OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Jun 28, 2021 at 7:00 PM
    #2161
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    I would tend to think it's not leaking out of the compressor because I have a check valve downstream of the compressor. Unless the check valve is bad. :notsure:
  2. Jun 28, 2021 at 9:00 PM
    #2162
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    If you store air in a tank it needs a check valve. Pumps definitely leak back pressure. The cylinder “valve” can be as simple as a flexible metal strip over the intake port. It works as a one-way port but doesn’t really seal very well. A spring loaded check valve will take care of that.
    Gunshot-6A[OP] likes this.
  3. Jun 28, 2021 at 9:03 PM
    #2163
    bagleboy
    Scott
    Norcal, Santa Rosa
    Have you checked the Schrader valve? They can leak too. Otherwise it’s going to be either the ptc connections or the tapered pipe thread connections.
  4. Jun 28, 2021 at 9:10 PM
    #2164
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    When I installed my OBA system, I used brass compression fittings. Had a good sized leak that would make my compressor blip every 4 to 5 mins. No air tank (yet).
    Drove me nutz!
    After extensive leak checking with soapy water, I resorted to systematically capping each fitting starting at the pump outlet. Worked my way through the system. Turned out to just be a compression fitting that needed one more "ugga dugga" and all was good from there.
    Now it holds solid for weeks.
    RyanDCLB likes this.
  5. Jun 29, 2021 at 8:29 AM
    #2165
    bagleboy
    Scott
    Norcal, Santa Rosa
    Just an in general FYI, when using compression fittings for soft tubing you’re supposed to use nylon compression sleeves along with brass tube inserts instead of the brass compression sleeves supplied with each fitting.
  6. Jun 29, 2021 at 1:47 PM
    #2166
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    You are probably right. The 3/8" plastic air hose I am using is quite rigid.
    https://www.amazon.com/dp/B08HQST6FD/?coliid=II381UJLSA7KE&colid=2X0EZYTFDNQHS&ref_=lv_ov_lig_dp_it
    It came in a tight coil that I warmed up in the oven to get it to layout mostly straight, and then pinned it to the yard and hosed it down with the garden hose.
    After putting this system together and getting everything leak free, I think I might switch out the connection points to the push lock style for tool free maintenance. The compression fittings are kind of a bear to deal with in tight proximities under the hood.
    This system should get me through this summer and then I'll be looking at changing things out.
    Otherwise having air at the front of the truck and at the rear bumper is a game changer for sure!
  7. Jun 30, 2021 at 2:57 AM
    #2167
    Tactical_Panda
    Tim
    Fredericksburg, VA
    I don't have a Schrader valve in my system.
  8. Jun 30, 2021 at 9:12 AM
    #2168
    bagleboy
    Scott
    Norcal, Santa Rosa
    I have it as an alternative to the compressor for filling the tank and for those without a tank it’s the most common fill port for air bag systems. You’ll probably need to use a more persistent soapy mix. It could also be a pinhole in the tubing itself. Unless you submerge the entire kit it will be hard to locate. Schrader valves come in handy for that kind of testing. I’m in the midst of building up a manifold to use air cylinders instead of linear actuators and the more connectors you have the more leaks are possible but I can charge the whole thing including 50’ of tubing and dump it in a cooler. 2 of 6 ball valves had cracked seats where the 1/4 mpt connectors screwed in. Some of the pipe thread connectors took more than one attempt to seal since under magnification the threads were ugly.
  9. Jul 1, 2021 at 2:36 AM
    #2169
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Quick question-- Reading a couple pages back it seems like some of you are leaving your system charged with air full time even while the vehicle is off. I always thought that leaving any air compression system full of air was terrible for fittings over time. They are constantly holding pressures. Similar to a garage air compressor for running tools. I always bleed out my systems after they been used and let them sit empty until the next use.
    There has to be a way to isolate the tank where only the tank would be holding pressure and keep the lines empty. Now you guys have put me on a path I'm not entirely ready for.
  10. Jul 1, 2021 at 5:38 AM
    #2170
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    The fittings are designed to hold pressure. They don't have a duty cycle, so being pressurized constantly isn't going to hurt them. The reason home owner grade compressors want you to vent them is because is condensation. The tanks are steel, so the condensation will rust them out from the inside overtime if they're left sitting.
  11. Jul 1, 2021 at 8:26 AM
    #2171
    bagleboy
    Scott
    Norcal, Santa Rosa
    If you feel the need you can install a 12v ball valve at the tank output. They make them in different wiring configurations for use with different switch types and they come in handy for isolating different parts of the system. I have one installed.
    ClassyTacos[QUOTED] likes this.
  12. Jul 4, 2021 at 1:29 PM
    #2172
    optysite
    optysite Well-Known Member
    ‘15 TRD OR Magnetic Grey
    I’m pretty nooby at this, but if I’m installing an Aircomp that I want to run off the blue sea fuse box can I use two circuits ran to one 80a relay and then one wire running to the aircomp from the relay? It’s a Viair 400p, so I know it needs just above what the blue sea provides on a single circuit. I just want to make sure it’s one to have two circuits go into one at the relay as opposed to running it straight from the battery.
  13. Jul 4, 2021 at 2:05 PM
    #2173
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    That would work, but you'd be better off running a wire straight from the battery or system circuit breaker (if you're running one) with an inline fuse.
  14. Jul 4, 2021 at 2:06 PM
    #2174
    optysite
    I know it sounds crazy but I just think having the wires leave my aux fuse box would appear like a cleaner install. Besides simplicity are there other advantages of coming straight off the battery?
  15. Jul 4, 2021 at 2:16 PM
    #2175
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Only 1 fuse for the system vs 2 with what you're proposing. Also, you have no way of guaranteeing that the current draw from the two circuits will be the same. If one side blows before the other, you're going to get a massive current spike through the second side which will blow it as well. If you're making your own cables from the battery to the Blue Sea, it would be easy enough to get a slightly larger gauge lug and crimp in both the wire for the Blue Sea and the compressor. The sleeve them together, so it looks like one cable.
    Like I mentioned, you're going to be running a circuit breaker, you can just pull a second wire off of it for the compressor. You can mount an AMI/MIDI or ANL fuse holder on your panel for an integrated look, instead of an inline fuse holder.
  16. Jul 4, 2021 at 2:20 PM
    #2176
    optysite
    Those are pretty valid, I think I’m convinced.
  17. Jul 4, 2021 at 2:46 PM
    #2177
    optysite
    I know this thread is more about the air install than it is the wiring part but if I have a relay with 12awg wire coming out of it spliced to 8awg for the long run to the compressor will that cause issues?
    the relay in question: 4-pin 80/60 AMP 12V DC Waterproof Relay with Harness - Heavy Duty 12 AWG Tinned Copper Wires, 1 Pack SPST Bosch Style Automotive Relay for Marine Boat Fan Light https://smile.amazon.com/dp/B08D8T9X9R/ref=cm_sw_r_cp_api_glt_fabc_KPN8VX7DEF4S2PKWP0NX
  18. Jul 4, 2021 at 7:16 PM
    #2178
    bagleboy
    Scott
    Norcal, Santa Rosa
    You’d be better served to pull the two #12 wires(pins 30 & 87) and have only #8 from terminal to terminal. The awg12 isn’t rated for 60A no matter how short the run.
  19. Jul 14, 2021 at 1:10 PM
    #2179
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Are there any other options beside arb that are sealed that people are running on second gens. I want to outfit my gfs second gen but she’s not going to use it all that much and doesn’t want to pay for the arb. Let me know
  20. Jul 14, 2021 at 7:49 PM
    #2180
    bagleboy
    Scott
    Norcal, Santa Rosa
    Vair is another decent choice.
    optysite likes this.
