OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Oct 13, 2016 at 6:02 AM
    #961
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    keep me updated on this. I am curious as well
    Crom[QUOTED] likes this.
  2. Oct 13, 2016 at 7:55 AM
    #962
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    1/8 bsp male to 1/4 npt female adapter, then use the 1/4 npt stainless leader hose from viair?
    http://m.ebay.com/itm/BSP-NPT-Adapt...n-in-Brass-European-to-American-/111932785640
  3. Oct 13, 2016 at 7:57 AM
    #963
    ramonortiz55
    Ramon
    Texas
    stock
    Sandman614[QUOTED] likes this.
  4. Oct 13, 2016 at 8:15 AM
    #964
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Roger that.
    Thanks! Good find, that's a candidate. It's just a gamble whether it's BSP or NPT. I think 1/8" is right.
    I was going to order this 1/8" NPT male, to 1/4" hose barb for $1.62 and try it.
    I really want to know before I buy. I'll try ARB and see what they say.
    I just ordered the $1.62 part and will try. I'll send it back if it doesn't work.
    Thanks
  5. Oct 13, 2016 at 8:54 AM
    #965
    ramonortiz55
    Ramon
    Texas
    stock
    For $1.62, its worth trying out. :)
  6. Oct 13, 2016 at 6:03 PM
    #966
    2X4TACOMA
    2X4TACOMA Well-Known Member
    Pyrite Mica 2010 Tacoma 4x4 Off Road
  7. Oct 13, 2016 at 7:40 PM
    #967
    2X4TACOMA
    Why is that? Did you have problems with the MV90? Or just decided to upgrade?
  8. Oct 17, 2016 at 4:30 PM
    #968
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    The ARB twin should have come with 4 bolts for the compressor. But if not, I believe M6 1.0 should work. This was based off a conversation with @Crom He may be able to verify.
    Crom likes this.
  9. Oct 17, 2016 at 5:50 PM
    #969
    Crom
    Nick
    San Diego, CA
    Millions
    Correct. My notes said M6 x 1.0. I found them at AutoZone, class 10.9 in zinc Dichromate finish, looks like gold. :)
    Jim Bob likes this.
  10. Oct 19, 2016 at 6:52 AM
    #970
    Sandman614
    Tim
    '06 SR5 Off Road
    Is this done yet?!?
  11. Oct 19, 2016 at 6:52 AM
    #971
    ramonortiz55
    Ramon
    Texas
    stock
    :spy:
  12. Oct 19, 2016 at 12:49 PM
    #972
    ramonortiz55
    Ramon
    Texas
    stock
  13. Oct 19, 2016 at 3:03 PM
    #973
    Crom
    Nick
    San Diego, CA
    Millions
    1/8" NPT is wrong. I should have tried BSP thread like you suggested. So, I have a 1/8" BSP male to hose barb fitting coming to me on the slow boat from China.
    I expect this one to work. Hope it arrives before my next trip. :rolleyes:
  14. Oct 19, 2016 at 3:05 PM
    #974
    ramonortiz55
    Ramon
    Texas
    stock
  15. Oct 20, 2016 at 8:50 AM
    #975
    Crom
    Nick
    San Diego, CA
    Millions
    No. I don't think that will work with the ARB air chuck. I could be wrong, but I don't think there is enough room to adapt on the manifold. I went with this:
    8mm OD Hose Barb 9.5mm 1/8BSP Brass Coupler
    https://www.amazon.com/gp/product/B00W8TTHSM/
  16. Oct 20, 2016 at 9:40 AM
    #976
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    This is more of a FYI in case anyone else is doing something similar
    I run my rear locker off my OBA set up with a pressure regulator right next to the ARB solenoid. I was wondering why my cab was starting to smell like gear oil. Come to find out that my ARB air line is acting like a secondary extended diff breather (which I already have - extended to the gas door) and gear oil was leaking through the solenoid and all over my stuff. I just ordered a ball valve lever that I'll be putting in-line right before the solenoid and just flipping it on when I'm on the trails. Hopefully that will limit how much gear oil travels upward into the solenoid.
    Speedo and Crom like this.
  17. Oct 20, 2016 at 12:55 PM
    #977
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I read (online) that there are seals in the diff that are supposed to prevent the air line getting contaminated with oil.
    The seal has gone bad, or installation error.
    ramonortiz55 likes this.
  18. Oct 21, 2016 at 6:55 AM
    #978
    Sandman614
    Tim
    '06 SR5 Off Road
    I had a similar issue except my tank was being filled with gear oil... ECGS did a warranty job on it and said the seals were installed correctly , checked everything else and said it was all correct too. I think the ARB design just isn't leak proof and the locker act as a suction somehow. When I disconnected the air line from the diff and drove around there was still oil being pushed out.
    MJonaGS32[QUOTED] and Crom like this.
  19. Oct 24, 2016 at 3:14 PM
    #979
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I need to inspect mine as I installed mine pretty much the same way in the same location, I thought I got a hint of gear oil smell the other day.
  20. Oct 24, 2016 at 3:17 PM
    #980
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    they changed the design on them a yr or so ago to prevent this maybe he has the old design or the new design didn't fix the problem.
