OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Oct 6, 2017 at 9:38 PM
    #1441
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Depends on how much he likes to toot his horn but it's not static like a locker and each toot takes a bite. If it's just for normal horn use then it might last weeks but if it's the flight of the bumblebee then might not get through the day.
    Naveronski, Seity and Drainbung like this.
  2. Oct 6, 2017 at 9:40 PM
    #1442
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  3. Oct 13, 2017 at 11:12 PM
    #1443
    bagleboy
    Scott
    Norcal, Santa Rosa
    Mf -1050 is on sale at Amazon.
  4. Nov 9, 2017 at 7:04 AM
    #1444
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I got the ARB twin, and won't be running lockers.
    I want a simple switch next to the compressor.
    What's the easiest way to do that? Can I use the stock switch and harness without it being all crazy?
    Drainbung likes this.
  5. Nov 9, 2017 at 7:25 AM
    #1445
    Blackouts
    Blackouts Well-Known Member
    Las Vegas, NV
    2014 Tacoma TRD Off Road DCSB
    The harness that comes with the twin has extra stuff for lockers that you don't need.
    The twin has built in relays, so all you need to do is wire up the 10ga red wires to +12v on your battery, ground the 8ga black wire, and connect the small purple wire to your switch output.
  6. Nov 9, 2017 at 7:37 AM
    #1446
    Naveronski
    Fort Worth
    Thank you.
    My power harness is already all connected.
    I'm having a hard time picturing how just the purple wire getting power would turn on the compressor, but I'll try it when I get home.
  7. Nov 9, 2017 at 7:41 AM
    #1447
    Blackouts
    Las Vegas, NV
    The purple wire activates both relays.
    You do also need to wire up your switch of course.
    Naveronski[QUOTED] likes this.
  8. Nov 9, 2017 at 7:42 AM
    #1448
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    let me know how it works out.
  9. Nov 9, 2017 at 7:48 AM
    #1449
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Yes, I did the same thing with my single, switch is in a wee little box under the hood. Compressor is on a Slee mount.
  10. Nov 9, 2017 at 8:24 AM
    #1450
    Naveronski
    Fort Worth
    Okay, so switch still needs a "on with ignition" power.
    I was hoping to avoid that, but oh well.
  11. Nov 9, 2017 at 8:24 AM
    #1451
    Blackouts
    Las Vegas, NV
    That is optional. The switch needs power from somewhere, but it's up to you if you want it to be able to run with ignition or not.
  12. Nov 9, 2017 at 9:28 AM
    #1452
    Naveronski
    Fort Worth
    I like that, did you make the box?
  13. Nov 9, 2017 at 9:30 AM
    #1453
    bagleboy
    Scott
    Norcal, Santa Rosa
    A jumper from the 10 guage main power feed to the switch supply is all you need.
  14. Nov 9, 2017 at 10:54 AM
    #1454
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I bought a small electronics project box and made a backing plate to attach it to the fender well.
  15. Nov 9, 2017 at 1:28 PM
    #1455
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
  16. Nov 9, 2017 at 5:51 PM
    #1456
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    I know it’s not air related but what gauge wire did you run for the winch from the solenoids
    Was it a kit or did you just do it yourself?
  17. Nov 9, 2017 at 6:32 PM
    #1457
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I ran battery cable. Definitely not a kit. Ordered the cable and lugs and made to length.
    foxrcing07[QUOTED] likes this.
  18. Nov 9, 2017 at 8:09 PM
    #1458
    bagleboy
    Scott
    Norcal, Santa Rosa
    Fatter is better, winch power is related to how much current can be fed through those cables.
  19. Nov 9, 2017 at 9:05 PM
    #1459
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Most winches come with 4 gauge when new. Don't use anything less than that.
    When I moved my solenoid box to under the hood, I replaced all of that with 2 gauge welding cable.
  20. Nov 9, 2017 at 9:10 PM
    #1460
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    I was thinking 2 or 0
    I have a few other short runs that I want to redo that are currently 4
    I just wanted to be sure I didn’t need 00 or something heavier like that
