Nuno's "Clever name/TIT tle" build thread
Discussion in '2nd Gen. Builds (2005-2015)' started by Cativelense, Jan 20, 2018.
  1. Sep 28, 2019 at 5:59 AM
    #221
    Cativelense
    Cativelense [OP] Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Hmm... Crap! I don't remember. LOL
    But it's definitely stuck in there good.
  2. Sep 29, 2019 at 7:15 AM
    #222
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    Well either way you could open up the switch and see if any of the LEDs are loose. You could also kind of grab the LEDs with your fingers and see if you can shake it loose. Still be gentle with it but that could tell you too.
  3. Sep 29, 2019 at 7:41 AM
    #223
    Cativelense
    Nuno
    CT
    How do I open it? From the back?
  4. Sep 30, 2019 at 9:48 AM
    #224
    nazlax10
    David
    Woodstock, GA
    There's three little tabs that get unclipped on the back side and then the circuit board portion will come out from the back. This is the best example I could find. It's just the slip over style that you pry in between it and the switch body.
  5. Sep 30, 2019 at 10:40 AM
    #225
    Cativelense
    Nuno
    CT
    I'll have to find time one day and take a look.
  6. Oct 25, 2019 at 10:23 AM
    #226
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    On the mods pending list as of today are (updated 3/20):
    - BenWA rear window power kit
    - Blackcat custom gauge
    - @bullaculla trailer plug relocation bracket
    - RAAmat to do the doors and backwall
    - Any time rear view camera button
    Bro! Anytime camera and sound deadener are a must! You can also put you trailer plug away in a much safer spot for free with a hole saw. Custom gauge would be pretty neat, got a link?
    MotoMoose68 and Cativelense[OP] like this.
  7. Oct 25, 2019 at 10:25 AM
    #227
    Cativelense
    Nuno
    CT
    Definitely gotta get to the anytime camera thing, and the sound deadening thing. The problem is, time is at a premium when you have a couple young kiddos.
  8. Oct 25, 2019 at 10:30 AM
    #228
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Deadener will be tough then lol. I cant remember the exact time it took but it was close to a week and like 30+ man hours. Almost impossible to do if you dont have a 2nd rig for the week. That way you can leave the entire interior stripped out. Camera was 2 hours max, much cheaper too, i think $60 bucks. Probably much faster since you already know how to pull the dash apart.
  9. Oct 25, 2019 at 10:31 AM
    #229
    Cativelense
    Nuno
    CT
    DANG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! You figured the sound deadening would be time consuming, but reading that puts it into more perspective.
    We'll see what happens, and when...
    LOL
  10. Oct 25, 2019 at 10:33 AM
    #230
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Good luck brother. Nice to see your truck progress. I think I'm even going to steal the gauge cluster idea!
  11. Oct 25, 2019 at 10:39 AM
    #231
    Cativelense
    Nuno
    CT
    Go right ahead! That's another thing I still need to put on... DOH!
    But a bit scared of the process because of having to pop up the needles.
  12. Oct 25, 2019 at 10:42 AM
    #232
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Its a piece of cake dude. I pulled out the damn annoying door buzzer a few years ago and I had to pull the cluster apart and its very straightforward. Perfect time to kill that buzzer too since you are already in there
  13. Oct 25, 2019 at 10:45 AM
    #233
    Cativelense
    Nuno
    CT
    Nice! I gotta find time for that as well then.
    Maybe I'll try and tackle it when I take a few days off here and there to burn through the vacation time I need to use before the end of the year.
    kgarrett11[QUOTED] likes this.
  14. Oct 25, 2019 at 11:11 AM
    #234
    NoFear9491
    NoFear9491 Well-Known Member
    Jeff
    Boston, MA
    2015 Magnetic Grey Tacoma AC
    Small stuff but not for long!
    Where did you get the small center switches?
  15. Nov 26, 2019 at 6:49 AM
    #235
    Slothmeyer
    Slothmeyer Member
    Jakob
    2012 Tacoma trd sport
    Wheels and tires
    Dude your truck is badass
    Cativelense[OP] likes this.
  16. Nov 26, 2019 at 6:51 AM
    #236
    Cativelense
    Nuno
    CT
    LOL
    Far from that, but thanks anyway!
    :thumbsup:
  17. Jan 26, 2020 at 5:16 AM
    #237
    jslawsby
    jslawsby New Member
    Jonathan
    2014 DCLB Sport
    Couple of questions (sorry they are from such an old post but just bought a 2014 and joined Tacomaworld). I found the listing for most of the black out parts, but I didn’t see the instrument cluster front and the tweeter surrounds. Also, do you have links for the parts in your headlight set up? Thanks for any help.
  18. Jan 26, 2020 at 7:16 AM
    #238
    Cativelense
    Nuno
    CT
    The cluster surround and tweeter surrounds I just removed and painted black. This link shows how to remove the instrument cluster ring:
    https://www.tacomaworld.com/threads...t-interior-parts.449999/page-26#post-13229954
    For the tweeters, you have to remove the door panels, and then break off the tweeter ring since it's not clipped on, and then glue it back in place.
    For the headlights... sorry, don't have a parts list. I bought them from someone who makes retros, and I just kinda told him what I wanted, and then he built them. If you're interested in a set, there are a few members on here that build and sell, and do an awesome job. @hyper15125 and @LSC15 are a couple, and I've seen a tons of pics of their stuff. Looks bad ass!
    Hope that helps.
  19. Jan 26, 2020 at 7:32 AM
    #239
    the_black_tacoma
    the_black_tacoma Well-Known Member
    Griffin
    IN
    2008 Black Tacoma SR5 AC
    A couple
    :thumbsup:Nice thread. Subbed.
  20. Jan 26, 2020 at 7:32 AM
    #240
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Thanks buddy. Bout to have a blacked out slightly used set up from sell in a couple weeks for 12-15 model. Or you could always place a order for exactly what you want
