OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Dec 10, 2013 at 10:29 AM
    #101
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Crom likes this.
  2. Dec 10, 2013 at 10:33 AM
    #102
    skygear
    skygear                    
    You are right. I only quote my 0 rating.
  3. Dec 10, 2013 at 10:34 AM
    #103
    skygear
    skygear                    
  4. Dec 10, 2013 at 10:37 AM
    #104
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    The ARB and Air Zenith are 100% cycle. Not trying to bash the ARB, very sweet all inclusive plug and play set up. But there are better alternatives that you can customize to your needs for a better bang to buck performance ratio.
  5. Dec 10, 2013 at 10:43 AM
    #105
    skygear
    skygear                    
    what is the max PSI? on those?
  6. Dec 10, 2013 at 10:48 AM
    #106
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    its a way better performance than my viair i had
  7. Dec 10, 2013 at 10:48 AM
    #107
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    150PSI max ARB
    200PSI max Air Zenith
    So that will play a part in set ups, especially with tanks. If you wanted to do the math, to see the differences go for it. I'd be curious, ambient temp like 75 degrees at sea level per gallon. I hate math.
    pa Va = pc Vc
    pa = atmospheric pressure (14.7 psia, 101.325 kPa)
    Va = volume of the gas at atmospheric pressure (cubic feet, cubic meter)
    pc = compressed pressure (psi, kPa)
    Vc = volume of the gas at compressed pressure (cubic feet, cubic meter)
  8. Dec 10, 2013 at 10:49 AM
    #108
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    What model Viar?
  9. Dec 10, 2013 at 10:53 AM
    #109
    wrmathis
    Bonaire, GA
    parts and stuff
  10. Dec 10, 2013 at 11:00 AM
    #110
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    No wonder! Apples to Oranges
    Viar 480c MAX CFM is only 1.76 @ 0 PSI.
    I wish I could find an actual table with ARB's specs. They have the graph which is not detailed enough to get actual specs. Typical deceitful product advertisements straight from the book. "as much as, as low as"
  11. Dec 10, 2013 at 11:05 AM
    #111
    wrmathis
    Bonaire, GA
    parts and stuff
    yeah i know. reason i went with the twin arb is just for use with arb locker (feel more comfortable using same company for everything) and to get more air than the viair. still have the air tank hooked up tho.
  12. Dec 10, 2013 at 11:30 AM
    #112
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    A quality set of hand tools should always be first priority. I do find situations where air tools would be nice. Especially when I am on my families hunting land. There is no power around and building tree stands and blinds can be a pain in the ass. Some of it can be done ahead of time, some of it cannot. Having the ability to run some tools would be sweet. Obviously air tools are a luxury, but time is precious. I don't want to spend all day ratcheting down bolts.
    Same thing with being out on a trail. Occasionally time isn't an issue, other times it is. The more I can accomplish with my setup the more I can justify the price.
  13. Dec 10, 2013 at 2:01 PM
    #113
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Hey all, just wanted to clarify. I currently have an OBA system and going to add my ARB locker to it. All I need is to get an inline regulator set to 90 psi from the tank to the locker, right?
  14. Dec 10, 2013 at 2:06 PM
    #114
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
  15. Dec 10, 2013 at 2:15 PM
    #115
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
  16. Dec 10, 2013 at 2:22 PM
    #116
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
  17. Dec 10, 2013 at 2:30 PM
    #117
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Yep, the ARB lockers come with solenoid valves. Just need to maintain their recommended pressure range for the air lockers.
    • Must supply a minimum of 85PSI [586kPa].
    • The supply must never exceed 105PSI [724kPa].
    • The Air source should have a tank capacity that enables it to
      actuate the Air Locker(s) in one charge so that no hesitation
      is experienced when locking one or two differentials.
    IMPORTANT :
    ARB cannot warrant your Air Locker(s) against damage caused
    as a result of using an alternate air supply. If you have any
    doubts as to the suitability of your air system to use in an Air
    Locker system, consult your ARB distributor.
  18. Dec 10, 2013 at 2:38 PM
    #118
    skygear
    skygear                    
    In defense of the VIAIR systems. They were designed to be a non failing point of most of these baggers systems. Reliable, Heavy duty, over built compressors in a small form factor, able to fit most applications.
  19. Dec 10, 2013 at 2:39 PM
    #119
    skygear
    skygear                    
    Are you referencing the ARB or VIAIR systems in this quote?
  20. Dec 10, 2013 at 2:40 PM
    #120
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    Reason I like it is because it's 100% duty cycle and nice CFM. And its a fraction of the price of an ARB.
