OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Aug 25, 2015 at 5:47 AM
    #501
    Spencer
    Spencer Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    I wouldn't bother. As long as you religiously pop your drain valve to blow out the damp air and condensation when you get home every time it'll last longer than your truck.
    And on the other hand, even the cheapo harbor freight tank that my father in law has been using for the past 7 or 8 years had NEVER been drained! Can't blame him for not knowing, but when I popped it open after using it I blew a gallon or so of rusty sludge out. Not saying I trust his tank anymore, but you'll be fine with the relatively light duty yours will see.
  2. Aug 25, 2015 at 9:09 AM
    #502
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I used a similar tank for about 8 years on my OBA setup, and never got a drop of anything out of that drain plug. :confused:
  3. Aug 26, 2015 at 7:37 AM
    #503
    Spencer
    TIGGLEBITTIES
    Either you're in az or somewhere with zero humidity, (then awesome!)
    Or, like the tank that had never been drained I had, shards of rust settled over the hole in the tank. I opened it and nothing at all came out even at 100 psi. Shook the hell out of it and it projectile vomited rusty shit everywhere. If you open em under 0 psi, that's often the case. Gotta be fully pressurized when you open it.
  4. Aug 31, 2015 at 5:19 PM
    #504
    InTheRough
    InTheRough Well-Known Member
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    I just had to replace a bunch of the cheap hoses that I installed for the OBA. I also removed the wheel well quick disconnects since I hardly used them and I could just use a short extension. I am also remaking/upgrading the gauge/regulator panel in the bed.
    The hose that I used was a bit more expensive (mostly because of the barb fittings) but it is rated at 300psi and the barbs bite so hard that you don't need to use hose clamps. I wrapped the hose in a protective casing to protect it as well.
    Crom likes this.
  5. Sep 11, 2015 at 7:16 PM
    #505
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I've read this whole thread, all 26 pages. I have one question. What's the fastest +12v pump money can buy?
    All I'm doing is airing up 33" tires, and I don't care how much it costs, just want the fastest pump.
    It looks like the ARB dual and the Zenith were pretty close on CFM, with the ARB taking a slight lead...
    Nate87 likes this.
  6. Sep 11, 2015 at 9:16 PM
    #506
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    Pretty sure viair has a faster pump
  7. Sep 11, 2015 at 9:18 PM
    #507
    Crom
    Nick
    San Diego, CA
    Millions
    Okay. Do you know which one by chance?
  8. Sep 11, 2015 at 9:22 PM
    #508
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
  9. Sep 11, 2015 at 9:24 PM
    #509
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Those systems are designed for air bags. They'll air up tires in a hurry
  10. Sep 12, 2015 at 12:42 AM
    #510
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    According to the specs the arb should be faster. The viair puts out 3.53 cfm at zero psi, and the arb 3cfm at 90 psi. Hell the smittybilt i've been using claims 5.65. It comes down to personal choice and where you plan to mount the compressor, and whether or not youre going to install a tank.
    Crom[QUOTED] likes this.
  11. Sep 12, 2015 at 6:44 AM
    #511
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks. No tank. Just want speed and performance. In this thread there are two members who are using belt driven compressors and that is awesome! But that's outta the equation for me as I'm unwilling to modify engine apparatus from stock.
    I also looked at Oasis, impressive! Their bottom range compressor is 62lbs. $1,500, but OMG it's a monster! 15CFM at 0PSI, 9CFM @ 50PSI, 8CFM @ 100 PSI! Wow!
    That's in another class altogether...
  12. Sep 17, 2015 at 6:32 AM
    #512
    Crom
    Nick
    San Diego, CA
    Millions
    How many are running a air dryer? I've only ever seen one and that was barlower's.
    If like to see more examples
  13. Sep 17, 2015 at 6:36 AM
    #513
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I plan to when I get my locker installed.
  14. Sep 17, 2015 at 8:11 AM
    #514
    Crom
    Nick
    San Diego, CA
    Millions
    Do you have a particular model dryer in mind?
  15. Sep 17, 2015 at 8:59 AM
    #515
    Crom
    Nick
    San Diego, CA
    Millions
  16. Sep 17, 2015 at 4:54 PM
    #516
    Sandman614
    Tim
    '06 SR5 Off Road
  17. Sep 17, 2015 at 5:17 PM
    #517
    2008taco
    chris
    san diego
    I do NOT recommend this. The 300 psi rating is at 80 degrees, and drops drastically above that. These little compressors can get very warm, and the air coming out can easily be 130 degrees. Iirc that lowers the rating to under 100 psi,and when pvc blow under pressure it becomes shrapnel.
    Tonkaman and G.T. like this.
  18. Sep 22, 2015 at 6:56 PM
    #518
    Poindexter
    Poindexter Well-Known Member
    north of Denali
    15 V6 auto 4x4 mag gray
    I need to find the hot setup to upgrade my ride rite air bag setup on the rear axle. I think the bags and brackets are fine for my application, and the rubing seems fine, but i am ditching the press fit connectors.
    While i have it apart should i upgrade the tubing to proper hose anyway?
    Is there a reliable wireless system i could run from my smartphone rather than run air lines in and out of the cab for in cab controls? Android\ galaxy 5 if it matters.
    Operating range -50dF to +80dF with 10 to 30psi typical.
    Thanks.
  19. Sep 23, 2015 at 7:27 AM
    #519
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    Seeing that it get -50 where you are at I would keep them
    In the cab. I would have recommended some air valves 1/2 that would open and close when voltage is applied like we use in the mini trucking world but with it getting that cold I have had mine freeze open and close when it got In The 20's.remember one to put air in and one to release. Both on a T fitting if you go that route. Here is a link for a wireless control but I don't know of any for a phone.
    http://m.autoanything.com/suspension-systems/air-lift-wirelessone-air-control-system
  20. Sep 25, 2015 at 7:58 AM
    #520
    Sandman614
    Tim
    '06 SR5 Off Road
