OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. May 18, 2018 at 8:22 AM
    #1641
    silasvirus82
    silasvirus82 Well-Known Member
    NC
    3rd Gen Off-Road DCLB
    Hobie Fishing Edition
  2. May 19, 2018 at 1:57 PM
    #1642
    micwillia
    micwillia Nonstop Tinkerer
    Cental Masshole
    Turd gen Inferno Taco TuRD OR DCSB 6MT, '96 Mustang V6 Vert 5MT
    Cubby Covers, TRD Pro Exhaust, BAK RevolverX2, Pro Skid, Speaker Upgrade, OBA/W, CB, 255/85R16
    You should take a look at my cubby caps (sig) they help to greatly reduce the amount of crap that gets flung into the cubbies. Not perfect but a good help.
  3. Jun 19, 2018 at 11:18 PM
    #1643
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    For those with a tank. How long does your tank hold pressure? Trying to figure out if I have a leak or if it’s normal to loose a couple pounds over time. For instance go from 150psi to 90psi in a day.
    My setup thus far. I have a lot of cleanup and I still have to wire up the switches for the compressor. Currently just “hotwiring” it tonsee if I need to make changes.
    BYJOSHCOOK likes this.
  4. Jun 20, 2018 at 12:03 AM
    #1644
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Push to connects can leak and the higher the pressure the faster the drop but 60psi in a day sounds like a problem. Make sure they're fully seated in the fitting, sometimes the tubing resists that last 1/8" in the docking maneuver. Also, if the air line goes out of round when it's cut it can leak. I use a bit of metal tubing to hold the shape stable and provide a square guide for a razor knife and that seems to work. Haven't tried the dedicated tubing cutters as they look pretty cheap for what they cost. To maintain tank pressure and sidestep some of the ptc issues I'm using barb connectors at the tank and the solenoid that feeds the manifold since those are semi permanent installs. If needed, you can use a QR coupling (supposed to be pressure tight) and barb fitting to make the tank detachable. Also, lube the draincock and make sure it turns freely and closes fully(things are sometimes sticky af). Its recommended also to use a braided line for the first 18-24" from the compressor since the compresssor gets pretty hot.
    tacoma16[QUOTED] likes this.
  5. Jun 20, 2018 at 5:22 AM
    #1645
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    You have a leak. A sealed system realistically Shound not leak more than a few psi in a day.
  6. Jun 20, 2018 at 5:25 AM
    #1646
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Thanks. I am using the push connect fittings, which I may have to change to braided from the compressor and the tank. I will have to go back and double check the push fittings. Soap and water may be in order to see for leaks. I will look into those other fittings. The fittings I have are good up to 200psi, so I will double check as I got them in a kit which was $50 so who knows the quality....
  7. Jun 20, 2018 at 5:27 AM
    #1647
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    thats what I was thinking. Thanks. Some soap and Water are in order
    YamaDirtrider[QUOTED] likes this.
  8. Jun 20, 2018 at 6:29 AM
    #1648
    silasvirus82
    NC
    You definitely have a leak somewhere to investigate, and a completely sealed system is possible. It appears you're using tape instead of Loctite 565. I never used 565 prior to putting my OBA system together, but mine holds pressure indefinitely. I've gone months without turning on the compressor, and it was still holding full pressure. So you might try that...
    JWROSE4 and tacoma16[QUOTED] like this.
  9. Jun 20, 2018 at 6:32 AM
    #1649
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Definitely something I will look into. If the soap and water test fails I will go back and redo the fittings. My initial water test passed but maybe I need more soap.
    Something that I just found is that I dont have a check valve going from the compressor into the manifold. I understand that leaks in the system are still possible, but may change that over as I do have one at home.
  10. Jun 20, 2018 at 6:52 AM
    #1650
    silasvirus82
    NC
    Another thing worth mentioning is that 565 is very forgiving. I had multiple fittings that I glued, removed, glued again, basically made a real mess out of, and half expected to leak. They didn't. I would also avoid those push-to-connect fittings all together and swap out with compression fittings. As someone else already mentioned, that is likely your issue, but avoiding hose fittings in general is ideal. I ended up with only two compression fittings at either end of the tank line, and everything else was plumbed with hard fittings. That included a regulator, gauge/switch, pressure switch, tank, compressor, and hose reel for main components.
    tacoma16 likes this.
  11. Jun 20, 2018 at 6:59 AM
    #1651
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    may switch it all to compression fittings. Have to do a bit more research I guess. Bought a kit to save some mulla, but may be paying in the long run...oh well another lesson learned. Will try the easy/cheap things first and go from there.
  12. Jun 20, 2018 at 8:10 AM
    #1652
    YamaDirtrider
    Josh
    Elizabeth CO
    Semi trucks use the push tight an they don’t leak. You proably messed up on one of the ends or somthing.
  13. Jun 20, 2018 at 8:21 AM
    #1653
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    most likely. Start with the easiest things first and go from there. Appreciate the reassurance on the fittings though as setting this up has been a huge learning curve for me lol.
  14. Jun 20, 2018 at 8:24 AM
    #1654
    silasvirus82
    NC
    The best systems out there are found on air ride suspension setups. Those guys typically only run hard lines which require additional tools and money, but man they look awesome. For your setup that might be another consideration since everything is visible. We just love spending your money :)
  15. Jun 20, 2018 at 8:31 AM
    #1655
    bagleboy
    Scott
    Norcal, Santa Rosa
    Definitely need a check valve from the compressor or it will bleed back through the compressor and not show on a leak test of fittings. The compressor "valves" are just flaps made to open and close quickly and don't really seal the way a spring loaded check valve will.
  16. Jun 20, 2018 at 8:32 AM
    #1656
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I was considering this for a main line and using shark bites....like you said though....money.
    It does look sharp though.....
  17. Jun 20, 2018 at 8:35 AM
    #1657
    silasvirus82
    NC
    Is that an ARB thing? The VIAIR I'm using included a check valve that seems to be working flawlessly.
  18. Jun 20, 2018 at 8:42 AM
    #1658
    bagleboy
    Scott
    Norcal, Santa Rosa
    Don't know but a check valve is a separate item. ARB may use better valvilng but I thought even they included a check valve with their complete systems.I'd put money on it that the problem is the missing check valve. To be honest it's something I didn't consider when I started buying my parts but included after more reading.
  19. Jun 20, 2018 at 8:47 AM
    #1659
    silasvirus82
    NC
    I know it's separate from the compressor, but like I said the VIAIR comes with a check valve and braided line from the compressor. I can't believe the way more expensive ARB does not, but maybe that's the case.
  20. Jun 20, 2018 at 8:57 AM
    #1660
    bagleboy
    Scott
    Norcal, Santa Rosa
    Sorry, quoted you but the intent was to inform t16 about the problem. I do believe ARB includes one with their complete kits but I've also seen Vair compressors sold as kits or with just the compressor alone. My knowledge of the valving comes from opening the head of an MV50 not one of the better units but given that the check valve is included with even higher end units indicates it's at least a good idea and probably a necessity.
