OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Nov 8, 2016 at 8:40 AM
    #1001
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Are the valve stems on the 4runner like the TPMS factory ones on our trucks?
    If they are, the brass fitting on the Powertank looks identical to the one I just tried on my modified ARB. It was a "CTA Tools 1930 Straight Lock-On Air Chuck"
    I had the same issue. When I built it, it worked on my wife's Nisan fine, rubber valve stems I think. I tried it on the truck this weekend and I was like, this POS is getting sent back!
    Mr.PowerTrays likes this.
  2. Nov 8, 2016 at 10:09 AM
    #1002
    G.T.
    G.T.
    CONUS
    The problem is with where they placed the valve stem itself.
    183219d1449971748-sale-5th-gen-trail-pre_5c09de4888efc6d457bc0d303e253cfa34c17d98.jpg
    Picture swiped from an image search. See how it is recessed into that stylized lug? That opening is really quite small and limits the size of chuck that can fit into it. I think I'm going to buy her an inflator and change the chuck out to a round knurled slip locking type so that we don't have to rely on what I keep in my tool bag.
    Crom[QUOTED] likes this.
  3. Nov 8, 2016 at 10:16 AM
    #1003
    Crom
    Nick
    San Diego, CA
    Millions
    @G.T. Good to know. Thanks for the description and picture. :)
    G.T. likes this.
  4. Nov 16, 2016 at 10:55 AM
    #1004
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks! I bought the open version, and I like it a lot!
    Coilhose Pneumatics CH15A Open Lock-On Chuck, 1/4-Inch FPT, pictured on the left.
    I returned the one on the right as I was not happy with it.
    The Coilhose one works great, it has two pieces of metal which grip the valve stem making a really solid connection. The clip on one on the right, like the original ARB, only had one, and didn't work as well as I initially thought.
    I like the Open chuck vs. the closed chuck, because I can use the open version to blow dust off and out of my truck after finishing a trail in the desert.
    Final modified product.
    Thanks @Sandman614 for suggesting the Coilhose variant. :thumbsup:
  5. Nov 16, 2016 at 12:07 PM
    #1005
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    What's up with the tape?
  6. Nov 16, 2016 at 12:26 PM
    #1006
    Crom
    Nick
    San Diego, CA
    Millions
    Not a QD, it's an air chuck called Coilhose that looks like a QD.
    Here it is laid out:
    ARB tire inflator + 8mm OD Hose Barb 9.5mm 1/8BSP Brass Coupler + hose clamp + your longer air hose + barb to 1/4 MNPT + Coilhose air chuck.​
    Search back two pages in this thread for details, or build thread has it listed too.
    @ramonortiz55 tape is a safety feature, covers the stainless size 4 hose clamp that secures the hose to barb.
  7. Nov 16, 2016 at 12:35 PM
    #1007
    ramonortiz55
    Ramon
    Texas
    stock
  8. Nov 19, 2016 at 5:19 PM
    #1008
    2X4TACOMA
    2X4TACOMA Well-Known Member
    Pyrite Mica 2010 Tacoma 4x4 Off Road
    Just ordered this after trying to decide which one to get. It was between the Superflow MV90 and the Air Armor M240.
    I went with the Air Armor M240. Found a discount code here It says it ended but it just now worked for me. Its 80 bucks off.
    Thought id share.
  9. Nov 19, 2016 at 5:28 PM
    #1009
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Anyone tried a Vixen 200psi kit with a 3 gallon tank? It says air horns but shouldn't it work for tires to? And lockers with a regulator?
  10. Nov 20, 2016 at 5:46 AM
    #1010
    WhiteNight
    WhiteNight Well-Known Member
    PDX
    13 DCLB SPORT
    Dynamat, Rigid E series 30", Rigid SR2 combo/Rigid grill, Redline elite hood struts, Clear Bra all over
    What is the perk to mount here vs under the hood is it not noisy when filling the tank?
  11. Nov 20, 2016 at 6:10 AM
    #1011
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I'd say it's cleaner but judging by that picture lol. With the dual compressor filling a tank shouldn't take long. Also there's a lot of insulation because of the seat I would think it wouldn't be a problem.
  12. Nov 20, 2016 at 6:12 AM
    #1012
    WhiteNight
    PDX
    13 DCLB SPORT
    I guess I view it differently. Being a cdl driver it's weird not having a belt driven compressor. Even weirder for it to be located at the rear of the truck.
  13. Nov 20, 2016 at 7:56 AM
    #1013
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Keeping it clean and dry mainly. Also its incredibly hard to make a mount to fit it under the hood without relocating something. When I have it on to run the lockers it isn't too noisy because the seat back is blocking a lot and isn't running constantly. When I am filling tires it is loud but I also lean the back of the seat forward for more ventilation. Also I don't run a tank. Don't have a need big enough to spend the money for it
    Its inside the cab, behind my rear seat. The second place I would have put it is inside the bed side in the back.
  14. Nov 23, 2016 at 6:02 PM
    #1014
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    Questions:
    If one were to mount the ARB CMKTA12 On-Board Twin Air Compressor under the hood for a 2nd Gen taco (or even the single ARB CKMA12 Heavy Duty Air Compressor), would there be room to install a snorkel?
    Has anyone used the Slee Off-Road Tacoma Compressor Brackets for the 2005-15 Tacoma?
    Slee Off-Road–Tacoma Single Compressor Bracket (SOK-0002) – 2005-15 Tacoma
    <http://www.sleeoffroad.com/installation/2005-15_tacoma_compressor_bracket_v1.1.pdf>
    Slee Off-Road–Tacoma Twin Compressor Bracket (SOK-0001) – 2005-15 Tacoma
    <http://www.sleeoffroad.com/installation/2005-15_tacoma_twin_compressor_bracket_v1.1.pdf>
    If either of these were used, would it allow for a snorkel?
    It's difficult to tell from the photos on Slee Off-Road.
    My plan is to use the air compressor to inflate my tires after wheeling. Somewhere down the road, I may install a front locker...so, I'm thinking the twin would be the better option but space is the concern.
    Looking forward to your inputs.
  15. Nov 24, 2016 at 1:43 AM
    #1015
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    The Slee mount does not conflict with the OE airbox or intake tube
  16. Nov 24, 2016 at 1:57 AM
    #1016
    seoulja99
    E.J.
    Oahu
    For the OE airbox or intake tube, I understand. But what about a snorkel?
  17. Nov 24, 2016 at 6:33 PM
    #1017
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    a snorkel connects to the OE airbox amigo
  18. Nov 24, 2016 at 6:42 PM
    #1018
    seoulja99
    E.J.
    Oahu
    Ok. Thanks!
  19. Dec 7, 2016 at 7:54 PM
    #1019
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Good info in here. :thumbsup:
  20. Dec 29, 2016 at 12:28 PM
    #1020
    seoulja99
    E.J.
    Oahu
    I installed the single ARB CKMA12 Heavy Duty Air Compressor, mounted it with the Slee Off-Road–Tacoma Single Compressor Bracket (SOK-0002) in my hood.
    Now, I want to relocate the air source (quick connect/disconnect) to the rear of the taco. In order to do so, what are the exact parts I will need to buy at the hardware store (or online)?
    From the list of products discussed in this thread (at the bottom of the pages), would these apply for my situation?
    1. 12" or longer stainless steel braided leader hose without check valve -- to connect directly to the air compressor between the T-fitting and the pressure switch?
    2. MettleAir MTMF 3/8-N02-1PK Push to Connect Straight Bulkhead Female Fitting, 3/8" OD, 1/4" NPT? -- only 1, or will I need 2? Or one Female and one male?
    3. One of these air lines?
    a. 50' Roll of Power Products 3/8" OD Black Nylon Air Brake Tubing SAE J844,
    https://www.amazon.com/dp/B00CMTJQX4 - $43.55
    b. ATP Value-Tube LDPE Plastic Tubing, Black, 1/4" ID x 3/8 OD, 100 feet Length
    https://smile.amazon.com/dp/B000R87R4C - $15.44
    c. 1/4" OD x 50' SAE J844 Nylong Air Brake Tubing Suspension Horn Train Lowrider
    https://smile.amazon.com/dp/B00CLXGHQU - $20.49
    d. ARB 170301 Engine Air Intake Adapter (blue)
    https://smile.amazon.com/ARB-170301...rd_wg=ofrJm&psc=1&refRID=K5DZQVW6NF3A7Q2GPEFV
    4. Fittings:
    a. 90 degree brass pipe fitting street elbow, 1/4" NPT Male x 1/4" NPT Female -- two of these, one towards the air compressor, and the other at the rear end of the truck?
    5. Quick connect/disconnect
    Or can I just use the Viair 90007 Air Source Relocation Kit? Would it be compatible with the ARB fittings/hardware?
    Note: I also bought the ARB inflation accessory kit (orange air hose and parts) and the ARB blue inflator with gauge and braided hose. I'm trying to avoid having to open up my hood every time I need to inflate my tires using the air compressor. TIA.
