NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. Jan 11, 2012 at 2:15 PM
    #341
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    they're remanufactured....they take the factory cores, clean up the splines, regrease and boot them with their boots...so the steel and main structure is factory strength, only loss is with the boots...
    i got 97000 on my axles before i had my passenger side boots start to leak, haven't busted open, but are definitely leaking..CVJ states their boots are better than other aftermarket boots out there but all aftermarket boots are not as durable as the factory, but they are more flexible (factory uses a harder compound than aftermarket boots)..
    the average life on these aftermarket boots run around 50k...these guys also warranty their axles, so if i bust one up somehow, i can bring it back to them for a new axle under warranty..
  2. Jan 11, 2012 at 2:32 PM
    #342
    NYCO
    bOb
    Colorado
    dents & scratches
    for future reference....
    front
    N140S - 15.90” closed 21.30” open 5.4" travel
    rear
    OME N182 - 13.85” closed 23.93” open 10.08" travel
  3. Jan 11, 2012 at 5:24 PM
    #343
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    I was surprised that a toyota dealership recommended CVJ axles over a stock replacement. They must be good quality even with the reused parts. Definitely going to pick up 1 or 2 before moab.
    Do remember the price per cv? I forgot :p
  4. Jan 11, 2012 at 6:26 PM
    #344
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    Only thing id say to add with what BOB said would be their boots have less fins, which makes it less likely the fins touch. the less the fins touch the less chances u have that the fins wear and break open. I love mine.
    And absolutely we recommend them. WE see them almsot everyday and they take great care of our customers. I as a tech always give the customer the option of reboot with oem parts or replace completely with CVJ. 98% of the time CVJ is chosen and never had a problem. LIke i said i love mine. I believe they are around 75 a piece...
  5. Jan 12, 2012 at 7:52 AM
    #345
    NYCO
    bOb
    Colorado
    dents & scratches
    yea they are 75/axle but he hooked me up with shop price (thanks jace), so idk what they normally run
  6. Jan 12, 2012 at 9:26 AM
    #346
    NYCO
    bOb
    Colorado
    dents & scratches
    no problem...talk with steve over there if you can..he's been very helpful with the process
    they also offer an off-road silicone based boot for the inner boot, but with our lifts the application was not beneficial/necessary...
  7. Jan 12, 2012 at 10:10 AM
    #347
    lotsoftoys
    Jace
    Denver
    bunch of crap
    if talk to them tell them u heard about it from Jace or BOB on a forum you are on. maybe theyd be interested in becoming a dealer on here?
  8. Jan 12, 2012 at 10:27 AM
    #348
    NYCO
    bOb
    Colorado
    dents & scratches
    not a bad idea....
  9. Jan 12, 2012 at 7:56 PM
    #349
    n0rth
    n0rth Well-Known Member
    J.W.
    Idaho
    09 Tacoma 4X4 SR5
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    GB? Where is JLink at?
  10. Jan 13, 2012 at 7:16 AM
    #350
    NYCO
    bOb
    Colorado
    dents & scratches
    great suggestion for an alternative way into moab from grand junction area...
    adds 1.5hr to the drive, but is slightly less in mileage (8m)...
    through gateway
    http://g.co/maps/3ed3a
    normal
    http://g.co/maps/ukpgt
  11. Jan 13, 2012 at 7:33 AM
    #351
    NYCO
    bOb
    Colorado
    dents & scratches
    curious to see how this turns out...
    is he a group buy master?
  12. Jan 13, 2012 at 9:16 AM
    #352
    n0rth
    J.W.
    Idaho
    09 Tacoma 4X4 SR5
    Seems like it he did a good job with the Trasharoo GB and I could use more CV's even though I have 2 spare OEM's currently not on the truck and am running the Cardone CV's which are holding up really well.
  13. Jan 13, 2012 at 3:10 PM
    #353
    NYCO
    bOb
    Colorado
    dents & scratches
  14. Jan 14, 2012 at 11:42 AM
    #354
    NYCO
    bOb
    Colorado
    dents & scratches
    got the new axles in today. while it was up on the lift we also put in new coolant, tranny fluid and greased up the drive shafts...
    unfortunately noticed that my lower ball joint is showing signs of old age and are now on the summer to-do list...
    but the truck is approaching 99k on the odometer (really closer to 110k due to the larger diameter tires that have been on since 25k and no speedo recal), and the parts have been holding up very nicely i must say...
    new cvjs waiting to go in..
    reason why the new cvs got put in...passenger side inner boot throwing out some guts
  15. Jan 20, 2012 at 7:46 AM
    #355
    NYCO
    bOb
    Colorado
    dents & scratches
    went ahead and got the allpoo ubolt kit...$49.99 isn't too bad and i doubt i'll have any issue with it...holding off on the bumps until i can take some flexing measurements, definitely not going through allpoo for those!...going to be getting some billies in the rear to replace the old ome's i have...thinking 5150s
    for shock reference...
    http://www.bilsteinus.com/uploads/tx_templavoila/Bil_OffRd_Cat2011_05.pdf
    http://www.eshocks.com/bil_Orgd.asp
    5150 stem mount conversion kit
    part # 192228
    part # - descr - travel - col. length - ext. length - valving
    25-101966 - 10" 5150 Crossflow - 10.02" - 15.89" - 25.91" - 175/60
    25-186307 - 10" 5150 Crossflow - 10.02" - 15.89" - 25.91" - 255/70
    25-186314 - 11" 5150 Crossflow - 11.50" - 16.50" - 27.99" - 175/60
    25-186277 - 12" 5150 Crossflow - 11.93" - 17.78" - 29.70" - 175/60
    25-101874 - 12" 5150 Crossflow - 11.93" - 17.78" - 29.70" - 255/70
    5165 stem conversion??????
    5165 Reservoir Frame Mount Kit: B4-KT2-Z009A01
    25-187700 - 11.3" - 5165 Reservoir - 11.3" - 16.1" - 27.4" - 170/60
    25-187717 - 11.3" - 5165 Reservoir - 11.3" - 16.1" - 27.4" - 255/70
    25-175783 - 11.6" - 5165 Reservoir - 11.6" - 16.9" - 28.5" - 255/70
    25-187731 - 13.1" - 5165 Reservoir - 13.1" - 17.9" - 31.0" - 170/60
    25-187748 - 13.1" - 5165 Reservoir - 13.1" - 17.9" - 31.0" - 255/70
    5150s
    $109.99/ea http://downsouthmotorsports.com/i-135589-bilstein-5150-series-performance-shocks.html
    $111.99/ea http://www.4wheelparts.com/Lift-Kit...t_s=90&t_pt=10503&t_pl=5984&t_pn=BIL25-101874
    5160s
    $359.99/set (pay attention to part # if order) http://www.toyteclifts.com/index.ph...tegory_id=117&option=com_virtuemart&Itemid=72
    part #25-177343 col. 13.84 ext. 23.23
    5165s
    Fox info...
    http://www.foxracingshox.com/filter...t=shocks&year=2005-2011&position=Rear&m=truck
    http://www.foxracingshox.com/dl/truck/fox-or-truck-cat-lores.pdf
    model comparisons http://www.offroad-engineering.com/fox-shocks.html
    fox 2.0s wo resi
    $148.50/ea http://downsouthmotorsports.com/i-1...es-emulsion-smooth-body-shocks-5-8-shaft.html
    $165.99/ea http://www.4wheelparts.com/Lift-Kit...0&t_pt=10503&t_pl=100360&t_pn=FOX980-02-038-A
    fox 2.0s w resi
    $198/ea http://downsouthmotorsports.com/i-8...ir-smooth-body-stem-top-shocks-5-8-shaft.html
    bump stop info..
    wheeler measurements and discussion..
    $50 front, $125 rear (on backorder)
    http://www.tacomaworld.com/forum/wheelers-off-road/67293-wheelers-super-bumps-3.html#post2845880
    http://www.wheelersoffroad.com/05uptacomasuperbumps.htm
    Front suspension (new OME shocks, keep 886 coils, add 10mm kit)
    $145/side
    http://www.wheelersoffroad.com/05upometaco.htm
    Front Suspension:
    Camburg 1.25" Uniball UCAs ordered
    10mm enhancer kit ordered
    Rear Suspension:
    All-pro U-Bolt Kit waiting to be installed
  16. Jan 20, 2012 at 8:25 AM
    #356
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup
    A few bolts are different.
    what brand cvs?
  17. Jan 20, 2012 at 8:43 AM
    #357
    NYCO
    bOb
    Colorado
    dents & scratches
    CVJ.... http://www.cvjreman.com/
    company out of denver who remans factory cvs..
    "To ensure you a Quality axle CVJ:
    -Uses high quality grease and balls
    -Only reuses components with insignificant wear
    -Inspects splines and threads on all axles
    -Straighten bars to a standard twice as accurate as the industry
    To prevent leakage and dripping CVJ:
    -Uses top quality Neoprene boots
    -Polishs all seal surfaces"
    so they have factory meat with neoprene boots, new grease and balls...stronger than the other aftermarket cvs seems how they use factory steel which is better than the chinese made crap
    PSU is trying to get a group buy going with them now..
    http://www.tacomaworld.com/forum/group-buys/198278-feeler-cvj-axles-group-buy.html
  18. Jan 20, 2012 at 9:29 AM
    #358
    Dark Knight
    Jeff
    NC/SC
    yeah they look good. Is it an upgrade to get the boots you got? They look like they are for high angle?
  19. Jan 20, 2012 at 2:25 PM
    #359
    NYCO
    bOb
    Colorado
    dents & scratches
    they are comparable to stock...same # of fins and similar spacing..
    the factory boots are a harder compound which leads to high average mileage life than these...but these still have an average life of 50k+ which is not bad...i got 100k+ actual miles out of these...
  20. Jan 20, 2012 at 4:30 PM
    #360
    Dark Knight
    Jeff
    NC/SC
    Right, I hear ya man. 110,xxx on mine and they are about to explode.
