O2 (Air/Fuel Ratio) Sensor Replacement, Bank 1 - 5VZ-FE, w/ Manual Transmission
Discussion in '1st Gen. Tacomas (1995-2004)' started by SwampYota, Aug 30, 2016.
  1. Oct 26, 2021 at 1:55 PM
    Jimmyrace
    Jimmyrace Well-Known Member
    JR
    Louisville, KY
    Betty '03 Taco MTM Xtra-cab DLX 5VZFE
    OME struts / springs / leaf pkg :: SPC upper A ::
    doing this now - just unscrew it & it slides right off
  2. Oct 26, 2021 at 6:15 PM
    LSUdude
    LSUdude Active Member
    1999 Tacoma trd
    My connecter was accessible without lifting cover off transmission
  3. Mar 23, 2022 at 2:31 AM
    Milkman14
    Milkman14 Well-Known Member
    2004 Toyota Tacoma 3.4L 4x4 M/T
    I got a CEL (code P0031) and was told to test my O2 sensor. I put my multimeter on the two black wires (for the heater?) and got a reading of 13 ohms. On the other two wires (blue and white I believe) I got an open reading. Can someone tell me what exactly this means? I am assuming that I need to replace it. Thanks
  4. Mar 23, 2022 at 4:30 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    I think you're reading Volts not OHMs.
    Advanced multimeters will auto switch if the operator is clueless.
    Heater resistance should be .8 to .13.
    Reading 0 ohms is below .8 which indicates heater circuit failure, short in wiring or sensor relay failure/short.
    Replacement B1S1 for your Taco is
    DENSO 234-9003
    DO NOT BUY IT ON Amazon or eBay
    Amazon does offer Genuine Toyota DENSO FROM AMAZON and ones supplied from others. Choose the the genuine supplied by Amazon if you can only buy online. Price varies from $89 to $149.99 don't cheap out on B1S1
    https://densoautoparts.com/find-my-part.aspx
  5. Mar 23, 2022 at 5:15 AM
    Milkman14
    Thank you and thanks for the response. I was following this video for testing it:
    https://m.youtube.com/watch?v=_Kr-c8eBl5E
    I am fairy certain I was reading ohms. When I tested black to black I got resistance and when I tested white to blue it read open circuit. I don't know if this provides any new information to you, but I will purchase it OEM if it needs to be replaced. Thanks for the link.
  6. Jul 11, 2022 at 10:11 PM
    Chris311
    Chris311 Well-Known Member
    1999 White Tacoma SR5 V6 TRD OR 5 speed M/T
    3" OME lift, SPC UCAs, URD Crankshaft pulley (the red gives more HP)
    Hello, sorry to bump an old thread, but I wanted to get some help with selecting the correct sensor.
    I have a 1999 Tacoma SR5 V6 4x4 Manual. Everywhere I look, including the Denso site, all say the 234-9003 sensor does not fit my truck. Instead, they all say my truck uses 234-4161 as the upstream O2 sensor.
    Can anyone else confirm this as well? Maybe early years of the first gen Tacoma use 234-4161, but later years use 234-9003?
  7. Jul 12, 2022 at 5:09 AM
    Black DOG Lila
    Virginia
  8. Jul 12, 2022 at 3:19 PM
    Chris311
    Thank you. My truck is fed emissions.
    Funny enough, the Denso part site doesn't even list California compliant version of the Tacoma for years 1999 or older. It only lists 2000 and newer for part 234-9003.
    My truck started throwing PO125 code recently, and when I checked the plug for the b1d1 sensor, it has a broken wire. Hoping to get a new O2 sensor now and replace it this week.
    Thank you for helping me with making sure I pickup the correct sensor.
  9. Dec 23, 2022 at 12:34 PM
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    Thank you. I was going to start ripping everything from the inside to try to get to the top of the transmission and this confirmed it. What a pain in the ass.
    SwampYota[OP] likes this.
  10. Dec 23, 2022 at 3:57 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Why not repair your wire??
    Much cheaper then a new sensor .
    I know I would .
  11. Sep 8, 2023 at 12:31 PM
    tacosean88
    tacosean88 New Member
    Sean
    03 Taco
    Thank you this thread made this repair possible for me.
  12. Sep 9, 2023 at 6:49 AM
    SwampYota
    SwampYota [OP] Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Awesome, happy to help.
