OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Apr 5, 2016 at 7:45 PM
    #741
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    I honestly don't remember the total cost. The compressor was $515ish, I think the tanks was like 40 and 30$ for the Viair kit. Plus the plumbing.
  2. Apr 8, 2016 at 2:35 PM
    #742
    Large
    Large Red
    Anyone give me a tip on how to mount the chuck to a plate bumper? I am out of thread on my fittings
  3. Apr 8, 2016 at 2:41 PM
    #743
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Also having trouble with this. Used a adapter with more thread and it leaked....without it I didn't have enough thread lol
  4. Apr 8, 2016 at 2:42 PM
    #744
    anthony250f
    Anthony
    San Diego, CA
  5. Apr 8, 2016 at 2:50 PM
    #745
    anthony250f
    Anthony
    San Diego, CA
    I tried going through 1/4" plate...would work with 1/8" easy
  6. Apr 8, 2016 at 2:53 PM
    #746
    Large
    Large Red
    My chucks look a little different I think. THey have a male end with about 3/4" of thread showing, I ordered some thin lock nuts to see if I can get them mounted and not have them leaks. We will see next week lol
  7. Apr 8, 2016 at 2:55 PM
    #747
    anthony250f
    Anthony
    San Diego, CA
    I used female quick disconnects with male barb going through the plate
  8. Apr 8, 2016 at 2:55 PM
    #748
    anthony250f
    Anthony
    San Diego, CA
    My first test of my oba blew the air hose right by the conpressor lol. Got too hot
  9. Apr 8, 2016 at 3:07 PM
    #749
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Gotta have that leader to let it cool. But that means no leaks right??!!
  10. Apr 8, 2016 at 4:30 PM
    #750
    anthony250f
    Anthony
    San Diego, CA
    I just got the loctite so gonna try that soon! I had it close enough to where j could use it.
    I have thick red 300 psi hose I was gonna replace it with... Think that would be ok?
  11. Apr 8, 2016 at 4:34 PM
    #751
    Sandman614
    Tim
    '06 SR5 Off Road
    If you're connecting it to a barb any of it will stretch and come off. Best bet is high temp or steel braided.
  12. Apr 8, 2016 at 4:45 PM
    #752
    anthony250f
    Anthony
    San Diego, CA
    I have probably 4 feet from the conpressor to the manifold. The hose may be high heat I don't remember. I used barb with tight hose clamps
  13. Apr 8, 2016 at 4:50 PM
    #753
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I used a bulkhead fitting for my quick connect on my bumper. Found one with female 1/4 NPT threads, and a PTC 3/8" for my air hose. You should be able to find a bulkhead fitting for whatever you're using.
    http://www.amazon.com/MettleAir-MTM...&redirect=true&ref_=oh_aui_detailpage_o05_s00
    I've seen people just thread their connects together right though a piece of metal, but I don't see how that could work without leaking, or without the fitting being loose.
  14. Apr 8, 2016 at 4:53 PM
    #754
    anthony250f
    Anthony
    San Diego, CA
    It worked for one of mine. Used washers
  15. Apr 11, 2016 at 11:06 PM
    #755
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Any suggestions on a hose for a 15 lb tank?
  16. Apr 12, 2016 at 9:19 AM
    #756
    klikboom
    klikboom Well-Known Member
    SNOHOCO
    Taco
    My AC system has a phantom leak the shops can't find it which I assume means the evaporator behind the dash... So I'm looking at using the stock AC comoressor with oiler before and filter after. Anyone have a link for this being done on 2nd gen? I see lots of threads but it sounds like they're adding a comoressor not reusing the stock one on the 4.0 v6.
  17. Apr 12, 2016 at 10:10 AM
    #757
    G.T.
    G.T.
    CONUS
    @rockgecko03 did and I'd like to follow in his footsteps.
  18. Apr 12, 2016 at 12:47 PM
    #758
    klikboom
    SNOHOCO
    Taco
    He used a york though. It's tough to tell did he mount in place of stock conpressor?
    I'm askin about reusing the stock compressor...
  19. Apr 12, 2016 at 8:58 PM
    #759
    fishfinder
    fishfinder Whoever dies with the most toys wins
    Mikey
    Santa Barbara
    2015 MT DCLB
    CBI armor, Kings, 35s, Lockers
    I've been working on installing my portable compressor as a permanent OBA setup, and made some more progress today. Got everything mounted, now just need to plumb the lockers and wire it up! I ran a stainless steel hose from the compressor, through the wall of the plastic compartment into the other side, to the tank. The manifold is plumbed directly from the tank. I need to re-wire the harness a bit, because the portable compressor's wiring is a bit different (pressure switch and relay are inside the compressor housing). Should get the wiring done tomorrow, and plumbing done by this weekend, looking forward to testing out these lockers!
    [​IMG] [​IMG]
    lpfe42 and Crom like this.
  20. Apr 12, 2016 at 9:08 PM
    #760
    anthony250f
    Anthony
    San Diego, CA
    Looks great!! I need to finish mine! Lol
