OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Sep 25, 2015 at 8:32 AM
    #521
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Does anyone have recommendations on a regulator?
  2. Sep 25, 2015 at 12:38 PM
    #522
    Sandman614
    Tim
    '06 SR5 Off Road
  3. Oct 8, 2015 at 8:33 AM
    #523
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
  4. Oct 8, 2015 at 10:34 AM
    #524
    Sandman614
    Tim
    '06 SR5 Off Road
    A quick update. I used loctite 545 on all of it, except the hydraulic fittings.
    Crom likes this.
  5. Oct 8, 2015 at 10:51 AM
    #525
    Sandman614
    Tim
    '06 SR5 Off Road
    Crom likes this.
  6. Oct 9, 2015 at 11:22 AM
    #526
    Crom
    Nick
    San Diego, CA
    Millions
    I'm thinking of two OB2 compressors with an air manifold, no tank right now. That would put out somewhere between 7 and 8.5CFM.
  7. Oct 9, 2015 at 2:22 PM
    #527
    G.T.
    G.T.
    CONUS
    Surprised no one here has mentioned 2WayAir systems yet.
  8. Oct 13, 2015 at 12:03 PM
    #528
    Sandman614
    Tim
    '06 SR5 Off Road
    Neat idea. I have some ideas that would make that system better. There have been homemade 4 tire fillup rigs posted, maybe in other threads though.
  9. Oct 15, 2015 at 4:23 PM
    #529
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    In prep to adding an arb locker im joining the OBA. Club.
    TomTwo likes this.
  10. Oct 18, 2015 at 9:36 AM
    #530
    dbrfan
    dbrfan Well-Known Member
    2015 DCSB 4x4 6SPD
    Hi everyone,
    I've been reading all the oba threads I can find, but haven't found any that locate an air tank under the bed on a stock truck and leaving the spare tire in place. It looked like post #447 by shreddindan did by locating closest to the bumper, but does the rod that drops the spare fit? It seems like the tank would block it. Thanks for any help, great info here!
  11. Oct 18, 2015 at 9:45 AM
    #531
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    it looks like he has his tank mounted more towards the passenger side of the bumper vice being centered. You can see the hole for the spare tire in the last picture
  12. Oct 18, 2015 at 2:10 PM
    #532
    dbrfan
    2015 DCSB 4x4 6SPD
    Thanks velillen! I just measured inside of axle to edge of hole for rod and it's only about 16"....so back to the drawing board. I might just have to go with a smaller tank; although, I did see a tank mounted parallel to the exhaust by the converter. I'm not sure I'm comfortable with compressed air by heat though. Any other ideas are much appreciated.
  13. Oct 18, 2015 at 2:15 PM
    #533
    Sandman614
    Tim
    '06 SR5 Off Road
    Is that mine you're talking about? My tank is up where the cubby was, shouldn't get hot up there.
  14. Oct 18, 2015 at 2:54 PM
    #534
    dbrfan
    2015 DCSB 4x4 6SPD
    It might hav been, but have lost track of the posts...need to start taking notes! I just measured under there though too and I can't find any length longer than 16" without obstructions. What size tank did you have?
    Thanks for your help.
  15. Oct 18, 2015 at 2:56 PM
    #535
    Sandman614
    Tim
    '06 SR5 Off Road
    Here you go
  16. Oct 18, 2015 at 3:46 PM
    #536
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Years ago (in an '84 4runner), I installed a 2.5 gallon tank in front of my spare tire, for the OBA system. There is a similar empty space in my Tacoma. Check it out.
  17. Oct 18, 2015 at 5:13 PM
    #537
    Crom
    Nick
    San Diego, CA
    Millions
    I just analyzed that space under the truck from when I can tell it appears I could fit a 3 gallon under the bed sides by the Cubbies that will fit by the rear shackle hangers
    It is possible to fit the 37 inch 2 gallon slim tanks on the bed sides above the wheel wells. I didn't really want to run multiple tanks for my setup.
  18. Oct 18, 2015 at 7:38 PM
    #538
    shreddindan
    shreddindan Well-Known Member
    Dan
    Victorville,CA and Essex,CA
    11 TRD Sport OFFROAD 4WD
    Black Diamond window tint on the front windows, sylvania silverstar head lights, sylvania silverstar fog light bulbs, tailgate lock, bed storage compartment locks, driver side mag light mount, additional bed D rings, console vault, pro comp lift kit 3" front 1" rear, BFG All terrains 275/70/17, n-fab Double Cab Wheel to Wheel nerf steps, satoshi grille, BAMF behind the grille light bar with 20" double row light bar, flow master exhaust, debased all the way around
    I have a 1.5 gallon tank mounted on the right side of the bed just above the shackles. it was a tight fit. its bolted to the bed and i got a 90* metal bracket from home depot that is bouted right behind the rear brake light and secures to the tank. my compressor is mounted also behind hte rear brake light. i can take a picture of it if anyone interested.
    ive been thinking about moving the air tank and compressor. I liked Sandman614's idea of where he mounted his tank; maye have to relocate it there and maybe above the tank mount the compressor.
    Sandman614 likes this.
  19. Oct 19, 2015 at 9:23 PM
    #539
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    Just finished this. Two gallon tank attached to the bed under the left side cubby.
    DDFC83FF-8EAA-419D-B5A9-890C2106ABF3_zps_2720863d2e69e0683de96729d717560d2300a8b4.jpg
  20. Oct 19, 2015 at 9:26 PM
    #540
    THE CALICO
    Colton
    Nashville
    Here is the cubby set up.
    59AD6BAA-6558-4A65-B63F-BB97879EDCEF_zps_32cb9f284925bd8e5e6de06d56b70ead77d54b04.jpg
    gaterose, KTJO 4x4, Pirhett and 7 others like this.
