O2 sensors
Discussion in '1st Gen. Tacomas (1995-2004)' started by Famouskmksrh26, Feb 16, 2010.
  1. Feb 16, 2010 at 10:53 PM
    Famouskmksrh26
    Famouskmksrh26 [OP] Active Member
    Sa, TX
    2003 4x4 TRD Limited
    TRD SuperCharged, Flomaster, Daystar 2 1/2" LVL kit
    im tyring to find out how many 02 sensors my 03 has i know i have two that are out but how many are there total and where is the cheapest place i can get em
  2. Feb 16, 2010 at 11:02 PM
    PacNWgen1
    PacNWgen1 NewHere
    Adam
    Oregon
    96' Tacoma Reg Cab 2.7l 4x4 5-speed 150,000+
    DynoMax ST, Deck Plate, Full Syn, Soon Header and Slotted Rotors
    Not sure how many there are? But i just saw some OEM(Denso's) on EBay. Wish I had checked I just spent 290 at the Stealership.
  3. Feb 17, 2010 at 4:17 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    TWO......
    Before the CAT (up near the manifold) and another one after the CAT.
  4. Feb 17, 2010 at 5:00 AM
    98tacoma27
    Ben
    Not Beech Creek
    Denso 234-9001 = Front
    Denso 234-4189 = Rear
    I highly recommend avoiding anything but Denso. Denso is the OE for Toyota's. Avoid universals also.
    You can can get them at either if these places
    www.urdusa.com
    www.rockauto.com
  5. Feb 17, 2010 at 7:04 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Yep, got mine at rockauto.com, and there farely easy to install to. And for the rear O2, there are 2 different ones, make sure to get the one that is longer in length with the connector.
  6. Feb 17, 2010 at 5:00 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    autopartswarehouse.com is where i bought mine
  7. Feb 18, 2010 at 4:36 PM
    Famouskmksrh26
    Sa, TX
    Thanks guys i pericate it i really do
  8. Feb 20, 2010 at 3:48 AM
    krlang
    krlang NewEnglander
    Commonwealth of Massachusetts
    03 2WD 2.4L Tacoma Reg Cab
    Chrome Bumpers F&R, Grille & Corner Lights, Wheel Skins, Red/Clear LED taillights, Remote start, PDL, Cruise, K&N, All Kenwood, DNX-5120 6.1" NAV/TRAFFIC/DTV/DVD/XM/BLUETOOTH/USB/IPOD/SUB/rear cam, Tint, Air Band radio, Class 3 Hitch with 4/7 pin harness, Transmission Cooler, Red Top Battery, "Deck Plate" mod.
    I have replaced my rear O2 sensor twice, once because it failed, the second time because it was incorrectly reinstalled during a muffler replacement.
    I bought this one the second time.
    http://www.amazon.com/gp/product/B000C91HX8/ref=oss_product
    The first one failed at 65k or so, giving me an engine light
    I replaced the original one with that same walker aftermarket unit I bought locally for $85
    I had the muffler replaced back in December, the parts store was out of the gaskets and said they would send one up the next day. The guy at the shop didnt wait for the new gasket, put it on with the old one, cracked both ears and sent me on my way. The next day I got a rear O2 sensor code. :(
    I bought the new sensor, got under my truck, saw the mess, took me a while to remove the rotten gasket off of the flange, installed the new one and things are all back to normal.
  9. Mar 4, 2010 at 7:19 AM
    ETaco23
    Evan
    PNW
    Yes it can improve mpgs. And If they havent been changed I would def. do so! They could be all fould up and not working correctly, and still not through a CEL.
  10. Mar 4, 2010 at 7:28 AM
    98tacoma27
    Ben
    Not Beech Creek
    Replace the front one(s).
  11. Mar 4, 2010 at 1:28 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    the front one seems to have more of an impact on your mpgs, it is also the more expensive one to
  12. Mar 4, 2010 at 5:46 PM
    ETaco23
    Evan
    PNW
    But Ive heard you should replace both at the same time bc one will read differently then the other.
  13. Mar 4, 2010 at 6:04 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    yah youre probably right there, my front one went on me, now im dealing with the CEL being on because of the rear one. I ordered a URD rear o2 sensor simulator tonight to fix that little problem. The simulators are a plug and play setup now,no more splicing.
  14. Mar 4, 2010 at 6:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    let me know how the install goes man. im planning on trd headers eventually....but in the meantime, im prolly gonna delete the catalytic converter and had planned on getting the rear o2 sim.
  15. Mar 5, 2010 at 1:28 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    yah no problem, hopefully itll be in sometime next week. shipping kinda takes a little long when shipped up to canada.
  16. Apr 3, 2010 at 8:39 PM
    bwilliamson
    bwilliamson Well-Known Member
    Brad
    Magnolia, KY
    I need to replace my rear sensor but for the life of me cant figure out how to get the old one off. Do i need to drop the muffler to get it out or what? There is just no why that I can see other than that to get the nuts off
  17. Apr 3, 2010 at 8:52 PM
    ETaco23
    Evan
    PNW
    Get the nuts off, and then fallow the wires up to the connector. And there is a little tab on the top that you need to push in on and then wiggle it out. It took some muscle to get mine off. What year/engine do you have?
    Oh and the connector will/should be under your passenger seat.
  18. Apr 4, 2010 at 5:39 AM
    Janster
    Jandy
    Lancaster, PA
    1st gen ? 3.4L? Manual? (02 sensort 2?)
    http://www.lieblweb.com/o2replacement.html
    I had to open up the shifter boot (manual) to get in there to unplug it - if I can remember correctly, been many years since I did it.
  19. Apr 4, 2010 at 8:38 PM
    bwilliamson
    Brad
    Magnolia, KY
    I wish it was that easy. The sensor it self has a heat shield (im guessing) on it. This shield is on the side thats most accessible. cant get any tool or can of pb blaster for that matter to work on it. Im seriously thinking im gonna have to drop the exhaust just to change it out.
  20. Apr 5, 2010 at 8:31 AM
    Janster
    Jandy
    Lancaster, PA
    Got any pictures?
