OBA -> On Board Air Mega Thread & BS
Discussion in 'Technical Chat' started by Gunshot-6A, Oct 20, 2013.
  1. Aug 1, 2018 at 12:40 PM
    #1681
    Toyotico
    Toyotico Well-Known Member
    Jonny
    Cartersville, Georgia
    2017 Silver Tacoma 4x4 dclb
    I have a question for y’all seasoned oba dudes. I’ve got an arb dual and plan on running it for airing up tires mainly and was planning on mounting it in the engine bay vertical next to the radiator with the slee mount. Running a steel braided line to the rear bumper. Would this be any real disadvantage to the compressor/lines or use as opposed to say an expedition cubby mount?
  2. Aug 1, 2018 at 12:42 PM
    #1682
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Shorter power lines is a plus..
  3. Aug 1, 2018 at 12:50 PM
    #1683
    Toyotico
    Jonny
    Yea all gonna be wired right there. Heat on the equipment ok?
  4. Aug 1, 2018 at 1:03 PM
    #1684
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
    I've had my dual in the engine bay for a while now with no issues.
  5. Aug 1, 2018 at 1:25 PM
    #1685
    Sandman614
    Tim
    '06 SR5 Off Road
    Yea no issue, plenty of airflow with the engine running.
  6. Aug 1, 2018 at 4:56 PM
    #1686
    Toyotico
    Jonny
    Thanks dude!
  7. Aug 30, 2018 at 10:13 PM
    #1687
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    So which units fit behind the rear driver seat?I think I wanna put it there to be completely out of the elements.
    itaro likes this.
  8. Aug 31, 2018 at 8:00 AM
    #1688
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Crom likes this.
  9. Aug 31, 2018 at 8:28 AM
    #1689
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I think my very first air compressor was behind the seats. After a few trips I realized how hot it got back there, especially with the seats in their normal position. So I moved it to the bed shortly after. Would it have been a problem down the road? I don't know. I see some people still do it, but for my peace of mind, it wasn't good enough for me.
  10. Aug 31, 2018 at 8:47 AM
    #1690
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Appreciate the input. Mines going behind the seat or on a slee bracket. Valid points for each argument, which make the decision that much harder lol :annoyed:
    itaro[QUOTED] likes this.
  11. Aug 31, 2018 at 9:15 AM
    #1691
    MJonaGS32
    MJ
    SF Bay Area (East)
    Yeah airing it out while using it is a good idea just to be on the safe side. My lazy ass doesn't want to worry about that haha. I have quick couplers on both bumpers so I never even see my air compressor
    kgarrett11 and itaro[QUOTED] like this.
  12. Oct 29, 2018 at 10:11 AM
    #1692
    pjskinner
    pjskinner Active Member
    What member, and what adapter? I would like to do this same set up!
  13. Nov 7, 2018 at 3:49 AM
    #1693
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
  14. Nov 7, 2018 at 8:24 AM
    #1694
    MJonaGS32
    MJ
    SF Bay Area (East)
    Looks good. idk if you've done this already, but I'd cover up those holes because a lot of mud and dirt gets kicked up there (assuming you've removed your mud flaps). When I used to store mine in that location, my air compressor eventually seized up from all the gunk.
    I ended up reversing the power and ground wires and it kickstarted it backward, and then I put the wires back and it worked perfectly fine again after
    Gunshot-6A[OP] and toysrgood like this.
  15. Nov 8, 2018 at 3:54 AM
    #1695
    Red18Taco707
    Richi
    Nor Cal
    Red 18 TRD POOR
    Yup! I just used tape to cover up the wholes lol I also made a lid for the box so nothing falls in.
    MJonaGS32[QUOTED] likes this.
  16. Nov 27, 2018 at 4:03 AM
    #1696
    Captbrad88
    Captbrad88 Well-Known Member
    Brad
    2018 Tacoma trd offroad
    I know this is a old thread, not sure if active. Heres my set up so far, need some input. Got the dual ARB compressor mounted, that’s it lol. Now I have a Viair 1 gallon tank I’m gonna mount, since it has four ports I can mount a safety valve and drain. Now my idea is to put a 90* from the compressor to the tank. Use a T fitting out the other side to my two lines for my quick connects. My question is, 1. do I need a pressure gauge hook up since I know the arb shuts off at 100psi, the tank is rated for 150psi? 2. Is it best to use a over rated 175psi blow off or a under 145psi safety valves? 3. Do I need a pressure switch since the arb has one built in, and I don’t plan on leaving the tank full when not in use. 4. Will I need a air dryer in-line to help? 5. Do I need to put a check valve in line to the tank? If someone could give me some input I’d be thankful.
  17. Nov 27, 2018 at 6:44 AM
    #1697
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Water filters are never a bad idea, even for tires since moisture corrodes tpms sensors and changes volume much more than air with changes in temperature. You want the relief valve pressure to be above the switch pressure and below the tank max so 145 psi is fine. Only need the one pressure switch but you can swap it for a different pressure as long as it's below the relief pressure. You should use flexible SS braided hose between the tank and compressor rather than a hard pipe connector(for the first 18" anyway), as it needs to absorb both heat and vibration. Most compressors will bleed back pressure so yes on the check valve too and screw it into the tank after the SS line. The tank drain should be at the lowest point. Use rubber isolators when you bolt up the compressor.
    Toynado and MJonaGS32 like this.
  18. Nov 27, 2018 at 7:50 AM
    #1698
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I have a safety blow off in case the tank gets hot and the air expands building pressure since I have the tank in the bed with a cap. Its a 150psi blow off.
    For the dryer....Apparently you need so many feet of line for the air to cool prior to it being able to have it separated. SO I took mine off and constantly drain the tank and run the compressor with the tank open to drain the lines as I only have 2-3 ft of line from the compressor to the tank. Additionally, I have a cutoff so I don't have to fill the tank completely or have the tank filled all the time. I usually just open the lines and fill the tank near the end of a trail so I can fill up tires. Otherwise I just want instant pressure to run my lockers.
  19. Nov 27, 2018 at 8:07 AM
    #1699
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I agree with the earlier comments, in addition:
    Item#1 - a pressure gauge is a good idea just to make sure the system is working properly.
    I mounted my gauge in the cab
    Item#3 - no need for redundant pressure switches
    Item#4 - I didn't have an air dryer, and never had a problem with moisture,
    but then again, I live in California (low humidity).
    If you are using this system to also run an air-locker, then you'll need a pressure regulator
    (set to about 80 psi) for the air line running to the locker.
    When done, be sure to test all the connections for leaks, with soapy water.
    A little leaking is OK since the system will only be pressurized while airing up tires
    (or while on the trail if you are also running a locker).
  20. Nov 27, 2018 at 9:34 AM
    #1700
    Captbrad88
    Brad
    Thanks for the response, yeah being from Louisiana and about 90-100 humidity on a daily I might need to look into it. But like I said I won’t be leaving the system pressured up only when needed.
