OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Dec 14, 2021 at 7:17 PM
    #2241
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    If the check valve is oriented correctly then any back bleed through he compressor should last only a few seconds at most. A check valve is just a ball bearing and a spring but they can still leak if the bearing is corroded or there’s a foreign body lodged. If the check valve is backwards then you get no air past it so it should be obvious.
  2. Dec 15, 2021 at 1:51 AM
    #2242
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    The check valve was always oriented properly; it's worked ever since I installed it. Now, my OBA system has had a mysterious bleed-down problem for a couple of months prior to the relay failures that I could not pin down. Maybe I finally discovered the problem.
    I ordered a new check valve. Stay tuned...
  3. Dec 17, 2021 at 10:02 AM
    #2243
    Tactical_Panda
    Tim
    Fredericksburg, VA
  4. Dec 17, 2021 at 10:16 AM
    #2244
    bagleboy
    Scott
    Norcal, Santa Rosa
    You can get plastic ones for sump pumps. Is it brass or chrome plated brass?
  5. Dec 17, 2021 at 10:17 AM
    #2245
    Tactical_Panda
    Tim
    Fredericksburg, VA
    Brass.
  6. Dec 17, 2021 at 10:22 AM
    #2246
    bagleboy
    Scott
    Norcal, Santa Rosa
    Threaded fitting leaks can be hard to spot if you can’t get the soapy water everywhere. Ptc connectors as well. But if you’re sure of all of those that leaves the tubing itself. I’ve reached the point where I do a pressurized immersion test to spot problems before install and also switched to compression fittings instead of ptc.
  7. Dec 17, 2021 at 10:23 AM
    #2247
    bagleboy
    Scott
    Norcal, Santa Rosa
    Likely an air fitting then.
  8. Dec 17, 2021 at 10:25 AM
    #2248
    Tactical_Panda
    Tim
    Fredericksburg, VA
    I've done the Soap Suds test on all my fittings. They don't indicate any leaks.
    I guess I'll keep looking.....
  9. Dec 17, 2021 at 10:31 AM
    #2249
    bagleboy
    Scott
    Norcal, Santa Rosa
    Try slightly more soap or less water to increase the viscosity. Or not use windex as the alchohol also interferes. It might make the bubbles persist longer and get bigger. If they form on a side of the fitting you can’t observe directly they could be forming and popping out of sight.
  10. Dec 17, 2021 at 4:20 PM
    #2250
    Tactical_Panda
    Tim
    Fredericksburg, VA
    I use water and dishwashing soap. No Windex or alcohol.
    I'm also going to try letting the compressor pump the tank up to full pressure, then disconnect the fitting on the compressor-side of the check valve. Then soap up the check valve and see if I am am getting any back flow.
    bagleboy[QUOTED] likes this.
  11. Dec 17, 2021 at 5:09 PM
    #2251
    bagleboy
    Scott
    Norcal, Santa Rosa
    Do you have a drain valve? Those can leak since they’re prone to getting fouled.
    Gunshot-6A[OP] likes this.
  12. Dec 17, 2021 at 5:13 PM
    #2252
    Tactical_Panda
    Tim
    Fredericksburg, VA
    I do.
    I'll check it as well.
  13. Dec 17, 2021 at 5:14 PM
    #2253
    bagleboy
    Scott
    Norcal, Santa Rosa
    Good luck with it. Finding them can tax the patience.
  14. Dec 18, 2021 at 10:26 AM
    #2254
    Tactical_Panda
    Tim
    Fredericksburg, VA
    OK.
    There is no backflow through the check valve. Yay!
    Found two more small leaks. Boo!
    Fixed them both. Yay!
    Checked the drain cock on the tank. No leaks. Yay!
    Still have a small leak somewhere. Boo!
    But the bleed-down is not as bad as before. Yay.
    Still have one connection to check but it is in a very inaccessible location. Boo!
    Will tackle that one tomorrow.
    Gunshot-6A[OP] and Meclizine like this.
  15. Dec 24, 2021 at 12:52 PM
    #2255
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Read through most of this thread, bud didn't find my answer so I will ask a fresh question.
    My ARB twin has been under hood for less than a year and working awesome. Just recently it is giving me a very high pitch/squeal sound after it warms up during use. So, it's not there during the first several cycles. Damn it's loud!!!
    The squeal only happens just before it triggers off at max PSI. I am leaning toward the pressure switch being the culprit, unless anyone has another suggestion?
  16. Jan 17, 2022 at 10:41 PM
    #2256
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    So I'm finally gathering parts to hard mount my smitty 2781. Currently looking for a relay/solenoid that can handle atleast 50A. I've been looking in the 80A range, but it seems like every relay or constant duty solenoid I can find on the internet have bad reviews, most including claims of getting extremely hot or failing pretty fast. Is there a go-to relay/solenoid that you guys have used? I'd like to hear what options people have had some good luck with, especially if you have experience with operating it in cold (sub 32F) temperatures.
  17. Jan 18, 2022 at 3:59 AM
    #2257
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Have you considered this one?
    https://www.amazon.com/Fastronix-We...t=&hvlocphy=9032898&hvtargid=pla-568736851419
  18. Jan 18, 2022 at 7:52 AM
    #2258
    Jojee117
    Joe
    MT
  19. Jan 18, 2022 at 7:57 AM
    #2259
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I ran this directly off my arb twin. I was fine for a while but after filling 4 35’s and 2 32” tires the fitting melted blowing the line out. Switched to a viar stainless braided hose for 16 to a distribution block. Haven’t checked the temps there but you may be able to run it after a set distance.
    Dan8906[QUOTED] likes this.
  20. Jan 18, 2022 at 10:40 AM
    #2260
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I haven’t got around to doing this mod yet, but I did grab a stainless hose to come off the arb with. Hopefully I can get this done before wheeling season
