Nut is off my rear shock, what can I do tonight about it? Need help fast.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ERdept, Nov 20, 2008.
  1. Nov 20, 2008 at 5:49 PM
    ERdept
    ERdept [OP] Well-Known Member
    I was inspecting the underside of the Taco, with the Toytec 3 inch lift and springs in the rear.
    The nut and washer are off of the bottom shock absorber and only the bolt is in, held in place by tension of the suspension.
    It's 7 pm here and I have no idea how long I have driven it like this, so it may be safe to drive to work tomorrow. Or it may have just happened and I'm living on borrowed time.
    But, what size is the nut and washer?
    What can I do tonight, all parts stores are closed and the dealer is closed.
    Is is safe to drive to work (15 miles of freeway)?
    Need help so I can sleep at least.
  2. Nov 20, 2008 at 5:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You will be fine. The suspension will still cycle like it should, but if the shock falls out, you will have no dampening on that side. If it were me, and I am not responsible in anyway for your actions, I would remove the shock, just incase it were to just dangle and get beat up by the springs, to save any damage from occuring to it. Vehicle handleing may be impared a little nit, as I mentioned, no more dampening on that side. Get a new bolt, nut, and washer in the morning. I have some friends that have pullered their shocks off the frame, only to have to drive home (75 miles) and do the repair. If they can drive without a shock, Im sure you can. :)
  3. Nov 20, 2008 at 6:03 PM
    Clipper
    Clipper Western Alliance: Sierra's
    Sacramento
    '06 Taco 4X4
    this happened to me when like a dumb A++ i didnt double check the bolt tightness on the shocks i installed on my last truck. when i saw mine it was hanging there about to fall off completely. what i did is found a large washer and nut that fit (from the garage) and put it back together. not the exact washer that came with the shock but it worked for me.
    This is just what i did, not recommending it, im not responsible in any way for your actions.
  4. Nov 20, 2008 at 6:38 PM
    moserjjx
    moserjjx Tacoma Newbie
    Eau Claire, WI
    08 DC TRD 4x4
    Weathertech liners, bed mat, rear spring TSB, extra 12V outlets in center console, seat belt chime off
    i don't think it will fall off. try pulling on it a little and i doubt it will move much. I wouldn't worry about it and even if it does come off it won't do much but bounce the heck out of you
  5. Nov 20, 2008 at 7:35 PM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    Donahoe (Icon) C/O, TC UCA's, Dakar leafs, BilStein 5125's, 285/70/17 BFG MT KM2's, Raceline Renegade 17x9's, u-bolt flip kit, debadged, TRD CAI, TRD exhaust, URD MAF controller, 20% front window tint, 3M clear bra on bumper, cam locks in all storage compartments, fog light mod, Alpine X100 deck, Co
    Lowe's or HomeDepot is still open. Take the bolt out and head to the loose nut and bolt department.
    If you can't make it, inspect the threads on the bolt. If they look pretty clean, chances are the nut just came off, if they look dirty, or have a lot of road grim on the threads, chances are you lost the nut a long time ago and you will definitely be ok.
    The last thing I would do is remove the shock and drive on the freeway, that is a definite NO-NO!
  6. Nov 20, 2008 at 8:04 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Is this the front shock or rear?
    If its a front shock/strut, I WOULD NOT drive it without a nut on it.
  7. Nov 20, 2008 at 8:30 PM
    ERdept
    Its the rear shock. OK i'm relieved that it wont pop off and cause me to swerve off the road.
    I did go to Home Depot but think it's a metric. It looks close to a half inch.
  8. Nov 21, 2008 at 4:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X100! :eek:
  9. Nov 21, 2008 at 7:04 AM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    they ahve metric at home depot in the drawers......so you should find it......but i would not worry about it. just wait to get the right nut and washer.
    if you are concerned....put some weight in ur bed for the ride.......the weight will put some more tension on the shock and that bolt will not budge
  10. Nov 21, 2008 at 8:21 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    I know this is late and the poster has already rectified the situation but......Got some vice grips or Duct Tape? Put the vice grips on the thread side of the bolt so it can't slide out. If you have duct tape you can wrap it over the thread end close to the shock to build up the thread so it can't slide out too. Then do a quick wrap around the shock end to seal the deal.
    I was a crew chief on fighters. I had just as many full landings as I had take-offs. ;)
    It took a college education to break it but a high school diploma to fix it!!!
  11. Nov 21, 2008 at 12:33 PM
    moserjjx
    Eau Claire, WI
    08 DC TRD 4x4
    hopefully duct tape wasn't used as a fix on too many fighters!! :)
  12. Nov 21, 2008 at 2:13 PM
    TicTacOma
    Columbia,SC
    Hopefully? You just keeping thinking that and stick to the topic....
  13. Nov 21, 2008 at 3:27 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    Then you HAD to be air force. ;)
  14. Nov 21, 2008 at 3:54 PM
    TicTacOma
    Columbia,SC
    The AirForce? Aircraft? Hmmmm....you must be a detective!
  15. Nov 21, 2008 at 4:27 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    I'd replace it!! Wouldn't you???
  16. Nov 21, 2008 at 5:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO!!
    This DOES WORK!
  17. Nov 22, 2008 at 4:26 AM
    TicTacOma
    Columbia,SC
    He was looking for a "Band-Aid" fix.....temporary, limp mode, gotta get back to civilization type repair. He wasn't gonna keep it that way.
    Ya gotta read the whole thread, not just the last two posts. That's how things get lost in translation.
    (Thank you Chris...)
