OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Dec 18, 2015 at 11:37 AM
    #561
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    IIRC it should be the isolation switch. The other 2 should be the front and rear lockers.
    dakotasyota and Sandman614 like this.
  2. Dec 18, 2015 at 11:40 AM
    #562
    3milecreek
    3milecreek MtnGoat
    Stephen
    Barnwell SC
    Heavily Modified 94 Yota
    Never the same
    Subd. looking to build a future oba system out of a superflow mv50 and viair tank.
  3. Dec 18, 2015 at 11:50 AM
    #563
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    That's it.
    dakotasyota likes this.
  4. Dec 18, 2015 at 12:23 PM
    #564
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Thanks guys. And what's the ignition wire for? Is that power for the switch as a safety so the key must be turned?
  5. Dec 18, 2015 at 12:30 PM
    #565
    THE CALICO
    Colton
    Nashville
    Yeah it keeps the compressor from killing your battery.
  6. Dec 18, 2015 at 12:33 PM
    #566
    Sandman614
    Tim
    '06 SR5 Off Road
    RTFM lol
    Spencer likes this.
  7. Dec 18, 2015 at 12:34 PM
    #567
    THE CALICO
    Colton
    Nashville
    Lol
  8. Dec 18, 2015 at 12:37 PM
    #568
    dakotasyota
    Dakota
    Ellensburg, WA
    That's what I figured, just weird it doesn't have a fuse... I think my KCs do. I have that switch power ran to the battery. Now I gotta figure out where to splice this into
  9. Dec 18, 2015 at 12:47 PM
    #569
    THE CALICO
    Colton
    Nashville
    I tapped mine into the same wire from the headlights that the switch-pros instructions detailed. It was yellow I believe. I'm sure you can tap into something off the tail light.
  10. Dec 18, 2015 at 12:53 PM
    #570
    dakotasyota
    Dakota
    Ellensburg, WA
    Wait that doesn't make sense, that means you can only use your compressor with headlights on. I tapped the illumination wire to there, but I'm talking about the ignition wire...
  11. Dec 18, 2015 at 1:05 PM
    #571
    THE CALICO
    Colton
    Nashville
    Fuck I don't remember and I won't be around my truck for another two days. It may have been an add a fuse or something. If no one else can help once I get home I'll recheck my wiring.
    dakotasyota[QUOTED] likes this.
  12. Dec 18, 2015 at 1:11 PM
    #572
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    grab a ignition power wire off the towing hitch plug
  13. Dec 18, 2015 at 1:41 PM
    #573
    dakotasyota
    Dakota
    Ellensburg, WA
    There's nothing closer under the dash?
  14. Dec 18, 2015 at 1:44 PM
    #574
    Sandman614
    Tim
    '06 SR5 Off Road
    :ballchain::dancingbacon::evil:
    Grab a multi meter or test light and read that manual, ask for wiring diagrams, or hire someone to come help (pizza, beer, and a plane ticket works for me).
  15. Dec 18, 2015 at 1:49 PM
    #575
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    there is, where r u wiring this thing? there is a few slots behind the change drawer infront of the fuse box that are ket switch on and just use a tap a fuse for it.
  16. Dec 18, 2015 at 2:05 PM
    #576
    dakotasyota
    Dakota
    Ellensburg, WA
    Haha okay got it.
    Well the switch is gonna go right by my factory switches. Tap a fuse? Auto parts store have those?
  17. Dec 18, 2015 at 2:09 PM
    #577
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
  18. Dec 18, 2015 at 2:34 PM
    #578
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Yup I used what Gordi linked to do my switches as on with ignition. If I remember right I used the left most 2nd from the top fuse. You can get a good idea just by reading what the fuse is to know which to tap into. Plus if you mess it up withtbat tap a fuse it's quick to change
    Speedo likes this.
  19. Dec 22, 2015 at 6:01 AM
    #579
    CASHORT
    CASHORT Well-Known Member
    Cory
    Whidbey Island WA
    2006 Black Sand Pearl TRD Off Road 98k miles
    Custom shovel, axe, fishing pole holders, Lumber Rack
    Sub'd for a upcoming build.
  20. Jan 23, 2016 at 4:18 PM
    #580
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    Question for those that already have an OBA setup, Do any of you have a quick connect fitting inside your cab? If so, do you find it useful and those that don't, do you wish you had plumed one into the cab? Right now I have a quick connect fitting at the front and rear of the truck. I'm about to run some tiny air line through the cab for an air pressure gauge and was contemplating adding an air line in the cab. I think it'd be nice to have, but don't know if it's worth the hassle. Thanks. I'll try and post progress here soon.
    Where did you end up mounting your compressor? I got you covered and will update soon! If not, I think @IGGY has been working on an under hood mounting solution
