OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Dec 15, 2013 at 7:02 PM
    #141
    skygear
    skygear                    
    You stole my OBW spot that I was going to reveal over the spring :spy:
  2. Dec 15, 2013 at 7:03 PM
    #142
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    :p Any ideas on how difficult it is to remove the bedside? Can make a bracket that utilizes the bed to frame mounting point to mount the compressor.
  3. Dec 15, 2013 at 7:05 PM
    #143
    skygear
    skygear                    
    Those are what I was refering to as being able to stuff up there. Remings me of my old "Sneaky Pete" nitrous bottles I had stuffed in my one of my old vehicles...
    Why not do what my end game is. Drill and tap your sliders! make them into air tank sliders. Can't remember if yours were weld ons, but thats 4-6 gal of air tank right there. Your proximity to them sliders now is uncanny.
  4. Dec 15, 2013 at 7:08 PM
    #144
    skygear
    skygear                    
    I am glad that people are thinking outside the box now. Utilizing all the additional dead space out vehicles have on them. Turning it into functional space for needed/ functional gear.
  5. Dec 15, 2013 at 7:10 PM
    #145
    skygear
    skygear                    
    Who's build is that anyways? Not yours right/. Yours is red. Thats a Blue LB
  6. Dec 15, 2013 at 7:15 PM
    #146
    BradyT88
    BradyT88 Well-Known Member
    But does the time that you save on that one tire make up for the time lost on the next 3 is my question?
  7. Dec 15, 2013 at 7:22 PM
    #147
    skygear
    skygear                    
    It depends on your CFM. Tire size and other factors. Take my rig, I want to go with 35x12.5r20's - To fill mine would take less time than a 35x12.5r16 due to the size there. I feel the short answer is YES. But the first 2 will fill up quickly.
  8. Dec 15, 2013 at 7:23 PM
    #148
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Yeah, I found it when searching on removing bedsides...no info other than the pic. Some other guy wanted to mount his set up in the bedsides but never posted a finished product.
    Should be a significant time savings with a tank....considering your filling a 5 gal tank from 160-200 in 1-2mins.
    My 1 gallon porter cable trim compressor takes ~2.5 full tanks @ 140psi to fill my 35x12.50R18 back to street PSI.
  9. Dec 15, 2013 at 7:25 PM
    #149
    skygear
    skygear                    
    When you find the write up on bedside removals, got to link that here for the masses. Or if you do it, do a nice write up!
  10. Dec 15, 2013 at 7:27 PM
    #150
    skygear
    skygear                    
    I'm doing 2 regulators on mine. 1 for the lockers and tools rated ~90psi and the other to adjust as needed. Might pick up a HVLP Pneumatic paint gun or two.
  11. Dec 15, 2013 at 7:39 PM
    #151
    BradyT88
    Yeah, I know there are a lot of different factors in here. In a nutshell, my question is using the same compressor and a 5 gal tank and filling say 35x12.50R16's. Will it be faster with the tank or not. Obviously if the tank is big enough then yes, but I have my doubts a 5 gallon tank is big enough to fill 4 of those 35's, and I wouldn't be surprised if a 5 gallon tank is a similar volume to a single tire so once the tank is drained it is like filling up two 35's are the same time... I'm going to do some research.
  12. Dec 15, 2013 at 7:40 PM
    #152
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Still searching.
    Here is a view of the driver side usable space under the bed side.
  13. Dec 15, 2013 at 7:52 PM
    #153
    skygear
    skygear                    
  14. Dec 15, 2013 at 7:56 PM
    #154
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    With a dual your doubling your CFM across the PSI range.
  15. Dec 15, 2013 at 8:01 PM
    #155
    skygear
    skygear                    
    The numbers are there. Still has me a little confused there though. So are they claiming that to fill the tank, 2.5 gal, it would be those numbers from 0 psi. Then if that same tank was empty, it would be the numbers below that to fill the 35"s?
    Rite off the bat, i went with a 3/8" hose instead of the recommended 1/4" hose. Hoping to supply more air faster to the ports/ tools.
  16. Dec 15, 2013 at 8:10 PM
    #156
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    I'm debating on what size air line to run. Had 5/8" on the old truck:eek: Fittings are hard to come by, Will probably go with 3/8" or 1/4".
    :goingcrazy: I might be going overboard... All I need for my application is a simple tank and compressor :cool: Would love to hide it in the bed side though, but @ only 2 gallons per side it might not be worth the effort. (Considering I can't put a spare tire under the truck ANYWAYS :eek:)
    EDIT: Maybe two slim tanks strapped together will fit on one side.
  17. Dec 15, 2013 at 8:14 PM
    #157
    zopperman
    zopperman LED & HID positive
    Zak
    Arlington, VA
    03 4Runner
    Lift, 32" Duratracs, sliders, LED light bar, interior LEDs, sweet tunes & sub, OBA, sliders, TRD 16" 6 spoke wheels, CB, HID spotlights, electrical mods, etc.
    Hmmm I was thinking of trying to mount one of those AVS slim tanks somewhere on my truck but this is a sweet idea. I don't see why it wouldn't work. I have no idea what they would be rated to though.
  18. Dec 15, 2013 at 8:15 PM
    #158
    skygear
    skygear                    
    Well, would be a nice CLEAN install there. I know 35"s do not really fit under there. Maybe you could fab a bracket so they could. When I finally get mine, I am going to try to stuff one in there. Not sure how hard people have tried. I would like to carry 2 tires though. One on a Swing out, and the other stuffed.
  19. Dec 15, 2013 at 8:47 PM
    #159
    BradyT88
    On the specs you posted, both of the duals have 2.0 gallon tanks and both the singles have 2.5 gallon tanks so the number are off there. All 4 of those use different compressors.
    These both use the 450C compressor. 1 is dual and 1 is single and the CFM's basically double. The times are pretty close as well.
    http://viaircorp.com/450C.html
    http://viaircorp.com/dual450c.html
  20. Dec 15, 2013 at 8:59 PM
    #160
    BradyT88
    As for the hose I definitely recommend the 3/8" hose. My ARB hose is 1/4" and it seems to be slower. Although I haven't decided if it is the hose or the ARB gauge I use.
    I built a 4 tire inflator a couple weeks ago and timed it. Here were my results.
    I used my ARB CKMA12 and my 255/85R16 KM2's on 16x8" wheels. I run them at 50 psi on the street and 20psi on the trail.
    My 4 way uses 3/8" ID hose and all 1/4" NPT parts.
    4 tires:
    Deflate: 50 to 20 psi: 3:30 minutes
    Inflate:
    20 to 30 psi: 5:00 minutes
    30 to 40 psi: 6:30 minutes (11:30 total)
    40 to 50 psi: 7:15 minutes (18:45 total)
    ARB kit (1/4" hose I believe) and the ARB inflator gauge. To deflate I just clamped the little tiny ARB chuck that comes with their fill kit.
    1 tire:
    Deflate: 50 to 20 psi: 3:45 minutes
    Inflate:
    20 to 30 psi: 1:35 minutes
    30 to 40 psi: 1:45 minutes (3:20 total)
    40 to 50 psi: 1:45 minutes (5:05 total)
    This is the ARB inflator guage I have:
    And this is the Orange ARB hose I have:
    [​IMG][/QUOTE]
    Little tire chuck on the end of the hose
