O2 Sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4x4jeep, Jan 29, 2012.
  1. Jan 29, 2012 at 5:21 PM
    4x4jeep
    4x4jeep [OP] Well-Known Member
    Kyle
    Destin FL.
    My truck is throwing a code for O2 Sensor. Its a 06 V6 with 65K miles. How do I know which O2 sensor to replace? Thanks
  2. Jan 29, 2012 at 5:25 PM
    4x4jeep
    Kyle
    Destin FL.
    The code is P0430
    Catalyst system efficiency below threshold
  3. Jan 29, 2012 at 5:31 PM
    4x4jeep
    Kyle
    Destin FL.
    Yea if I reset the code it will stay off for the next few drives. I hope its not the cats they are $$$ but at least in Florida their is no smog test :rolleyes:
  4. Jan 29, 2012 at 7:01 PM
    4x4jeep
    Kyle
    Destin FL.
    Is their a way to test the O2 sensors?
  5. Jan 29, 2012 at 7:35 PM
    the.sight.picture
    the.sight.picture Well-Known Member
    Nick
    Warren County VA
    2016 MGM TRD OR 4X4 DCSB
    Tint
    its the passenger side downstream. P0430 is bank 2. Bank 2 = cylinder 2 side
    check for leaks before downstream 02 sensor. then if no leaks replace 02 sensor. then replace Air /fuel ( upstream sensor). if MIL doesnt go away, bad cat. also if there is bad (rotten egg smell from exhaust) smell from exhaust, its the cat. the only cat u have to worry about if there is no smog test is the manifold cat. 500$ for magnaflow direct fit manifold cat and 300-400$ for eastern direct fit manifold cat. Homework has been done.
  6. Jan 29, 2012 at 7:37 PM
    the.sight.picture
    Nick
    Warren County VA
    Tint
    Ometer test. test the electric waveforms based on factory service manual. Buy Ometer at wally world
    Oh and cats just dont magically go bad. Mecs say that to get more $ outta you. fixed my stuff 3 weeks ago with 02 sensrs, mecs said it was BOTH cats. so....
  7. Jan 29, 2012 at 7:38 PM
    4x4jeep
    Kyle
    Destin FL.
    Thanks exhaust smells normal. Ill check for leaks in the A.M. and replace sensors accordingly
