O4 Tacoma Lift Result
Discussion in 'Suspension' started by BRP27, Dec 12, 2009.
  1. Mar 22, 2010 at 4:51 AM
    BRP27
    BRP27 [OP] When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    I have had it checked 3 times as I moved it up in two steps and back down. The shop is well respected and says the numbers are good and it drives good. Maybe it is how they are presenting the numbers. I will ask them. If caster was off that much I would expect it to drive like crap
  2. Mar 22, 2010 at 5:24 AM
    fsbrain03
    fsbrain03 Well-Known Member
    Your truck looks awesome. Looks like we have almost the same setup, and I know I love mine.
    Great job! Any more plans for it?
  3. Mar 22, 2010 at 5:53 PM
    DblstuftTaco
    DblstuftTaco Well-Known Member
    Joe
    Ohio
    02 TRD SR5
    OME 3" Kit New frame
    Awesome!
    I've been on the fence about lifting my 02 dbl cab, your pics have inspired me! I might go with the OME 3" kit from Toytec. Hopefully it comes out similar to yours.
  4. Apr 5, 2010 at 3:34 PM
    BRP27
    04 4X4 Tacoma SR5
    I went back and had them do an alignment again. I stood there the whole time and encouraged the alignment tech to get the caster numbers up.I told him that the camber could be sacrificed a little to get the caster higher. My goal was to get Caster around 1.5
    I ended up with these numbers
    Camber -0.2 0.0
    Caster 1.2 1.6
    Toe 0.07 0.05
    No where near > 2.0 on the caster but I can live with these numbers.
    It was very interesting working with the tech and seeing that caster and camber are inter related. Toe is no problem. The machine was new and cost $35,000 with the lifts. That was the forth alignment after I lifted the truck. 1) to align after I lifted first time. 2) to align after I lifted it to a full 3 in. 3) Lowered it 3/4 in to keep CV angles more reasonable. 4) to get the caster higher. I would Advise staying just below 3 in to keep the CV angles down.
    I drove the truck today > 80 miles and the caster helped. Not a big change in driveability but noticeable. Caster being off is really no big deal. I can't see why 600 for a UCA would be needed for just caster.
  5. Apr 5, 2010 at 4:15 PM
    BRP27
    04 4X4 Tacoma SR5
    Bump
    200 th post, Now I am a Super Senior Gold Member
    Thank You TW
  6. Apr 9, 2010 at 8:38 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I am very curious about the overall performance/horsepower feel/change since the addition of the bigger tires. Have your shift points changed? I am assuming you have not re-geared yet. Has the way the truck responds in traffic changed? Finally, have you lost a significant amount of MPG?
    I just installed a coilover lift, mine are SAWs. I am at about +2.5 in the front. I am sure that I can fit 285s but worried about the compromises in performance.
    Thanks for the feedback.
  7. Apr 13, 2010 at 4:46 AM
    BRP27
    04 4X4 Tacoma SR5
    I did not notice a drop in performance, no change in shift point. I don't drive this truck hard, but it accelerates sharply for what it is. This truck is the V6 version and the tires were not a noticable impact, for me.
    I don't plan to re gear, I am 4.10 now and that is good for me.
    The compromise is in clearance, I have one spot that rubs the frame lightly when I trurn against the lock going left. And the stock jack doesnt work good, had to get a Hi lift type of jack. On the plus side I like the lokk of having the Hi lift mounted in the back.
  8. May 18, 2010 at 1:58 PM
    bighungitacoma
    bighungitacoma Well-Known Member
    hey, i ordered the ultimate kit for m white 03 last night, i love how ur .truck came out man, thats how im hopin mine comes out...but did you need a carrier bearing drop bracket or brake line extensions??
  9. May 18, 2010 at 2:06 PM
    BRP27
    04 4X4 Tacoma SR5
    I bought the brake line extension but never used it and the carrier bearing is not moved. I did buy and use the differential drop kit. I have no vibration issues
  10. May 18, 2010 at 2:07 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Those #s are much better than the first set. And typical when lifted without UCAs.
  11. May 18, 2010 at 2:10 PM
    BRP27
    04 4X4 Tacoma SR5
    It drives better with the caster numbers up a little, the after market UCAs would make it drive even better but ... its not worth it to me.
  12. May 18, 2010 at 8:37 PM
    bighungitacoma
    thanks bro, i cant wait to get mine in the mail
  13. Jul 31, 2011 at 9:38 PM
    zshred199
    zshred199 Member
    Zach
    Santa Rosa California
    2002 Toyota tacoma Prerunner 4cyl
    how much did your wheel package cost
