit to spending approx. $500.00 on the NST pulley kit instead of the $100.00 for the URD pulley?
    3. Is it true that the aluminum lightweight pulleys will ease the stress on your engine at a constant speed compared to the stock steel pulleys, giving you more life out of your engine in the long term?
    Thanks for the help.
