Nut size on shock mounting kit
Discussion in 'HeadStrong Off-Road' started by Thyces, Sep 27, 2016.
  1. Sep 27, 2016 at 7:15 AM
    Thyces
    Thyces [OP] 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    I installed the mounting kit and shocks last weekend and during install one of the threads in one of the nuts completely fell apart. I need to replace it with a grade 8 nut. Just need the size. Thanks
  2. Sep 27, 2016 at 7:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    Which nut exactly?
  3. Sep 27, 2016 at 7:29 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Sorry, should have specified. One if the three bolts that holds the shock to the upper mount. The one on the lefttmp_9127-20160927_1028321903441858.jpg
  4. Sep 27, 2016 at 7:45 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Take one of the good nuts to the hardware store...
  5. Sep 27, 2016 at 7:46 AM
    98tacoma27
    Ben
    Not Beech Creek
    M10 - 1.25
  6. Sep 27, 2016 at 7:51 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Thanks
  7. Sep 27, 2016 at 11:39 AM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thanks 98tacoma27
    Sorry for the slow response Thyces, we are currently playing catch up. The Mod is correct on the nut size, they are a Flange Hex M10-1.25. We have never had a failure with these, they are Dorman brand though if interested.
    If you have any other questions let us know.
    98tacoma27 likes this.
  8. Sep 27, 2016 at 11:46 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Thanks Marie. I think it must have been a bad one that slipped through quality control. The threads just snapped clean off. I was using a torque wrench so I know I didn't over torque it. Not a big deal though I'll just stop by a hardware store and grab one. Thanks again
  9. Sep 27, 2016 at 11:56 AM
    HeadStrong Off-Road
    Anytime!
  10. May 20, 2023 at 9:26 AM
    Kain78818
    Kain78818 Member
    Seth
    2019 Toyota Tacoma SR5 4D Exbed
    Bilstean TrD package on rear
  11. May 20, 2023 at 9:27 AM
    Kain78818
    Kain78818 Member
    Seth
    I'm having the same problem but with the nut on the top.. Literally about to cut the nut off so I can get the strut out. I just need to know what size the nut on the top is.. So I can go buy it
