O2 sensor codes....
Discussion in 'Technical Chat' started by cyclonerider2, Nov 25, 2013.
  1. Dec 4, 2013 at 3:16 AM
    Tacoma Mike
    Southern Maine
    Yes splitting between 2 shops is what I ment.
    The right box wrench will sneak down the wire.
    Yes they are a pita to unplug
    I have about 8 different wrenches and sockets for these sensors And still sometimes it's never quite enough.... Grrrrrrrrrrrrrr. Heheheeh
    Good luck
  2. Dec 4, 2013 at 6:14 AM
    cyclonerider2
    cyclonerider2 [OP] Active Member
    Youngstown, Ohio
    PreRunner
    Ya know Mike, I've been wrestling with the idea of doing this myself, mainly because of the cost, but after sleeping on it another night I decided to have the dealer do it. I called this morning and made the appointment. I kept thinking as long as everything went well, it would be worth it. But, after I've already purchased the parts online, I'm really into it. What if I can't get to that connector? What if I don't have the right tool? What do I do if after my work is done that there's still some sort of a problem? My gut tells me let them do it AND be responsible for the outcome. Plus, my back has a way of messing with me and I can see needing a chiropractor after all is said and done! LOL......Sorry for any inconvenience. You sure stepped up to the plate to help a guy out. Thank you for that.
  3. Dec 4, 2013 at 1:53 PM
    Tacoma Mike
    Southern Maine
    Oh my pleasure to help. I help when I can as long as the person isn't being a dick... Hehehehehe
    After 40 years I know all about chiropractors and surgery so I feel your pain.
    As far as the connector you have to be inventive. They just don't come apart real easy. Sometimes using a long screwdriver as a long finger helps. They change the angles at will so you have no idea what it looks like until you see it.
    If they do it then the parts are warr. 12/12 I believe. If your parts are warr. Then it would only be the part and not the labor because its not bought there.
    Then you would be in the same boat again if the sensor was an issue down the road. If your going to do this on the ground then you might be making the right move and having them do it.
    Let me know how things turn out..
    Mike...
  4. Dec 9, 2013 at 4:03 PM
    cyclonerider2
    Youngstown, Ohio
    PreRunner
    Hey Mike.......well the sensors got replaced today. I guess all went well. No other unexpected issues showed up. They applied the diagnostic fees I had already paid toward todays' repair. It cost me $623.00 today. So far no dash lights are illuminated so I guess it's all good. I'll keep my fingers crossed the other remaining sensors don't go bad too. They gave me a new Rav 4 to use while the work was being done. I really liked it. It was loaded with all wheel drive and leather interior. Too bad you can't tow a boat with it......
  5. Dec 9, 2013 at 6:14 PM
    Tacoma Mike
    Southern Maine
    Well you can tow a boat. Just not the boat you might want to tow..lol
    Hope all stays well.
    Thanks for letting me know.....
  6. Oct 12, 2014 at 4:44 AM
    leew
    leew Well-Known Member
    massachusetes
    2006 Taco SR5 4x4
    I have a 2005 Tacoma 4.0 and 130.000 miles with codes 0430 and 0606 coming up. The eng light will come on and off from time to time. Any idea where I should start? The truck runs very well... Thanks Lee
  7. Apr 21, 2015 at 9:16 AM
    yzf583
    yzf583 New Member
    2012 4cyl 4x4.I found all comments on this subject useful.thanks to all.i had code p0138 witch is downstream 02 sensor and after replacing it, the code always came back every couple of days.so I replaced the upstream air/fuel 02 and problem fixed.i guess if the the front gives false reading the second one is the one that detects a fault by reading a difference greater or less than normal.thanks again.
