OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Aug 14, 2017 at 5:28 AM
    #1401
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    If you haven't figured it out don't just randomly start tapping wires to power.. There's a bit of sarcasm intended.
    Fosk[QUOTED] and JWROSE4 like this.
  2. Aug 14, 2017 at 5:34 AM
    #1402
    Fosk
    Fosk Well-Known Member
    Andrew
    Huntington Beach, CA
    That's the one I was using. I'll see if I can get a replacement from ARB, unless someone around here has one they didn't use, and follow which ones you tapped.
    JWROSE4[QUOTED] likes this.
  3. Aug 14, 2017 at 5:35 AM
    #1403
    Fosk
    Andrew
    I prefer to learn things the hard way, makes it stick better.
    hunter357mag, 2008taco and JWROSE4 like this.
  4. Aug 14, 2017 at 5:40 AM
    #1404
    Sandman614
    Tim
    '06 SR5 Off Road
    Electronic smoke is one you won't forget... that and gear oil.
    JWROSE4 likes this.
  5. Aug 14, 2017 at 6:43 AM
    #1405
    JoeySauce
    JoeySauce Well-Known Member
    Joe
    Eagle PA
    11 DCSB
    If you run your own lead straight to the battery you need to fuse it, I threw in a 5 since that was the smallest I had on hand.
    The compressor power has a built in fuse in the harness.
    Dash lights you can tap off a number of wires all depends on where you mount the switch.
  6. Aug 21, 2017 at 11:51 AM
    #1406
    amontances
    amontances Well-Known Member
    2017 White Tacoma OR
    TRD Pipes | 18" Fuel Assault | Roof Rack | Tint | Steps | Husky Floor Liners | Bed Liner | LED Interior Lights | Swing Arm Bed Storage |
    were there any other hardware you needed to buy to mount the ARB Dual Compressors inside the bed???
  7. Aug 21, 2017 at 11:52 AM
    #1407
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I've had that Dual ARB sitting in my garage for 18 months, lol.
    I have it planned out, just haven't installed it.
    itaro likes this.
  8. Aug 21, 2017 at 11:54 AM
    #1408
    amontances
    do you think the bed design is the same as the 3rd gen compared to yours? i have a 3rd gen and that's where i want to put my arb.
  9. Aug 21, 2017 at 11:55 AM
    #1409
    ramonortiz55
    Ramon
    Texas
    stock
    I have yet to see a 3rd gen bed up close and personal
  10. Aug 21, 2017 at 11:56 AM
    #1410
    amontances
    if you've had the arb for over 18 months, you want to sell it to me?
  11. Aug 21, 2017 at 12:00 PM
    #1411
    ramonortiz55
    Ramon
    Texas
    stock
    I new you were going to ask that.
    nope.
    Digiratus likes this.
  12. Aug 21, 2017 at 12:04 PM
    #1412
    ramonortiz55
    Ramon
    Texas
    stock
    itll get installed.
    Took me 3 years to install a molle panel behind the back seat, but I eventually installed it.
    Itll get done, along with all the other dozens of un-installed boxes with mods in the garage
  13. Aug 21, 2017 at 9:18 PM
    #1413
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I get this. :cool:
    ramonortiz55[QUOTED] likes this.
  14. Aug 25, 2017 at 7:51 PM
    #1414
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    I believe the composite is the same, only the bedsides changed
  15. Aug 26, 2017 at 7:38 PM
    #1415
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Finally got mine mounted using the Slee bracket. I wasn't going to need the switch in cab so I fabbed a bracket with a project box and mounted it under the hood. Good feeling when you hit the switch and sparks don't fly.
    Falldownhard, lpfe42 and rob1208 like this.
  16. Aug 26, 2017 at 7:48 PM
    #1416
    ramonortiz55
    Ramon
    Texas
    stock
    the nerve to be asked to sell my twin arb...
  17. Aug 28, 2017 at 1:39 PM
    #1417
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    How many Viair models are there and which one is the best. These sound like the best bang for the buck.
  18. Aug 28, 2017 at 3:54 PM
    #1418
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I have an 88p that i picked up for 50 bucks! Its good for up to 33 inch tires. Its just a portable one though
  19. Sep 6, 2017 at 4:58 PM
    #1419
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Long thread. I'll be doing something for oba soon but these are a few thoughts that flickered by while I was reading.
    I'm a carpenter not a mechanic and I have too much respect for the dude to impinge on his territory by mounting it in an already overcrowded and overheated engine bay so it's going to be mounted elsewhere. Leave unto Ceasar...
    The "air tools" I might run would be low cfm nailers and such, I already have plenty of 18v cordless tools so I don't need a high volume 100% duty pump.
    The main use is for the air bags which I will want to monitor while driving with a guage(s) and probably analog regulator mounted in the dash.
    For those two(neither of which demands hphv) I want to have a smallish tank for reserve air and an inexpensive modest pump, possibly mf1050.
    The truck is a 2wd mall certified DD so I won't be airing up air lockers or 33's but only the occasional mtb and hopefully much less occasional low or spare.
    I don't plant on hopping around like a jumping bean so it will likely have a 70-100 or 90-115 pressure switch and won't be hard lining anything, just braided leader and possibly additional heat sinking/surface area for the head since I won't be able to throw on a wet towel.
    Space is at a premium since I carry a lot of tools(hence the need for the bags) so it will probably end up in a location that isn't readily accessible but still accessible at need.
    Vehicle corners are out such as behind the tail light as are bumper mounted couplers, they're called bumpers for a reason, as is any location close to the tail gate which is reserved for accessing things I frequently access. The current options are in the under seat storage bin behind the driver, inside the bed wall forward of the wheel well, and inside the bed forward of the wheel well.
    Inside the bed wall conserves the most space and is less exposed than a corner but not greatly so, I've seen plenty of side-swipes munch this area without totaling the truck.
    Inside the cab in the storage bin shortens the power runs and possibly also the tank-regulator line but might have other problems I haven't sussed yet besides noise.
    My bed set up has a removable ~25/75 plywood platform split lengthwise that has slots in the dividing support wall for various length levels, Dewalt folding 6' saw stand on the drivers side, and a pulley mounted drawer I can haul up against the front wall(heavy) and shove saw horses behind(light). It's removable since I sometimes use one or the other piece of ply as an out feed for the table saw. It's not pretty but it works. This leaves access to the rear cubbies(no power inverter) but the areas in front of the wheel wells and below the ply are unused save when I empty the truck for bulk hauling. I could cut through the comp bed there to access the bed wall void or simply box one in there inside the bed(remember it doesn't have to run for long periods).
  20. Sep 10, 2017 at 6:25 AM
    #1420
    jc11taco89
    jc11taco89 Well-Known Member
    jon
    Naugatuck CT
    2011 Tacoma aclb 4wd
    3 inch toytec 5100 SPC uca's Pelfreybilt front plate bumper with center hoop Pelfreybilt rear plate bumper with swing out B.A.M.F. sliders with kick out Mobtown ifs and trans skid. 33's with rims that are to large.
    Hey all so I'm getting ready to order the single heavy duty ARB compressor and I'm wondering if an air pig(air tank) is necessary. Primarily I'll be using it to inflate the tires after wheeling but will also run at least a rear locker as well but that's a little ways away yet.
