OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Oct 12, 2016 at 3:18 PM
    #941
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Yeah... and when it does go, it is loud.
    Correct, from the chuck to the tool, not a problem. I ran stainless all throughout to the Peterbilt fan clutch switch. Exiting the slider, 3/8" ID rubber fuel line to the chuck. I use the supplied ARB chuck and orange line for my tire gauge and air tools.
  2. Oct 12, 2016 at 3:19 PM
    #942
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  3. Oct 12, 2016 at 3:20 PM
    #943
    Ritchie
  4. Oct 12, 2016 at 3:21 PM
    #944
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Sandman614[QUOTED] likes this.
  5. Oct 12, 2016 at 3:26 PM
    #945
    Sandman614
    Tim
    '06 SR5 Off Road
    Here's the tank Install, looking for latest pics of compressor.
  6. Oct 12, 2016 at 3:28 PM
    #946
    ramonortiz55
    Ramon
    Texas
    stock
    and since there is a swivel union on the end, this will reduce the amount of fittings I need to run regular hose. Ill just thread it directly into the compressor and directly into the tank.
    Ritchie and Sandman614 like this.
  7. Oct 12, 2016 at 3:32 PM
    #947
    Sandman614
    Tim
    '06 SR5 Off Road
    Hell it was easier to go out and take a few shots.
  8. Oct 12, 2016 at 3:44 PM
    #948
    Ritchie
    Nice stuff there.
    Does the black line get close to any heat from the exhaust?
  9. Oct 12, 2016 at 4:22 PM
    #949
    Sandman614
    Tim
    '06 SR5 Off Road
    Yea, it dives down near the manifold, but tucked against the fender liner, but it doesn't get too hot.
  10. Oct 12, 2016 at 7:03 PM
    #950
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    What thread your guys think this is?
    The green arrow. It's next to 1/4" NPT for reference.
    I'm guessing 1/8"???
    Came off my ARB air chuck.
    I may call ARB. I'm trying to upgrade the business end. But I don't think it's removable from the stainless hose.
  11. Oct 12, 2016 at 7:07 PM
    #951
    Sandman614
    Tim
    '06 SR5 Off Road
    Probably 1/8 BSP
    I take it you're replacing the line? Was it an Open flow air chuck vs a closed flow?
  12. Oct 12, 2016 at 7:12 PM
    #952
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
  13. Oct 12, 2016 at 7:23 PM
    #953
    ramonortiz55
    Ramon
    Texas
    stock
    which tee do you recommend for this?
  14. Oct 12, 2016 at 7:24 PM
    #954
    ramonortiz55
    Ramon
    Texas
    stock
    i like these, any issues with the fittings?
    link of the black air line you used?..
  15. Oct 12, 2016 at 7:30 PM
    #955
    Squeaky Penguin
    Brett
  16. Oct 12, 2016 at 7:31 PM
    #956
    ramonortiz55
    Ramon
    Texas
    stock
  17. Oct 12, 2016 at 7:36 PM
    #957
    ramonortiz55
    Ramon
    Texas
    stock
    found a tee
    Sandman614 likes this.
  18. Oct 12, 2016 at 8:27 PM
    #958
    Sandman614
    Tim
    '06 SR5 Off Road
    As long as it's the configuration you want it'll do the job.
  19. Oct 12, 2016 at 9:03 PM
    #959
    Crom
    Nick
    San Diego, CA
    Millions
    The ARB air chuck is a little too cheap. I'm trying to upgrade the end that clips on the valve stem. As seen in the photo, I can remove the stainless hose, but the ends are crimped and not serviceable, so yeah, need to find new line with right thread, AND will work with 1/4 NPT.
    I might go full custom if I have to...
  20. Oct 12, 2016 at 10:00 PM
    #960
    Ritchie
    All,
    Be careful using 1/8" threaded fittings w/ ARB components.
    I actually ordered the 90 exiting my ARB manifold from a place I can't recall but the fitting came from Poland. Damn thing was $27.00 US.
    The difference in the fittings is the thread pitch... one is @ 45 degrees, the other is 55 degrees. I don't remember which is which but a place that sells hydraulic & AN fittings can tell you.
    I know this because I f'd up my manifold and had to purchase a second. No pipe dope or thread sealant could eliminate the small leak.
    Good luck.
    Crom, jubei and ramonortiz55 like this.
