OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Jan 7, 2017 at 8:40 AM
    #1021
    Squishy!
    Squishy! Member
    @themightyredchili
    Just about everything, but enough to do to keep me poor
    Nicely done indeed. This is the exact approach I'm taking on my 3.4 swapped 1st gen Runner. It looks like you are running 1/4" air line. If so, are you happy with the rate of flow, or if not is there any issue running 1/4" line on that compressor? Considering that an A/C compressor is typically pressurizing against a tiny expansion valve, I wouldn't think so, but lets see what y'all have to say about it.
  2. Jan 7, 2017 at 9:15 AM
    #1022
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Everything is 3/8" line, minus the guage. Flow rate is great, with the heavier line as well helps with the heat coming from the compressor.
    seoulja99 likes this.
  3. Jan 7, 2017 at 3:53 PM
    #1023
    Squishy!
    Squishy! Member
    @themightyredchili
    interesting. I cant seem to find a 3/8 manifold like that, only 1/4", but it definitely was a great tip for this build. Where did you source all your parts? Amazon seems to have most things, but damn the brass fitting are expensive there...
  4. Jan 7, 2017 at 7:21 PM
    #1024
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    http://m.ebay.com/itm/162313940576
    Ebay and Amazon is where I sourced 95% of the parts. A few were from my local Ace hardware.
    Certain parts I used from Viair for piece of mind.
  5. Jan 30, 2017 at 9:37 PM
    #1025
    HABOOBS
    HABOOBS Well-Known Member
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Alright... So I need some input fast... I'm currently working with Sierra Expeditions on installing an ARB Dual Air Compressor into the truck... I wanted to find room under the hood, but thats a no go. Then I wanted it behind the rear seat but was worried about the noise factor. So their solution was to put it underneath mounted to the frame rail... Initially I didn't think anything of it since the ARB system has an intake that can be relocated as necessary but now I am second guessing this route all together... Why? H20!!!
    They've already made a pretty bad ass mount/box to protect the compressor but I'm worried about any major water crossing (especially while running a locker - If I ever install one). The box/mount is located just in front of the rear crossmember and is definitely not water tight/proof but it is strong enough to resist minor impacts (plus there are other points on the truck that would hit rocks first). I'm just worried about water... Should I be worried about this location? Am I being overly cautious here? They want to finish up this project tomorrow and I am now questioning their chosen design. See pic...
    Anyone ever have issues with these underneath? Fast input would be hugely appreciated...
  6. Jan 30, 2017 at 9:52 PM
    #1026
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    I'm no expert, but I wouldn't want mine there. Deep water could fully submerge it, and it just doesn't sound like a good idea to me. Not sure how it much the compressor would like that. Imagine your compressor that low on the truck in a situation like this.:notsure:IMG_3551.jpg IMG_3552.jpg
    I know @Nate87 mounted his under his bed and @916TacoTruck has his mounted in his bedside where the storage cubby was and they worked fine. Maybe they can chime in.
    Is a small box somewhere in the bed out of the question?
    Good luck
    Pirhett and 916TacoTruck like this.
  7. Jan 30, 2017 at 9:57 PM
    #1027
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Yeah right!? I agree... I'm a bit surprised Sierra Expeditions suggested this spot... it just doesnt seem smart...
    Even under the bed it would be higher up and better than where it is now but still exposed in deep water...
    And yeah there is no way I'd consider loosing more bed space... so a small box is out of the question...
  8. Jan 30, 2017 at 10:01 PM
    #1028
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Not an ARB, but I plan on mounting my Viair 444c on the side of the bed tub between the tub and the bedside. Going to make a L mount to spread the load a bit on the tub and will put a backing plate on the inside of the bed. Will use a similar setup to mount the 2 gallon tank.
  9. Jan 30, 2017 at 10:16 PM
    #1029
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    I'm pretty sure the slee mount doesnt work with my CAI... Plus I'm still a little unsure how the relocation of the PS fluid works.
  10. Jan 30, 2017 at 10:17 PM
    #1030
    tacomgee
    Blake
    NorCal - Ukiah
    That turned out great! :thumbsup:
    Jim Bob likes this.
  11. Jan 30, 2017 at 10:25 PM
    #1031
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Right? And here I kept iterating my concern about the elements... I think I'll look into another location... UGH... time/money wasted.
    Perhaps the slee mount idea can work after all. Thanks for the input.
  12. Jan 31, 2017 at 7:04 AM
    #1032
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
    I HAD mine mounted in the bedside where the cubby is. I never had any issues with the compressor working while mounted there. However, it gets real dirty and caked when wheeling. I am going to move it to a tool box in the bed similiar to what @tacomgee has.
    tacomgee likes this.
  13. Jan 31, 2017 at 1:35 PM
    #1033
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    So I talked with ARB this morning... It appears a ton of jeep guys have no problem mounting their compressors on the frame rails. The units are designed to put up with the elements (including water submersion and dust/dirt) as long as the intake is mounted somewhere safe. Between that and the box mount that SE made for me I've decided to stick with the location for now. Hell, it's got a 3 year warrantee so by then I'll put it through plenty of abuse to see how well it holds up. Now my only obstacle is making a Pelfreybilt Rear Skid fit down the road... Haha fingers crossed.
    916TacoTruck likes this.
  14. Jan 31, 2017 at 6:15 PM
    #1034
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    No issues with it under the bed. With the lift and tires I had, it was a good 4 feet off the ground. Plenty high and out the way. If any crossing come up, just make sure it's off.
  15. Jan 31, 2017 at 8:18 PM
    #1035
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Good to hear... Well and what compressor were you running? The more research and thought I've put into this the more I've been able to justify the location mainly because its an ARB product.
  16. Jan 31, 2017 at 8:26 PM
    #1036
    tacomgee
    Blake
    NorCal - Ukiah
    ARB twin
  17. Feb 2, 2017 at 6:54 PM
    #1037
    jamiec
    jamiec Man who keep hands in pockets feel cocky all day
    Jamie
    Chillicothe, Ohio
    2017 Prius three touring. Sold the Taco
    I'm about to tackle the onboard air myself. I have a train horn kit coming and in the future I'll add belayer bags in the rear.
    Subbed
  18. Feb 2, 2017 at 9:34 PM
    #1038
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    What horn kit did you go with? Where are you mounting your OBA?
  19. Feb 2, 2017 at 9:39 PM
    #1039
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    ObA is next on my list.
    Ordering the Slee Mount for my 5th gen and an arb single compressor. Gonna have it to fill up tires, run a rear locker, and pressurize a shower system.
  20. Feb 2, 2017 at 11:12 PM
    #1040
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I don't see the reason to spend double for something that does all the same things. It just airs up slightly faster. Anything will be better than the 15 dollar compressor I bought on Amazon and I'm pretty happy with how fast it airs up my tires.
    Is there a reason other than faster airing up?
