OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Mar 11, 2018 at 11:55 PM
    #1581
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I doubt a 1 gallon tank will help much airing up tires. It's more useful with small volume tasks or maintaining constant pressure.
  2. Mar 11, 2018 at 11:57 PM
    #1582
    Kasbien
    Kasbien Well-Known Member
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Pop rivets and JB Weld.
    No intent for air tool use, just tires. :oops:
  3. Mar 11, 2018 at 11:59 PM
    #1583
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    So it's actually better to NOT run a small tank? It hinders things?
  4. Mar 12, 2018 at 12:01 AM
    #1584
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It can slow things down cause it is another cavity to fill, If I had to draw a pressure curve over time ito would look like a huge rollercoaster drop and a slow buildup to half pressure. So you gain a little time, lose a little time, and work your compressor more.
  5. Mar 12, 2018 at 12:01 AM
    #1585
    bagleboy
    Scott
    Norcal, Santa Rosa
    Lots of other things can be powered by air besides tools, bags, lockers, pressurized water tank, air horn, etc. but if you're only filling tires then fan the tank.
  6. Mar 12, 2018 at 12:05 AM
    #1586
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Ah, that makes sense. If you had a larger reserve, say 2-3 gallons under the bed, would that be enough for four tires or do you quickly end up in the same situation?
  7. Mar 12, 2018 at 12:07 AM
    #1587
    Speedytech7
    I't might make the first tire faster, you'd be back at usual speed for the other three. You essentially have to match the volume and pressure of air to that in your tires at full pressure. My 30gal compressor used to have to kick on when airing up my old explorer. Can't imagine carrying a 30 gal tank though. I'd recommend some bigger or faster compressors. I use two Viair 444C
  8. Mar 12, 2018 at 12:12 AM
    #1588
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Jeeze! Okay. Well it looks like I either need to A) Suck up having a small compressor or B) Get a bigger compressor or C)...get a Co2 tank. However, having a Co2 tank and a compressor just for a locker seems like a waste.
    Thanks everyone.
  9. Mar 12, 2018 at 12:13 AM
    #1589
    Speedytech7
    You can use CO2 for lockers too, even an airsoft minibottle with a regulator can run a locker.
  10. Mar 12, 2018 at 12:19 AM
    #1590
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Stop. My brain can only consider so many options haha. I'm so used to being privileged with unlimited clean (and quiet) air at work that I never considered what it takes to produce it.
  11. Mar 12, 2018 at 5:04 PM
    #1591
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    I have the 1 gallon tank from ARB and it really doesnt make a difference, not even for air tools. I will be replacing it with a 3 to 5 gallon tank under the bed eventually.
    Kasbien[QUOTED] likes this.
  12. Mar 13, 2018 at 6:48 AM
    #1592
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I have a 2.5 gallon, doesn't seem to make a big difference when a tire takes something like 20 gallons from flat (regular size tire, obviously a 35 or 42" will take more)
    JWROSE4[QUOTED] likes this.
  13. Mar 13, 2018 at 2:15 PM
    #1593
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    So a little update... I'm now considering returning the ARB CKMA12 compressor in lue of the smaller CKSA12 compressor in order to SOLELY run the rear locker off it. In addition, I will run a Co2 tank setup to do my tires quickly as airing up at the end of a long ass day has always been a serious pet peeve of mine. I looked into the dual ARB setup but the $CAD exchange hurts right now.
    Although this isn't exactly a thread for Co2 discussion, does anyone know what particular hose material is needed for safe usage? Or will a standard air hose cut it?
  14. Mar 13, 2018 at 10:04 PM
    #1594
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I use the standard air hose for mine, from the tank back to the quick-disconnect.. Holds the pressure fine, but when I do a soapy-water test at the connections, I get some bubbling, so I don't leave it pressurized when not in use.
    Kasbien likes this.
  15. Mar 14, 2018 at 5:37 AM
    #1595
    Sandman614
    Tim
    '06 SR5 Off Road
    Yep regular hose should be fine for pressure, co2 uses a regulator to lower tank pressure (3000psi?) to line pressure (50psi?)
    Sounds like you need some better thread seal, unless you're talking about the quick connects.
  16. Mar 14, 2018 at 11:30 AM
    #1596
    G.T.
    G.T.
    CONUS
    Keep the compressor you have and set it up without the tank. Add the Co2 setup you want. With this you’ll have speed and the security of a fallback system.
    mcharfauros and seoulja99 like this.
  17. Mar 15, 2018 at 11:50 AM
    #1597
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    This is tempting. Smart man!
    mcharfauros likes this.
  18. Mar 16, 2018 at 10:56 AM
    #1598
    bagleboy
    Scott
    Norcal, Santa Rosa
    CO2 can use standard hoses or even the cheap coil hose but if you're using a larger bottle to fill tires you should probably get something rated for below freezing temps as the gas leaving the bottle very quickly goes sub zero and stays there. Most importantly the bottle has to be used in the upright position or the liquid CO2 will destroy the regulator in short order. Another thing to consider is tire pressure should continue to climb a bit as the gas fill comes up to ambient (PV=NRT). I don't have any empirical evidence on how much since I've only used mine to add a few pounds rather than 50% or more of the total pressure. I'd be curious if it was negligible, a pound or two, or something more. Be gentle with your valve stems when removing the nozzle since they will also have been exposed to extremely low temps. I've not heard of bad things happening other than regulator issues(quite common) so it's more cautionary common sense than hard won personal knowledge.
  19. Mar 20, 2018 at 9:48 AM
    #1599
    austin2009
    austin2009 Well-Known Member
    Austin
    Boise, Idaho
    Lifted and Locked 09 2.7L 2TR 4x4 5 Speed
    DRIVETRAIN- -4.56 Nitro gears -ARB rear locker -SPC UCA's -Fox 2.5" RR fronts/650lb coils -Bilstein 5100's rear -1.5" AAL -285 BFG KO2’s -16x8 MK6’s ARMOR- -ABR bumper -BAMF LCA skids -Cali Raised sliders RECOVERY- -Smittybilt XRC 9.5k synthetic winch -ARB OBA -Factor 55 Pro Link, Expert STEREO- -Pioneer head unit -Rockford T series speakers -Rockford 500 watt amp -Rockford P2D4 8" sub LIGHTING- -Calirasied ditch lights -Caliraised amber fogs -Hella Black Magic’s -Blue Seas fuse panel
    I see a lot of the ARB dual setups but not nearly as many of the singles. So, who’s got pictures of their single setup? There’s some threads from like 2012 but nothing really recent.
  20. Mar 20, 2018 at 10:11 AM
    #1600
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I think most people that get the single ARB eventually get the dual ARB lol
    bonnfabrication and tacomgee like this.
