O-Ring Fell Out During Diff Oil Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by foy1der, Oct 20, 2024.
  1. Oct 20, 2024 at 9:09 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Sure doesn’t look like one in the photo. The o-ring is on the outside of the axle assembly and goes around the cast in lip that the bearing rides on. Essentially being sandwiched by the bearing and housing with no way to make it into the diff.
    T4R_hereforbearings likes this.
  2. Oct 20, 2024 at 9:10 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Oh, it is definitely not a "round" section O-ring, or a part of the pinion seal, as mentioned it would never make it through the bearing. Breaking off the axel seal in such a picture-perfect condition is low on the possibility list too; but has to be considered. I was going to mention earlier all the people who report metal in their first diff oil change, but decided I did not wish to open another can of worms. A piece of rubber left over is of no concern, unless it is a part of an axel seal.
    It would be great if someone had an axel seal and measured the diameter of the inner area and supplied that to the OP and he could see if the parts measure up.
    Your picture supplied in post #18 is what I was referring to in my post #4. Glad you found it.
  3. Oct 20, 2024 at 9:10 PM
    MGMDesertTaco
    You'll find out real quick, like within a few hundred miles of driving if the part was needed or not. :rolleyes:
  4. Oct 20, 2024 at 9:16 PM
    BLtheP
    Plano, TX
    Inner diameter of a wheel seal is about 2.25”. So there is a start for measuring. Hard to say what it could be, the appearance of that part just doesn’t match anything I can think of in the entire rear axle assembly. If a piece of a seal did break off, I’d think gear oil would be leaking out rather quickly.
  5. Oct 20, 2024 at 9:22 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I agree there is no way the hub assembly o ring could get inside the axle tube and make its way to the pumpkin.
  6. Oct 20, 2024 at 10:27 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    How many miles are on it?
    What's the diameter of that piece...assuming it's round....maybe part of the oil seal that migrated into the diff?
    Is there oil leaking at the brake backing plate?
  7. Oct 20, 2024 at 11:47 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
  8. Oct 21, 2024 at 7:36 AM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    If it's the o-ring that goes between the outer flange and the brake backing plate, it would sit on the outside of the flange lip so there would no way it could migrate into the diff. Perhaps it was there since manufacture.
    Toycoma2021 likes this.
  9. Oct 21, 2024 at 11:42 AM
    Toycoma2021
    Ok, the OP now has the information to make a determination. In any case it has not damaged the diff gears or bearings.
  10. Oct 21, 2024 at 4:15 PM
    foy1der
    foy1der [OP] Well-Known Member
    W1FOY
    2017 OR DCLB
    163k miles. This is my second rear diff fluid change. First one was quite normal.
    I didn't drive it today, and I won't drive it tomorrow. It's too nice to not take the motorcycle to work.
  11. Oct 29, 2024 at 12:07 PM
    foy1der
    W1FOY
    2017 OR DCLB
    My rear end locked up this morning. The dealer wants 3200 to replace the rear axle seal and all the associated parts on the passenger side.
    That MAY have been an important o-ring.
    More to come once they tear into it.
    usmc2msu likes this.
  12. Oct 29, 2024 at 12:28 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Wow, an interesting turn of events. Keep us posted
    thomasburk likes this.
  13. Oct 29, 2024 at 12:40 PM
    MGMDesertTaco
  14. Oct 29, 2024 at 12:52 PM
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    Agreed also. I’ve been back there a lot and that rubber piece that came out is extra. It could be some RTV gasket maybe?
    they want HOW MUCH? so was it low on fluid or was it fine when you drained? Looks like someone put that in there on purpose honestly. Very sad if so.
  15. Oct 29, 2024 at 3:15 PM
    #35
    foy1der
    W1FOY
    2017 OR DCLB
    I'm the only one that ever changed the diff fluid. I never used RTV or put anything other than the appropriate diff oil into the rear end. I drained 3 to 4 liters of oil out of the diff before putting in fluid up to the bottom of the fill hole. The only thing I could think is that the suction from the gallon of fluid sucking out the bottom of the diff pulled the oring from its seat.
  16. Oct 29, 2024 at 3:23 PM
    #36
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    Why go dealer to fix rear axle? You did not find any outside shops do rearend work?
  17. Oct 29, 2024 at 4:09 PM
    #37
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Why go to the dealer when you're so far outside of warranty? You could've gotten complete axle assys from salvage yards for less thru Car-part.com.
  18. Oct 29, 2024 at 4:17 PM
    #38
    MGMDesertTaco
    From my experience it's very difficult to find a competent axle/diff mechanic. Find a reputable shop with good reviews. It doesn't have to be a dealer.
    Also, do frequent fluid changes after a few hundred miles. You'd be surprised how much debris is floating around after a rebuild.
    Last time I paid to have an axle rebuilt at a dealer it was around 2500 with labor. (4th gen ls1 Camaro.) I could have bought a whole new aftermarket axle for that from moser or strange engineering.
    STEELeR43 likes this.
  19. Oct 29, 2024 at 4:41 PM
    #39
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    People crash these trucks every day, you can get a replacement axle assembly much cheaper than what the dealer quoted for the repair.
  20. Oct 29, 2024 at 4:57 PM
    #40
    foy1der
    W1FOY
    2017 OR DCLB
    Thank you all for trying to so desperatly protect my paycheck. I most sincerely appreciate it.
    I need it fixed now, not after I pull an axle from a junk yard and spend half a weekend messing with it.
    thomasburk and usmc2msu like this.
