OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Jan 30, 2016 at 5:34 PM
    #601
    CaptainReverso
    CaptainReverso Well-Known Member
    Cory
    Gardena
    2015 TRD off road 4x4 DBL cab Magnetic Grey
    Off Road Stuff
    ok well i got it all mounted up but can not get the thing to turn on
  2. Jan 30, 2016 at 6:10 PM
    #602
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    Did you have the ignition wire connected?
    CaptainReverso likes this.
  3. Jan 30, 2016 at 7:47 PM
    #603
    CaptainReverso
    Cory
    Gardena
    Off Road Stuff
    :anonymous: that was it lol
  4. Jan 30, 2016 at 8:15 PM
    #604
    THE CALICO
    Colton
    Nashville
    Lol. It's a great feature, but a show stopper.
  5. Jan 30, 2016 at 8:16 PM
    #605
    CaptainReverso
    Cory
    Gardena
    Off Road Stuff
    no kidding lol im still tring to figure out where to tap in the dash lights wire
  6. Jan 31, 2016 at 4:23 AM
    #606
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    Since someone wanted close up picture I figured I'd post them up also. 2010 off road
    docloco likes this.
  7. Feb 7, 2016 at 7:09 AM
    #607
    MtnDesertTaco
    MtnDesertTaco Well-Known Member
    Utah
    2014 Spruce Mica, TRD Offroad, access cab,
    Looking for a little feedback, pros/cons. I have an ARB twin compressor I will be installing soon. Was thinking about cutting off the 2 40 Amp fuse holders and using an 80amp breaker instead. I spend lots of time in remote areas and don't want to rely on carrying extra 40 amp fuses. Probably will need to lengthen the harness for how I will be mounting and routing everything. Was thinking I could just add the breaker next to my Aux fuse panel, Driver side back of engine compartment, then just run a bigger gauge wire from my Aux battery to the breaker. Any thoughts? Thanks.
  8. Feb 7, 2016 at 7:34 AM
    #608
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    No that is a bad idea. Those 40amp fuses each serve one of the two compressors. Youd potentially damage them by not having the 40amp fuse for each one. One could be going bad and pull 40+amps which could damage it while the other one is only pulling 20amp so not enough to trip the breaker.
    You would be much better off having to 40amp breakers if you really wanted a breaker. Or you could just pick up two fuses and toss them in the glovebox and not worry about it. I havent really heard of anyone blowing fuses with these before
  9. Feb 7, 2016 at 7:40 AM
    #609
    MtnDesertTaco
    Utah
    Good points thanks. Hadn't thought of the situation if one failed. I was also trying to keep the fuse or breaker closer to the battery, figured I would need to relocate the 2 fuses anyway.
  10. Feb 7, 2016 at 7:57 AM
    #610
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Theres no problem relocating the fuses closer. Just dont combine them into a single 80amp breaker is all.
    Bluesea does make a resetable 40amp breaker though!
    http://www.amazon.com/Blue-Sea-Syst...qid=1454860647&sr=8-2&keywords=blue+sea+40amp
  11. Feb 7, 2016 at 8:13 AM
    #611
    MtnDesertTaco
    Utah
    I had seen those. Just trying to keep the engine bay area wiring and additions as clean and tidy as possible. Had a good spot for adding one breaker but not two. I think I will just end up wiring along the front of the engine bay instead of the back and use the fuses. Pick up 2-4 extra fuses incase and be good. I have heard from other people that fuses don't blow very often with these compressors.
  12. Feb 7, 2016 at 8:33 AM
    #612
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Look around, there are several plates that mount over near the brake booster that have plenty of room for what you'd like to do. You can buy or build your solution.
  13. Feb 7, 2016 at 8:42 AM
    #613
    MtnDesertTaco
    Utah
    I was thinking of the Pelfreybilt style plate which has room for 2 breakers. I already have a home made plate that fits just one which goes to my Aux fuse panel, I could easily make a new plate that fits 2. In the future I'll probably upgrade to a Bussman setup just don't have the $ now.
  14. Feb 7, 2016 at 1:42 PM
    #614
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
    Finished my setup today. Twin arb compressor mounted where the side cubby was. Cover still fits with slight modification. Homemade hinged swing down mount for the tank, and homemade manifold for the front locker.
    MJonaGS32, Crom and bogginator like this.
  15. Feb 7, 2016 at 4:30 PM
    #615
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    What are you using to hold the tank in?
  16. Feb 7, 2016 at 4:36 PM
    #616
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I like it. :)
    916TacoTruck[QUOTED] likes this.
  17. Feb 7, 2016 at 4:39 PM
    #617
    916TacoTruck
    Inyo mom
    2019 Rapturd
    Thanks man.
    Crom[QUOTED] likes this.
  18. Feb 8, 2016 at 12:52 PM
    #618
    916TacoTruck
    Inyo mom
    2019 Rapturd
    Sorry, I didn't see your post. I used 1/8" thick strip steel that I shaped to the tank. I used rollers from a atv winch for the swing down that's welded to angle iron. The angle iron is welded to the spare tire support.
    Crom likes this.
  19. Feb 10, 2016 at 5:09 PM
    #619
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    How are people mounting quick disconnects to your bumpers? Can you drill a whole in the bumper and use some type of bulk head fitting to tighten it up?
  20. Feb 10, 2016 at 5:13 PM
    #620
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    I just got some 1/8" aluminum, cut it to a small length, drilled a hole through it in two spots, undid a bolt and attached it, then attached a QD.
