OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Jan 7, 2018 at 9:20 AM
    #1521
    dbrfan
    dbrfan Well-Known Member
    2015 DCSB 4x4 6SPD
    Hose and gauge setup to fill 2 or 4 tires at a time?
    I have read about these setups before, but I can’t for the life of me find them now. I would like to fab an in line gauge to let me know when the tires are full...any input or reference would be appreciated.
  2. Jan 7, 2018 at 2:17 PM
    #1522
    Traviste
    Traviste Now with more woopow
    Travis
    Georgia
    2014 DCSB Locked 4x4 Mid-Travel
    F:King 2.5 coilover resi ext 700#coils R:King 2.5 ext allpro expos
    I have run to approx 160 to test. Also it shouldn't turn on between 135-150 and it still does
  3. Jan 7, 2018 at 11:37 PM
    #1523
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Certainly sounds like somethings wrong. Either with the sensor or how it's connected.
  4. Jan 15, 2018 at 9:49 AM
    #1524
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I am currently running the Viair "constant duty" kit, which has been fine for me, if a little slow. I am looking at upgrading my oba setup, and was wondering if any of you guys with experience might have some input? I have a 2.5g tank.
    option A) quit whining, the 450c is fine
    option B) add dual 400c for a total of 3 compressors
    option C) replace 450c with dual 400c
    option D) replace 450c with ARB twin
    Breakdown:
    450c : 1.52cfm @ 30psi, max 23 amps
    dual 400c : 3.74cfm @ 30psi, max 59 amps
    ARB twin : 4.68cfm @ 30psi, max 69 amps
    450c + dual 400c : 5.26cfm @ 30psi, max 82 amps (speculative)
    one other consideration; I am planning to be installing ARB lockers front and rear soon. I'm not sure if it makes a difference because I will likely run them from a regulator off of the tank. Unless there's a reason not to do this?
  5. Jan 15, 2018 at 11:14 AM
    #1525
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Compared to airing up tires, ARB lockers draw very little air, no comparison. For years, I had a system that used a GMC air pump from a 80's era Buick for my single ARB. Cost about $20 from a wrecker.
    IMHO, either a belt-driven air pump, or a liquid CO2 tank( PowerTank for example) is the best solution for you.
    WormSquirts likes this.
  6. Jan 15, 2018 at 11:33 AM
    #1526
    WormSquirts
    Braeden
    BC
    Belt driven would be ideal, but seems like a hefty hassle to install in a Tacoma. The reason I didn't list CO2 is because I get decent prices on Viair or ARB through my business, but no good price options on CO2. I also like the built in, set and forget ability of a compressor compared to CO2... You are right though, it would be a great option
  7. Jan 15, 2018 at 1:58 PM
    #1527
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    From what I've witnessed, dual 400Cs would be a good compromise for speed and cost. My Buddy Zane is running this setup. Though it is not quite as fast as my twin ARB, the airing up time difference is not that great. And the cost difference is significant as the ARB is not cheap. @Speedytech7
    WormSquirts[QUOTED] likes this.
  8. Jan 15, 2018 at 2:24 PM
    #1528
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    400C is a great setup for airing up and lockers, two would be nice for bigger tires. I have two of the 444C and they are a bit closer of a match for the ARB dual pressure wise but still about .97CFM less flow at 90PSI. All of the Viair compressors are rebuild-able which is cool and the 400C is closer in total flow albeit at lesser total pressures. I would sell your current compressor if you're unhappy with the speed and install the dual 400c kit instead, it'll be quite a bit faster. Three would be ridiculous space wise plus hose clutter, and the ARB while nice isn't as easily rebuilt and the price differential is high. The ARB makes the most sense if you need the space and can keep it cool and dry though, I worry about its little computer cooling fan and overall temps.
  9. Jan 15, 2018 at 9:41 PM
    #1529
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    After installing my dual battery, I lost my mounting location for my compressor.
    Ive seen people install compressors inside the bed cubbies, but I hate the idea of losing that storage space. Ive seem people run them under the bed mounted to the chassis. Saves space but leave the compressor exposed.
    Has anyone mounted the compressor to the top side of one of the cubbies so it sits up inside the bed side out of the elements? Im kickin around the idea of mounting my MV-50 like this then running it to a quick disconnect either in a cubby or the bed side.
    Thoughts?
  10. Jan 16, 2018 at 8:03 AM
    #1530
    bagleboy
    Scott
    Norcal, Santa Rosa
    I'm still working/planning on locating that same compressor and a 2-gallon tank in the bedside forward of the passenger side wheel well. My thought follows yours in that I want to keep the cubbies for removable items but I want any weight added to be as far forward as possible and on the passenger side. I'm pretty sure above the cubbies works(at least for the compressor) but I'm reserving that space for an ironton mini hose reel.
    steveo27[QUOTED] likes this.
  11. Jan 16, 2018 at 10:52 AM
    #1531
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    That space get plenty of road grime, water, and mud slung up there.
    rob1208 likes this.
  12. Jan 16, 2018 at 10:54 AM
    #1532
    Speedytech7
    Yeah probably not a great location for an MV-50. The Viair compressors past 300c are all IP-6x rated though and have remote intake options so those could mount fine there.
  13. Jan 16, 2018 at 11:33 AM
    #1533
    silasvirus82
    silasvirus82 Well-Known Member
    NC
    3rd Gen Off-Road DCLB
    Hobie Fishing Edition
    That is exactly where I'm mounting my compressor and regulator, pics forthcoming if it ever gets above freezing here. My tank will be mounted below the cubby and the air intake inside the cubby.
  14. Jan 16, 2018 at 12:23 PM
    #1534
    steveo27
    Pittsburgh
    Deffinitely interested in seeing how this works.
  15. Jan 16, 2018 at 12:52 PM
    #1535
    WormSquirts
    Braeden
    BC
    That's where I mounted my Viair. Looking up in there, there is some dirt, but not nearly as much as behind the wheel. I made a thread about that location that didn't really get much traction: https://www.tacomaworld.com/threads/the-ideal-compressor-location-long-box-only.488023/
    bagleboy[QUOTED] likes this.
  16. Jan 16, 2018 at 7:47 PM
    #1536
    bagleboy
    Scott
    Norcal, Santa Rosa
    Yup, that's the spot I'm looking to use. It's a snug fit but I think the tank will squeeze in there too since I'm keeping my spare right where it is. I have to make up a bracket to hold both that bolts through the sidewall of the bed and cut a hole to access the compressor if needed.
  17. Jan 17, 2018 at 8:14 AM
    #1537
    WormSquirts
    Braeden
    BC
    That's good advice. I'm still quite tempted by the ARB, but don't like that it uses proprietary hoses so that I would have to figure out some sort of manifold system to hook it to my tank. I haven't looked closely at it though, so it might not be all that bad.
    You're right that 3 would be a bit of a tangle. Going for a dual Viair setup seems like the easiest option for me since it's all already wired, and I would just have to add a T to the input and mount it basically. You make some good points. Appreciate your input!!!
    I have a tonne of space on my passenger side fender well after I removed the stock airbox, so I could easily fit 3 compressors there, plus my other spot in front of the rear wheel in the bedside, where I have mine mounted currently, where I could fit 2 on each side if I wanted... Maybe I should run 7 compressors and upgrade my alternator o_O:p
    I think you're both right, and for the money, the dual viair set up is the best deal. I'll keep thinking about it... if I can work it out that my business can buy the compressor, I might still do the ARB just because that's mostly what we sell, and I have one sitting there on the shelf. R&D/marketing you know haha
  18. Jan 21, 2018 at 4:17 PM
    #1538
    TWTaco
    TWTaco Well-Known Member
    Dave
    Well its been over a month since i first installed my twin ARB comp! Its been in n out 3 times now , had to ship back to ARB for problems. 1st time was for a bad motor, returned and installed only to not work correctly again motor fixed but really bad air pressure. Pulled out of truck shipped back diagnosed with a bad manifold. ARB returned me a brand new in box unit plus a really nice ARB digital tire inflator , a ARB key chain and some stickers! Really the best customer service i think i have had from any company!34.jpg
  19. Jan 21, 2018 at 6:19 PM
    #1539
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Alright everyone, I read through and I feel like I need some critiquing/reassurance. I have an arb twin compressor that will be running lockers and filling a 2.5 gallon compressor. I was going to run the system like this.
    Compressor>water trap>manifold
    So from the manifold It will go like this:
    Manifold>Locker solenoids
    Manifold>pressure regulator>Tank>Water trap>Quick connect
    Manifold>air gauge
    The air tank will have a 150psi blow off valve and also a drain valve for any moisture.
    I was planning on running airline for all of this since you can't really make custom air hose connections I think?
    Do I have the right idea or am I way off?
  20. Jan 21, 2018 at 6:23 PM
    #1540
    Sandman614
    Tim
    '06 SR5 Off Road
    I've had nothing but excellent customer service from ARB/OME!!
