OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Mar 7, 2014 at 11:14 AM
    #221
    crooks420
    crooks420 Well-Known Member
    Jesse
    San Gabriel
    05 AC Prerunner SR5, 12 DC LB 4x4, 70 FJ40
    nice install.... well thought out.
  2. Mar 7, 2014 at 11:39 AM
    #222
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Just started seriously looking into my own OBA setup (odd my autocorrect wants to change oba to Obama?). I want to be able to fill tires at the end of trails and have future plans for rear ARB Locker.
    I see a lot of people using Viair and other 100% duty cycle compressors, but from what I'm seeing they have lower CFM (<2) than other "medium duty" compressors. Is this strictly for using air tools or is there something I am missing. Higher CFM = faster tire/tank fill.
    For instance I was comparing ARB to MV90. Granted the MV90 has a much higher amp draw.
    specifications MV90
    rumored 67% duty cycle
    air volume: 6400 cubic inches per minute
    CFM at 90 PSI: 3.71
    maximum voltage: 12 volt
    maximum amperage draw: 45 amps
    maximum working pressure: 150 psi
    maximum restart pressure: 90 psi
    maximum operating temperature: 90 degrees F
    minimum operating temperature: -67 degrees F
    maximum continuous operating time: 40 minutes @ 40 psi @ 75 degrees F
    Manfred likes this.
  3. Mar 9, 2014 at 7:49 AM
    #223
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    In order to accurately compare the CFM outputs, find each manufacturers chart for the CFM rates at PSI. Then you can tailor the best fit for your needs and air tools you want to run. (Max psi, CFM requirments etc)
  4. Mar 10, 2014 at 12:56 PM
    #224
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Yes, you need to compare CFM at say 90PSI for both compressors. I am using a Viair systm with the relay/limit swithc rated to turn on at 90PSI and turn off at 125 PSI (they sell one higher and one lower). If you use a tank of 3 to 5 gallons capacity in your OBA system it will go a long way toward topping off your tires. The pitfall here is if you have really small compressor and a really large tank you will have to wait a bit for the tank to build up if you drain it below say 60 PSI.
    Any way you go it sure beats driving around on 12PSI on the road hoping your tires dont overheat! I used to never go below 20PSI so that I could drive home as is, but in many conditions lower pressure is a big improvment.
  5. Mar 10, 2014 at 1:00 PM
    #225
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    For anyone it may concern, i used up the last bit of my CO2 tank this weekend airing up. this was the first cycle from full to empty that i had run through it. i was curious how acurate the "tank pressure" gauge would be, and it turns out that it is extremely acurate. lost pressureprecisely when the needle hit empty. this is in refference to the power tank brand. i cannot speak for to the acuracy of any other brands.
  6. Apr 15, 2014 at 6:29 PM
    #226
    yoBr0ski
    yoBr0ski Active Member
    Pittsburgh
    2010 DCSB OffRoad
  7. Apr 17, 2014 at 7:05 PM
    #227
    CVYota
    CVYota Yarrr, me be Captn Andy
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Got home from work and started installing this behind the rear driver side seat.
    drilled and tapped into the floor on top of the foam pad that is already there and bolted it down, ran the electrical to the dash gonna finish up tomorrow. Went with the twin for future lockers, air up the tires and run some small air tools.
    Crom likes this.
  8. Apr 30, 2014 at 1:10 PM
    #228
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    I am picking up my ARB Twin air compressor on Friday and will be installing it in my tool box. Do any of you know what fittings I would need to run it through the wall of my tool box so I can have access to a quick Disconnect on the outside?
  9. Apr 30, 2014 at 2:09 PM
    #229
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Sounds like you need a bulk head fitting, or a PTC straight if you'll have enough thread sticking through to attach a female quick disconnect. :cool:
    So many options, What size air line are you running?
    Preferred is a DOT rated PTC fitting.
  10. Apr 30, 2014 at 2:58 PM
    #230
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    I haven't got any airlines for it yet.
    Also via some googling it appears that I will be needing their air manifold so I can run my locker with the twin. Ugh so damn annoying.
  11. Apr 30, 2014 at 3:06 PM
    #231
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Twin doesn't come with the manifold?
  12. Apr 30, 2014 at 4:05 PM
    #232
    BradyT88
    BradyT88 Well-Known Member
    Nope for some reason it doesn't.
  13. Apr 30, 2014 at 5:18 PM
    #233
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Thought I read that the manifold comes with the locker?
  14. Apr 30, 2014 at 7:44 PM
    #234
    BradyT88
    My locker did not come with a manifold, but I did buy my locker and compressor at the same time and the non-twin compressor comes with the manifold, so I highly doubt the lockers come with the manifold.
    They do come with the solenoid (and wiring/switch for it) that goes into the manifold and allows the lockers to air up selectively.
  15. Apr 30, 2014 at 9:06 PM
    #235
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Thats what I probably saw
  16. May 4, 2014 at 8:41 PM
    #236
    InTheRough
    InTheRough Well-Known Member
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    I picked up a tank today. I just need the mounting straps for it. Anyone have a place they can point me to for two 9.75" diameter straps?
  17. May 4, 2014 at 8:50 PM
    #237
    nvwiggins
    nvwiggins Well-Known Member
    David
    Elko
    96 Tacoma, 85 T4R
    Tepui Kuenam Sky RTT.
    Commercial truck parts stores might have them for the tanks used on air brake systems. Not sure what size they are though .
  18. May 4, 2014 at 10:09 PM
    #238
    InTheRough
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    Ya actually the tank came off of a bus (front brakes) I tried looking it up but most of them were like $65 and up plus shipping (some were even up to $300 for them mounts). Seems a little steep for a thin piece of metal. It's 9.75" in diameter btw.
  19. May 4, 2014 at 10:10 PM
    #239
    nvwiggins
    David
    Elko
    96 Tacoma, 85 T4R
    Where are you going to mount yours?
  20. May 4, 2014 at 10:14 PM
    #240
    InTheRough
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    Under the bed where the spare was. Probably closer to the cab or where ever I have the most room/clearance.
