O2 sensor issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by NOLA ItsNotOva, Jul 27, 2014.
  1. Jul 27, 2014 at 8:50 PM
    NOLA ItsNotOva
    NOLA ItsNotOva [OP] Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Decided to take a look at my O2 sensor yesterday and was seeing if maybe it wasnt bolted down all the way or had a bad wire connection. Neither f those were the issue so I will have to get a new one. My issue is, the bolts are rusting away and I cant figure out how I would get them off when I get my O2 in the mail. Any ideas?
  2. Jul 27, 2014 at 10:54 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
  3. Jul 27, 2014 at 10:58 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    shower them with some PB blaster
  4. Jul 28, 2014 at 1:59 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If you can get a propane torch in there without burning up the truck, that would be the easist. Make them red hot and you will be able to uncrew the the nuts with a pair of pliers. You will need new nuts.
  5. Jul 28, 2014 at 5:25 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    What if I were to chizzle them off? Would that be possible without messing up the threads?
  6. Jul 28, 2014 at 5:45 PM
    koditten
    Kirk
    Central Michigan
    I would still lean towards heating them up. There is nothing wrong with the bolts, just the nuts are rounded off. I don't see chiseling being easier. And I see chiseling them messing up the bolts.
  7. Jul 29, 2014 at 10:23 PM
    paquu
    paquu Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    Spray 50/50 mix acetone and automatic transmission fluid on the heads a couple times in the days leading up to the swap, tapping it a hammer to penetrate. It's supposed to be significantly better than pb blaster. I'd give it a couple hours to dry (acetone is flammable) then hit with heat. If that doesn't work those bolt extractor sockets. Harbor freight has those extractor sockets cheaper.
  8. Jul 30, 2014 at 5:28 AM
    AlienBacon
    AlienBacon Member
    Greg
    Seattle, Wa
    1" Body Lift 3" Suspension Lift
    Yea. PB Blaster the shit out of it! Pick up some "Grab-it" sockets too. If all else fails use a torch, or freeze em off.
    PB blaster should do the trick though.
