O/D button an ECT button.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pyro, Sep 29, 2010.
  1. Sep 29, 2010 at 1:55 PM
    Pyro
    Pyro [OP] Well-Known Member
    Jon
    Garden Grove, Ca
    01 PreRunner
    Camburg Arms, Icon Coilovers, ProComp 9000 rears, Big Foot all-terrains, KNN Intake, Flowmaster,
    So is it good to have them both on or both off? or one on and one off?
    what would be better for onroad and what would be better for offorad?
    -JB
  2. Sep 29, 2010 at 1:59 PM
    tacoma92
    tacoma92 Black Hole Sun
    Forrest
    Gulf Shores, Alabama
    09 SR5 Toyota Tacoma
    I dot kno bout both on at same time but o/d is better on highway w gas mileage w wat I've heard.
  3. Sep 29, 2010 at 2:04 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Use both. The ETC electronically holds each gear to a higher RPM before upshifting and the OD is just that. If you want slightly better mileage, leave the ETC off and the trans will upshift to the high gear asap unless you are a leadfoot.
  4. Sep 29, 2010 at 2:06 PM
    Pyro
    Jon
    Garden Grove, Ca
    01 PreRunner
    so for better on-road performance keep the ETC button off and the O/D off?
    And for better off-road performance then have both on?
  5. Sep 29, 2010 at 2:14 PM
    Ridgerunner
    Frank
    San Francisco
    For normal point A to point B driving I would have OD on and ETC off. These are things you can play with as the situation calls for. For example, freeway onramps call for ETC on. High-speed freeway calls for OD on. Around town with some hills calls for OD off and ETC off to save gas and provide a little engine brake on slight downgrades. In all it is all about what feels right for your driving style and situation.
    Offroad I would have OD and ETC off and work the gearshift manually as needed.
  6. Sep 29, 2010 at 2:18 PM
    Ridgerunner
    Frank
    San Francisco
    The tranny will kick out of OD if you step on it-it will still hunt gears. Matter of fact the ETC tends to cause the tranny to over-downshift on the freeway because its intention is to provide higer RPMs. I leave the ETC off on freeways so the tranny stays in higher gear more.
  7. Sep 29, 2010 at 2:21 PM
    Pyro
    Jon
    Garden Grove, Ca
    01 PreRunner
    So wouldnt it make more sense if my O/D is off with the ETC button on while offroading? Making higher rpms wouldnt better ?
    and for the onroad keep the OD on and the etc off correct? Im guessing that would lower the rpms.
  8. Sep 29, 2010 at 2:39 PM
    Ridgerunner
    Frank
    San Francisco
    IMO you really don't want high RPMs offroad-you want to actually control wheel slippage so ETC off. On road I already explained above:) and like I said before it is all about what feels right to you at that moment.
    Example-engage ETC as you enter an onramp for better gain of speed. Once you are at speed-turn it off so the tranny holds top gear better for mileage.
  9. Sep 29, 2010 at 5:14 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Always turn the overdrive switch on for better fuel economy and quieter driving...If the engine coolant temperature is low, the transmission will not shift into overdrive gear even with the overdrive switch on...
  10. Sep 29, 2010 at 5:25 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    ECT or "Power" mode is for a more powerful acceleration...Toyota recommends leaving it off to improve fuel economy...
  11. Sep 29, 2010 at 5:27 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    :God I love manuals :anonymous:
    snowgoose likes this.
  12. Sep 29, 2010 at 5:46 PM
    fireman_343
    fireman_343 Ultimate TRD
    Brian
    Columbus, OHIO
    05 TRD Dlb Cab
    Viper Alarm, XD Series Wheels, Pioneer touch screen radio/nav system.
    I like the way the tranny shifts with the power button ON! But, I've found with it ON, I get about 2 mpg less!
    So, I leave it off unless I need to get up to speed real fast, it does help a little!
    OD is always ON! Unless I've got a trailer behind me, or if the tranny keeps downshifting out of OD on hilly freeways!
