Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. May 26, 2014 at 11:43 AM
    #9861
    Airmain
    Airmain Well-Known Member
    Jes
    Middle of Georgia
    06 TRD Off road
    I am not goin to be able to make it today srry
  2. May 26, 2014 at 11:49 AM
    #9862
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    I'm figuring free style...gonna meet Ryan (Vigo) there. He's gonna bring his crawler also.
  3. May 26, 2014 at 11:52 AM
    #9863
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Helical gears? For the pinion and spur? Me no likey. The twisted teeth puts lateral force on the motors armature and causes the bearings to wear out quickly. It's basically a screw. Align offered them on the trex 600 and I tried them. Sounded cool, and was quiet, but I could see tell the main gear was being pulled on. Most motors don't have thrust bearings. To solve this issue, mikado came out with a double helical herringbone cut gears. Very quiet, and double opposing helical teeth countered each others force. But alignment was critical.
  4. May 26, 2014 at 12:03 PM
    #9864
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    That sounds like a neat set up, but I think they're talking out the pinion / diff ring gear. I have em on a crawler, I didn't break it yet, but the metal doesn't wear as fast as the stock axial ones.
  5. May 26, 2014 at 12:06 PM
    #9865
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    my u-bolts have been flipped for a while :p
  6. May 26, 2014 at 12:06 PM
    #9866
    TRDeeznutz
    TRDeeznutz Smash Da Skinny Pedal
    Kaleo
    Kapolei, HI
    2013 tacoma trd sport
    The gears would be for the transmission. Its a full set for my 2speed. 2 input, 2 idle gears an 2 output.
  7. May 26, 2014 at 12:11 PM
    #9867
    808leo
    808leo Well-Known Member
    Kapolei, Oahu
    ‘21 super white dcsb 4wd
    5100 max setting, 285/70/17 ko2, FN 6 shooter, Subaru/kicker tweeters, JBL BassPro sub, nfabs, LED lights exterior/interior.
    Hit it and quit it boobs..
    Long term fitness model.. At least you know she'll always take good care of herself and you ;)
  8. May 26, 2014 at 12:11 PM
    #9868
    TRDeeznutz
    Kaleo
    Kapolei, HI
    Mikes flipping his shackles!
  9. May 26, 2014 at 12:23 PM
    #9869
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Now that's good advice!:D:D
  10. May 26, 2014 at 12:32 PM
    #9870
    bullaculla
    Da big big island!
    Those are better, but not as good as worm drive for a crawler :D
    Should be fine then. Quiet too :)
  11. May 26, 2014 at 12:38 PM
    #9871
    TRDeeznutz
    Kaleo
    Kapolei, HI
    So would the regular rubber sealed or whatever bearings work?
  12. May 26, 2014 at 12:40 PM
    #9872
    bullaculla
    Da big big island!
    If its in the trans case, then no need rubber sealed bearings. stays pretty clean in there. I used to buy all my bearings from bocabearings.com ABEC-5 or 7 :D
  13. May 26, 2014 at 12:43 PM
    #9873
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Iven, that dude with the Icon's with the noise issue solved his problem when he put on new one's. Must have had a bad shock
  14. May 26, 2014 at 12:44 PM
    #9874
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    He's now a card carrying member of the U-Bolt flip club:D
  15. May 26, 2014 at 12:56 PM
    #9875
    TRDeeznutz
    Kaleo
    Kapolei, HI
    Ok sounds good!
  16. May 26, 2014 at 1:21 PM
    #9876
    lemon177
    lemon177 Well-Known Member
    Matthew
    Oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    I should be leaving my house by 11
  17. May 26, 2014 at 1:44 PM
    #9877
    Vigo
    Vigo WFO
    '12 4 door
    stuff...
    Thanks to all the servicemen for your sacrifices.
  18. May 26, 2014 at 1:57 PM
    #9878
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    :amen:
  19. May 26, 2014 at 2:29 PM
    #9879
    JCos327
    JCos327 Active Member
    Jose
    New Jersey
    08 2.7L SR5 5 speed 4x4
    LCE headers, AFE CAI, Magnaflow Exhaust, 5100 Billestien front and back w/ add a leaf, Homertaco Grill, 275/70/R18 Toyo M/T, 18” XD Thump Wheels, AMP retractable steps, 10” Alpine Type S Sub and Amp, infinity door speakers
    Hey everyone, new to the thread and kinda new to the island. Anyone running a 2.7L 4x4? Seen a lot of nice trucks on the island and i need some ideas.
  20. May 26, 2014 at 2:31 PM
    #9880
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
