OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Sep 23, 2014 at 10:24 PM
    #401
    skygear
    skygear                    
    cmanhonor likes this.
  2. Sep 23, 2014 at 10:26 PM
    #402
    adriancast
    adriancast Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
  3. Sep 23, 2014 at 10:34 PM
    #403
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Hadn't thought about quick disconnects for water yet!
    We will be cutting the clamps off and running the wires to relay and then to a extra Fuse block, Blue Seas/Skygear/cheap auto parts store mounted behind the taillight. Switch in the cab will be hooked to the relay.
  4. Sep 23, 2014 at 10:51 PM
    #404
    adriancast
    Adrian
    Ontario, Ca
    Ok. I was thinking of cutting the clamps off. There's a fuse already hooked up to the compressor. Can I use that?
  5. Sep 23, 2014 at 10:55 PM
    #405
    Sandman614
    Tim
    '06 SR5 Off Road
    Yep. It's just cleaner to a Fuse block. Don't forget the relay.
  6. Sep 23, 2014 at 10:55 PM
    #406
    skygear
    skygear                    
    Yes, you can use that fuse. I have my 2 wired through the RFRM That I built. In my sig.
  7. Sep 23, 2014 at 11:03 PM
    #407
    adriancast
    Adrian
    Ontario, Ca
    That's what I'm asking. Do I need a relay? It's basically the same setup. I just want it to be under the hood permanently instead of grabbing it from my toolbox everytime I need it.
  8. Sep 23, 2014 at 11:05 PM
    #408
    skygear
    skygear                    
    YES. You need the relay. A relay is an electromagnet switch. It takes the load off the regular switch used to activate the compressor.
  9. Sep 23, 2014 at 11:08 PM
    #409
    adriancast
    Adrian
    Ontario, Ca
    Ok. Thanks.
  10. Sep 23, 2014 at 11:12 PM
    #410
    skygear
    skygear                    
    No problem
  11. Sep 24, 2014 at 7:51 AM
    #411
    adriancast
    Adrian
    Ontario, Ca
    I was thinking of using the same switch. I'm not going to be adding a switch in the truck.
  12. Sep 24, 2014 at 8:58 AM
    #412
    Sandman614
    Tim
    '06 SR5 Off Road
    You should be good to run it like that, but there is an led that comes on when you connect power. That may run your battery dead.
  13. Sep 24, 2014 at 9:01 AM
    #413
    adriancast
    Adrian
    Ontario, Ca
    yea. thats what i was thinking. its pretty much the same setup now just that clamps are going to be connected to the battery permanently. any recommendations on what to use after i remove the clamps?
  14. Sep 24, 2014 at 9:04 AM
    #414
    Sandman614
    Tim
    '06 SR5 Off Road
    I edited the comment, read the rest of it. Ring connectors.
  15. Sep 24, 2014 at 9:05 AM
    #415
    adriancast
    Adrian
    Ontario, Ca
    Mine doesnt come on anymore I re-wired everything because the spring in the old switch broke and I didnt connect that LED light back up.
  16. Sep 24, 2014 at 9:13 AM
    #416
    Sandman614
    Tim
    '06 SR5 Off Road
    I still prefer to run a relay. Though the pump is only rated at 20 amps. I have a similar switch here and it says it's rated for 30 amps. That should be ok then.
  17. Sep 24, 2014 at 9:23 AM
    #417
    adriancast
    Adrian
    Ontario, Ca
    ok. thanks.
  18. Sep 24, 2014 at 9:30 AM
    #418
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I would consider at least a breaker then. Since you don't always need the compressor to run, I'd leave it off so as to not wear it out prematurely.
  19. Sep 24, 2014 at 10:35 AM
    #419
    Sandman614
    Tim
    '06 SR5 Off Road
    It'll be switched off, I assume Lol.
  20. Sep 24, 2014 at 11:28 AM
    #420
    adriancast
    Adrian
    Ontario, Ca
    I was confused for a sec but what sandman said. It will be off. I just use when I go off-roading or airing things up. I just hate getting out of my toolbox everytime. Just wanna lift hood, hook up to what needs air and turn on.
